Mi-Light / LimitlessLED / Applamp
redfirebrooks
Re: Mi-Light / LimitlessLED / Applamp
Post by redfirebrooks »
Hello
I got my bulbs RGB+CCT (FUT013) and the iBox v2 (the white square). What settings should I use now in Domoticz ? I've tried almost every combination without any result...
IP is fixed
what port should I use ? 8899 or 5987
bridge version should me v4/v5 or v6 ?
Version: 2024.1
Build Hash: 5279c8261
Compile Date: 2024-01-01 12:59:22
dzVents Version: 3.1.8
Python Version: 3.9.2
Raspbian Bullseye
Raspberry3B+
RFLINK R48.4
redfirebrooks
redfirebrooks wrote: Sunday 18 February 2018 1:39 Hello
IP is fixed
Did it.. I restarted from scratch
port 5987
v6
RGBWW
It works now...
Version: 2024.1
Raspbian Bullseye
Raspberry3B+
RFLINK R48.4
bullseye1977
Post by bullseye1977 »
Question here. I have the Ibox2 and GU10RGBCCT + Phone working correctly. Also the Box is configured correctly in Domoticz. I can control the on/off and colour. I have two sliders for brighness and white. But i cannot change the white temperature color. Is there something i miss or is there no support for controlling the RGB CCT (Cold White + Warm White)? not trough the website interface of trough the Payed Domoticz App
bullseye1977
redfirebrooks wrote: Sunday 18 February 2018 18:31
IP is fixed
port 5987
v6
RGBWW
It works now...
Can you controle the warm white and cold white trough domoticz?
keithclean
Post by keithclean »
Hi Guys, I got 2 short questions:
1) Which of the mi light wifi boxes/controllers are supported by domoticz? They come in v4, v6 and possibly other ones, I want to buy one that is supported by Domoticz.
2) Also what is the difference between the different versions? I like to know this so I can make a well informed decision
Thanks in advance! :D
Nautilus
Post by Nautilus »
keithclean wrote: Thursday 22 February 2018 20:27 Hi Guys, I got 2 short questions:
I think there's currently only iBox1 and iBox2 available: https://www.futlight.com/productlist.aspx?typeid=125 The difference between these is that iBox1 also has an internal RGBW light. You might find the older v5 or v4 bridges on Aliexpress or eBay and even though they are also compatible with Domoticz there isn't any reason for buiyng them. They don't have as good support for the new light bulbs and price probably isn't any cheaper either.
elythomaslumber
Domoticz version: 2023.1
Post by elythomaslumber »
This is a very old one, but works and seems to be still available:
https://www.geeektech.com/en/mi-light-m ... oller.html
If you think about ordering there I would ask if you realy will get exactly this item. Also there is a risk that the SW inside is not compatible but seen from the label it is exactly what I'm using since many years.
Nautilus
Post by Nautilus »
elythomaslumber wrote: Friday 23 February 2018 8:04 This is a very old one, but works and seems to be still available:
Yes, but as v6 is supported by Domoticz and you can get one for ~15€ shipped (e.g. from Aliexpress) then what would be the reason to get this version? Original question was "I want to buy one that is supported by Domoticz" :)
FunFair
Post by FunFair »
I just got my new Ibox2 wifi box (v6) to control my CCT lights. But I wanted to use my DualWhite lamps aswell.
But it seems domoticz can't control them with the v6 bridge, even though the v4 bridgeworked perfectly. The Milight 3.0 android app can control the DualWhite lamps fine (after finding out how to in the horrible app).
I found out from here: https://github.com/domoticz/domoticz/bl ... itless.cpp
That at line 17 it states: // Todo: Kelvin slider & WW/CW type
Does anyone have any idea when this function is coming? or is development stopped for the dualwhite lamps?
For now I have to settle to use both the v4 and v6 bridge te control all my lights as a workaround. But I'd rather only use 1 bridge.
tontze
Domoticz version: Beta Ch
Post by tontze »
My milight in beta domoticz, has sliders but not in correct place:
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
poudenes
Domoticz version: 3.8993
Post by poudenes »
tontze wrote: Sunday 11 March 2018 19:07 My milight in beta domoticz, has sliders but not in correct place:
Also in default theme? I don't have this (use default theme)
tontze
Post by tontze »
poudenes wrote: Sunday 11 March 2018 22:09
Yes. Themes dont bring extra features to devices.
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
poudenes
Post by poudenes »
Clear cache and check again
Verzonden vanaf mijn iPhone met Tapatalk Pro
tontze
Post by tontze »
If you are referring to my post, cache clearing doesnt help.
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
poudenes
Post by poudenes »
strange. Because i don't have the problem at all:
tontze
Post by tontze »
Are you in latest beta, or stable ?
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
poudenes
Post by poudenes »
tontze wrote: Tuesday 13 March 2018 14:15 Are you in latest beta, or stable ?
Latest beta, Updated 2 min ago to 3.9045
tontze
Post by tontze »
i did update too, now it seems to be in its place :)
EDIT:
Well that didnt last long, now they are off again ..
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
poudenes
Post by poudenes »
tontze wrote: Wednesday 14 March 2018 19:33 i did update too, now it seems to be in its place :)
EDIT:
Here now 3.9047 and have both white and brightness when click RGB logo and there gone when i press edit
ziaziung
Post by ziaziung »
Hi. I have RGBWW milight bulbs and Gu10 and RGBCCT milight bulbs working with a 2.4G wifi controller ibox (see picture below, please), a FUT089 Wireless LED Controller, a FUT96 remote.
I can control all RGBWW bulbs and GU10 with Domoticz but not the RGB+CCT bulbs.
Do you know if Domoticz can control RGB+CCT bulbs with the 2.4G wifi controller ibox or only ibox2 works with RGB+CCT?
Thankl you.
