levynger
Post by levynger »
@corbin,
new code doesnt deal with ctrl_ln* anymore ? (so it seems..)
i have only ctrl_ln1, so this is the only one i can help with testing .. with the former code, it works pretty well though.
Xiami added Power Consumtiopn (Watt) , however i couldnt find any refernece in message for that, only volttage..
2017-07-18 06:55:31.685 {"cmd":"heartbeat","model":"ctrl_ln1","sid":"158d00014ab142","short_id":13820,"data":"{\"voltage\":3600,\"channel_0\":\"on\"}"}
warmaniac
Post by warmaniac »
Hi there . After update of gateway FW I can see in domotocz logs my aqara magnet / door sensor , will be some update of beta domoticz available soon ? I compiled official beta today, but I still can't see it in new devices
2017-07-18 10:57:51.033 {"cmd":"report","model":"sensor_magnet.aq2","sid":"158d00016c402b","short_id":30460,"data":"{\"status\":\"open\"}"}
2017-07-18 10:57:53.485 XiaomiGateway: unhandled model: sensor_magnet.aq2
2017-07-18 10:57:53.485 {"cmd":"report","model":"sensor_magnet.aq2","sid":"158d00016c402b","short_id":30460,"data":"{\"status\":\"close\"}"}
chatainsim
Domoticz version: v4.11307
Post by chatainsim »
I have some strange logs in Domoticz :
2017-07-18 17:16:11.336 XiaomiGateway: unknown cmd received: read
2017-07-18 17:16:11.336 {"cmd": "read", "sid": "158d00015e9683"}
2017-07-18 17:16:11.336 {"cmd": "read", "sid": "158d0001a64ef5"}
2017-07-18 17:16:11.336 {"cmd": "read", "sid": "158d00012a42ca"}
2017-07-18 17:16:11.336 {"cmd": "read", "sid": "158d00015a8d79"}
2017-07-18 17:16:11.337 XiaomiGateway: unknown cmd received: read
2017-07-18 17:16:11.337 {"cmd": "read", "sid": "158d000182ec9e"}
Do you know what is it ?
chatainsim
theo69 wrote:
chatainsim wrote: I tried but it failed.
I will try again later. Thanks
The learning button is on the side (not the small hole on top)
Yes, I've tried that and on the Mi Home app I have something that let me thing button is added but it failed.
theo69
Domoticz version: la. beta
Post by theo69 »
chatainsim wrote: The learning button is on the side (not the small hole on top)
Strange, mine is added and working with automation within the Mi Home app
Love my Xiaomi Gateway in connection with homebridge and domoticz on my PI3
Xiaomi Gateway Domoticz Wiki
booster
Post by booster »
I've got a Xiaomi temp + humidity sensor, and was hoping I could use the humidity value in blockly to trigger the ventilator based on its value.
however, the humidity value doesn't seem to be populated...instead I now see a value 3 for some reason.
same happens with another sensor...Is there a way to get the real humidity value in my blockly?
hope the screendumps help to understand the issue
ok on the dashboard
here it says temp+hum+3... humidity is loaded with value 3 and not 67
Connected to:
-Pi3; Aeon Labs Z-Stick; Fibaro Switches, Roller Shutter and Motion Sensors; Qubino Dimmers; P1 Port + Youless, MiLight; HUE Bridge; Forest shuttle Z-Wave; RFLink + KAKU; Voltcraft CO20; Everspring floodsensors; GreenWave PN-6; NEO Sensors
warmaniac
Post by warmaniac »
now I can see logs of Aqara temperature/humidity/pressure sensor !
2017-07-20 14:10:54.391 XiaomiGateway: unhandled model: weather.v1
2017-07-20 14:10:54.392 {"cmd":"report","model":"weather.v1","sid":"158d00017200ff","short_id":26405,"data":"{\"temperature\":\"2577\"}"}
2017-07-20 14:10:54.403 XiaomiGateway: unhandled model: weather.v1
2017-07-20 14:10:54.403 {"cmd":"report","model":"weather.v1","sid":"158d00017200ff","short_id":26405,"data":"{\"humidity\":\"5625\"}"}
2017-07-20 14:10:54.424 XiaomiGateway: unhandled model: weather.v1
2017-07-20 14:10:54.424 {"cmd":"report","model":"weather.v1","sid":"158d00017200ff","short_id":26405,"data":"{\"pressure\":\"97046\"}"}
2017-07-20 14:10:54.435 XiaomiGateway: unhandled model: weather.v1
I think pressure must be calculated in domoticz by the height above sea level , but it is positive that Xiaomi fix it finally , hope it will be soon implemented in Domoticz :)
ben53252642
Post by ben53252642 »
After using Xiaomi Gateway successfully with Domoticz for about 2 -3 months, one day recently I found my gateway had stopped working and was flashing yellow. Couldn't see it on the network or broadcasting it's setup wifi SSID after power cycling it, I ended up doing a hard reset, this is where it gets awesome...
I named it the same as it was before during the setup, the app restored all device associations to the Gateway, the only thing I had to do was re-enable "local area network communication protocol", which after doing so my Xiaomi devices attached to the Gateway started working in Domoticz again. Needless to say I am very impressed! Really wish Z-Wave had such easy backup / restore functionality.
doxikus
Post by doxikus »
Does anybody have info when support for new aqara temp sensor will be merged in official beta!?
theo69
Post by theo69 »
doxikus wrote:Hi,
Waiting also for the merge for the neutral line Switches :-(
chatainsim
theo69 wrote:
doxikus wrote:Hi,
Merge is here : https://github.com/domoticz/domoticz/co ... e1ab829e55 :)
Update and compile your Domoticz !
Thanks @corbin !
benbammens
Post by benbammens »
chatainsim wrote:
theo69 wrote:
doxikus wrote:Hi,
Thanks @corbin !
I guess, just like me, he has no idea how to do this :)
I'm also waiting for the beta to implement this...
theo69
Post by theo69 »
benbammens wrote:
chatainsim wrote:
theo69 wrote: Waiting also for the merge for the neutral line Switches :-(
Thanks @corbin !
Looks like its in the beta now, updating now (first backup my SD) and will report back...
benbammens
Yes, it's working now!
theo69
Post by theo69 »
Just to report Aquara Square Button is working now.
However the single Wall Switch with Zero Line still shows:
2017-07-25 09:36:56.708 XiaomiGateway: unhandled model: ctrl_ln1
bublikOff
Post by bublikOff »
Any way to handle Aqara Smart Curtains?
theo69
Post by theo69 »
theo69 wrote:Just to report Aquara Square Button is working now.
However it shows "not supported" in HomeKit. With the mi-aqua homebrige plugin its working like a button!
jjnj
Post by jjnj »
bublikOff wrote:Any way to handle Aqara Smart Curtains?
+1 for the curtains
Verstuurd vanaf mijn LG-H870 met Tapatalk
bublikOff
Post by bublikOff »
---deleted---
Last edited by bublikOff on Thursday 03 August 2017 19:41, edited 1 time in total.
Revers59
Post by Revers59 »
please can you test circle wireless switch double click fonction with the last beta ?
I have a double click fonction on my script and all work well before some beta upgrade. Now the when I double click some time I have Simple click and some time I have long click
