- mvveelen
Aaaaaaaand it stopped updating (the LUX from the gateway) after updating to V3.8701
Wondering why nobody knows if this will be fixed or not. Has there already been issued a (bug)report for this?
RPi3b+/RFXCOM rfxtrx433E/Shelly/Xiaomi Gateway/Philips HUE Lights/Atag Zone One/2 SunnyBoy inverters/AirconWithMe/P1 smartmeter/Domoticz latest Beta
- Domoticz version: v4.11307
- Domoticz version: 4.10538
I've also ordered them at several ali suppliers, no issue here
- Domoticz version: 4.11333
Hi, there a
is promo code for Original Xiaomi Aqara Air Conditioning Companion
https://www.gearbest.com/living-applian ... 16094.html
I'm reading the thread now, but the promo can end quickly.
So my question is - will this gateway work as the second one with Domoticz, or not?
_______________
- Dell FX-160 / Ubuntu 16.04
- RFLink 433Mhz / NRF 2.4GHz
- 2x Xiaomi Gateway
- different species of ESP8266
- 2x Xiaomi Gateway
hello,
I have a problem with a "door_contact" switch.
The icon in the switches secction is correct => a open door when the door is open and a door closed when is closed.
The problem is in the "floorplan section" ==> when the door is closed the icon is "a door open".
Someone have this problem too???
thanks a lot!
thanks a lot!
Remove ref!mayyam wrote:Hi, there a
https://www.gearbest.com/living-applian ... tml?wid=21
Last edited by kluczus on Thursday 09 November 2017 16:07, edited 1 time in total.
RPi2 + sonoff + 433MHz + Xiaomi Gateway + EQ-3 MAX!
Sorry, You right.
_______________
- 2x Xiaomi Gateway
- 2x Xiaomi Gateway
Hello, for the second time this year my gateway got partially stuck :
- some random sensors are seen "not connected" in mi home
- almost no data is sent to domoticz.
The only solution I found was power off/power on. This is very annoying as this gateway is managing critical features in my home. I don't even know how to detect such state as the gateway keeps responding to a ping.
Is it a known bug?
Is it a known bug?
- mvveelen
How big is the distance between de gateway and the other devices? Perhaps this is the reason why it's not updating constantly.
- mvveelen
Three days later.....and the LUX of the gateway registered a LUX value again. What is going on...?
I have the same issue.DAVIZINHO wrote: ↑Thursday 09 November 2017 15:57 hello,
thanks a lot!
I've open a github issue: https://github.com/domoticz/domoticz/issues/1934
I haven't took time to troubleshoot this issue yet.corbin wrote: ↑Friday 06 October 2017 22:32Commands are not sent multicast, they are sent direct to the IP of the gateway. Multiple gateways should make no difference to this, regardless of if the additional gateway is configured in Domoticz. The correct key should be returned by matching the IP address of the gateway you have configured in Domoticz, so don't know why you are having this problem.chatainsim wrote: ↑Thursday 05 October 2017 10:21 If I understand correctly, you send order to the gateway through multicast ?
Do you have some clue on how to troubleshoot this ?
Anyone here who can recommend a realtime flat adapter for a Chinese to EU powerplug?
Is it really so that all Xiaomi wall switches are just "toggle" switches and there are no switches with separate on/off available?
- Domoticz version: lastbeta
I'm happy with this one:
http://www.skross.com/en/product/98/cou ... urope.html
Bought it via amazon.de (bol.com sells it also)
Synology DS716+. Domotica devices (on about 30): KaKu (and other 433MHz devices), Z-Wave, Mi-Light, Xiaomi.
i have 3 of this, and very usefull and quality!.digimate wrote: ↑Sunday 12 November 2017 6:24I'm happy with this one:
The problem?. the price, is expensive
- sincze
- Domoticz version: 2024.4
Very nice. Maybe with these items I can use the Xiaomi Smartplug as well without it being sticking out of the wall
However with tha adapter price tag of around 10 euro's .... the Neo Cool Smartplug Can compete with it as well priced at € 16- €20 euro's
At least it will plug the Gateway much nicer against the wall I think.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- Domoticz version: BETA
mmm is there perhaps a solution for the battery notification....
Only the xiaomi give a low battery warning..
And also when i set a new battery in the devices...
Last year found these, ive installed 6 of them and working since Jan. Very flat and way cheaper (with shipping around $2 a piece)sincze wrote:Very nice. Maybe with these items I can use the Xiaomi Smartplug as well without it being sticking out of the wall![]()
https://www.ebay.com/itm/EU-3-Round-Pin ... 1737610742
