Page 109 of 123
Posted: Wednesday 27 December 2017 0:34
by serak
can anybody help me, please? I've installed and configured xiaomi gateway. Everything works great. Blockly events works.
- gw1.jpg (55.23 KiB) Viewed 3542 times
Now I'ld like to set light color. This can be done by json script. But if I try it from OS I get this response:
d:\curl\src>curl -S -i -H "Accept: application/json" "http://192.168.1.38:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=12&hue=38&brightness=83&ishite=false"
curl: (7) Failed to connect to 192.168.1.38 port 8080: Connection refused
d:\curl\src>curl -S -i -H "Accept: application/json" "http://192.168.1.38:9898/json.htm?type=command¶m=setcolbrightnessvalue&idx=12&hue=38&brightness=83&ishite=false"
curl: (7) Failed to connect to 192.168.1.38 port 9898: Connection refused
Why I get this error? IP adress is OK. (I've tried two ports)
Posted: Wednesday 27 December 2017 9:08
by hekm77
serak wrote: Wednesday 27 December 2017 0:34
IP:Port = ip_domoticz:port_domoticz
idx = xiaomi gateway idx from devices tab
Posted: Wednesday 27 December 2017 10:40
by serak
It works! Thank you.
Posted: Thursday 28 December 2017 22:44
by raffiq78
corbin wrote: Saturday 23 December 2017 21:46
wall switches still working here. did you apply the latest gateway update? I haven't on mine.
Probably I did.
My version is : 1.4.1_151.0143
something wrong with it ?
Posted: Friday 29 December 2017 20:29
by grunkan
I just got a couple of Honeywell Smoke Detectors in the mail. They where super easy to add to Domoticz! But I have a problem. I can't trigger the alarm sound from Domoticz. Is it even possible to do this? My plan was to link them together to make them turn on the alarm if any of them detect smoke and I wanted to use them as "sirens" in my home alarm.
Is this a dead end?
Posted: Sunday 31 December 2017 13:41
by farhanito
i have an issue with latest beta v3.8797
all sensors, switches, and plugs are working fine, but the gateway itself is not. i can't control the RGB, alarm, and the lux meter isn't updating..
Posted: Wednesday 03 January 2018 20:26
by grunkan
farhanito wrote:i have an issue with latest beta v3.8797
I had the same problem when I plugged in the gateway the first time and added it in domoticz. I think I restarted both the gateway and domoticz and it started to work.
Skickat från min XT1562 via Tapatalk
Posted: Thursday 04 January 2018 8:25
by ChopCZ
ChopCZ wrote: Tuesday 12 December 2017 8:29
ChopCZ wrote: Monday 27 November 2017 9:16
sincze wrote: Sunday 24 September 2017 13:11
DIM the white LED to any level of the Xiaomi Gateway is that possible? Any other colour I am able to DIM to the level I want, except White.
Hi, I am having the same issue.
Anyone was able to solve this?
I am using my Gateway with motion sensors as nightlight and I realy need to change the DIM level to custom values.
The original Mi Home is able to change level of white light and even can do fluent light up. I mean it seamlessly increases the brightness level to desired value in short time period and thats really cool effect. I have tryed to do that in domoticz python script but domoticz cannot change the brightness as fluently as the gateway itself.
Hi guys,
I apologize for repeating my question but I was unable to find the answer.
Is this an issue in the gateway plugin or hardware limitation that I can not change the brightness of the white light?
The plugin for yeelight bulb can do this...
Happy New Year everybody!
Is there any chance I will got an answer to my question?
Thank you
Posted: Thursday 04 January 2018 9:44
by schlabbe
grunkan wrote: Friday 29 December 2017 20:29
Is this a dead end?
I have the same question.
I would like to implement the Smoke Detectors in the alarm system.
But turning the Detector "on" doesn't have an effect.
Anybody who got this working?
Thank you very much in advance
Posted: Thursday 04 January 2018 9:48
by pjsgsy
Just to add, I have 2 of the smoke detectors on the way too so will be interested to know if anyone gets them working.
Posted: Thursday 04 January 2018 12:17
by grunkan
ChopCZ wrote:ChopCZ wrote: Tuesday 12 December 2017 8:29
Hi guys,
Thank you
I'm not sure I understand the question? If you would like to change the light in the gateway it self you can do this in the RGB dimmer switch in domoticz. Both colour and brightness.
Posted: Thursday 04 January 2018 19:46
by ChopCZ
Thank You for your reaction
I know I can change the color and brightness of the Gateway via RGB dimmer switch. But if I try to set the white color via RGB dimmer and change brightness of the white color then I have not succed. White color can only be set by On or Off buttons.
I had no luck using JSON API commands
https://www.domoticz.com/wiki/Domoticz_ ... brightness
But for the Yeelight bulb both methods are working fine for the white color.
Posted: Thursday 04 January 2018 20:35
by mvveelen
Maybe it's already mentioned before, but I couldn't find it:
I have this Aqara switch:
And it shows me only a "Click" and a "Double Click". I added a "Long Click", but that doesn't work.
Is the Long Click not possible or do I have to add it a different way?
(I'm using the latest firmware for the gateway by the way)
Posted: Friday 05 January 2018 5:38
by farhanito
grunkan wrote: Wednesday 03 January 2018 20:26
ah, my bad.
the gateway IP has changed. i thought i already reserved an IP for it.
funny how all sensors and switches are still working fine with wrong gateway IP.
thanks
Posted: Friday 05 January 2018 10:13
by ChopCZ
mvveelen wrote: Thursday 04 January 2018 20:35
as far as I know, the Aqara version does not support Long Click.
Only the previous version supports that.
Posted: Friday 05 January 2018 12:23
by DAVIZINHO
ChopCZ wrote: Friday 05 January 2018 10:13
correct!
Posted: Friday 05 January 2018 18:29
by mvveelen
Ah, no need to search any further then
Posted: Saturday 06 January 2018 16:28
by mvveelen
Maybe I've taken a wrong turn somewhere, but I'm playing with the custom sounds of the Gateway, but I can't seem to play it using Domoticz.
I added a custom sound and I think it might me 10001. In the past I played with these sounds too, so it could easily be 10005 or something. So I added the slider and tested all sounds through 10009: nothing.
Should I add some extra choices to the "Xiaomi Gateway Doorbell" switch? It then reads values 50,60,etc. So that's not what I'm looking for, right?
What am I forgetting?
Posted: Saturday 06 January 2018 20:03
by chatjozef
There is an uservariabele, when you changed it to 10003 pr higher, that sound Will be played
Take a look at the wiki page:
https://www.domoticz.com/wiki/Xiaomi_Gateway_(Aqara)
Posted: Saturday 06 January 2018 22:08
by mvveelen
As I mentioned, I tried 10001 - 10009, nothing to hear. Do I have to add something somewhere?
2018-01-06 22:16:13.831 LUA: Xiaomi Gateway will play sound stored on bank 10003
2018-01-06 22:16:13.832 EventSystem: Script event triggered: Xiaomimp3
2018-01-06 22:16:14.033 (Xiaomi GW) Light/Switch (Xiaomi Gateway MP3)
Nothing....
Edit:
10019 did the trick.....didn't realise that I added s much sounds in the past
