Mi-Light / LimitlessLED / Applamp
redfirebrooks
Re: Mi-Light / LimitlessLED / Applamp
Hello
I got my bulbs RGB+CCT (FUT013) and the iBox v2 (the white square). What settings should I use now in Domoticz ? I've tried almost every combination without any result...
IP is fixed
what port should I use ? 8899 or 5987
bridge version should me v4/v5 or v6 ?
IP is fixed
Version: 2024.1
Build Hash: 5279c8261
Compile Date: 2024-01-01 12:59:22
dzVents Version: 3.1.8
Python Version: 3.9.2
Raspbian Bullseye
Raspberry3B+
RFLINK R48.4
Raspbian Bullseye
Raspberry3B+
RFLINK R48.4
redfirebrooks
Did it.. I restarted from scratchredfirebrooks wrote: Sunday 18 February 2018 1:39 Hello
IP is fixed
port 5987
v6
RGBWW
It works now...
Version: 2024.1
Raspbian Bullseye
Raspberry3B+
RFLINK R48.4
Raspbian Bullseye
Raspberry3B+
RFLINK R48.4
bullseye1977
Question here. I have the Ibox2 and GU10RGBCCT + Phone working correctly. Also the Box is configured correctly in Domoticz. I can control the on/off and colour. I have two sliders for brighness and white. But i cannot change the white temperature color. Is there something i miss or is there no support for controlling the RGB CCT (Cold White + Warm White)? not trough the website interface of trough the Payed Domoticz App
bullseye1977
Can you controle the warm white and cold white trough domoticz?redfirebrooks wrote: Sunday 18 February 2018 18:31Did it.. I restarted from scratchredfirebrooks wrote: Sunday 18 February 2018 1:39 Hello
IP is fixed
port 5987
v6
RGBWW
It works now...
keithclean
Hi Guys, I got 2 short questions:
1) Which of the mi light wifi boxes/controllers are supported by domoticz? They come in v4, v6 and possibly other ones, I want to buy one that is supported by Domoticz.
2) Also what is the difference between the different versions? I like to know this so I can make a well informed decision
Thanks in advance!
Thanks in advance!
Nautilus
I think there's currently only iBox1 and iBox2 available: https://www.futlight.com/productlist.aspx?typeid=125 The difference between these is that iBox1 also has an internal RGBW light. You might find the older v5 or v4 bridges on Aliexpress or eBay and even though they are also compatible with Domoticz there isn't any reason for buiyng them. They don't have as good support for the new light bulbs and price probably isn't any cheaper either.keithclean wrote: Thursday 22 February 2018 20:27 Hi Guys, I got 2 short questions:
Thanks in advance!![]()
- elythomaslumber
- Domoticz version: 2023.1
This is a very old one, but works and seems to be still available:
https://www.geeektech.com/en/mi-light-m ... oller.html
If you think about ordering there I would ask if you realy will get exactly this item. Also there is a risk that the SW inside is not compatible but seen from the label it is exactly what I'm using since many years.
Nautilus
Yes, but as v6 is supported by Domoticz and you can get one for ~15€ shipped (e.g. from Aliexpress) then what would be the reason to get this version? Original question was "I want to buy one that is supported by Domoticz"elythomaslumber wrote: Friday 23 February 2018 8:04 This is a very old one, but works and seems to be still available:
FunFair
I just got my new Ibox2 wifi box (v6) to control my CCT lights. But I wanted to use my DualWhite lamps aswell.
But it seems domoticz can't control them with the v6 bridge, even though the v4 bridgeworked perfectly. The Milight 3.0 android app can control the DualWhite lamps fine (after finding out how to in the horrible app).
I found out from here: https://github.com/domoticz/domoticz/bl ... itless.cpp
That at line 17 it states: // Todo: Kelvin slider & WW/CW type
Does anyone have any idea when this function is coming? or is development stopped for the dualwhite lamps?
For now I have to settle to use both the v4 and v6 bridge te control all my lights as a workaround. But I'd rather only use 1 bridge.
tontze
- Domoticz version: Beta Ch
My milight in beta domoticz, has sliders but not in correct place:
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
poudenes
- Domoticz version: 3.8993
Also in default theme? I don't have this (use default theme)tontze wrote: Sunday 11 March 2018 19:07 My milight in beta domoticz, has sliders but not in correct place:
tontze
Yes. Themes dont bring extra features to devices.
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
poudenes
Clear cache and check again
Verzonden vanaf mijn iPhone met Tapatalk Pro
tontze
If you are referring to my post, cache clearing doesnt help.
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
poudenes
strange. Because i don't have the problem at all:
tontze
Are you in latest beta, or stable ?
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
poudenes
Latest beta, Updated 2 min ago to 3.9045
tontze
i did update too, now it seems to be in its place
EDIT:
Well that didnt last long, now they are off again ..
EDIT:
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
poudenes
Here now 3.9047 and have both white and brightness when click RGB logo and there gone when i press edittontze wrote: Wednesday 14 March 2018 19:33 i did update too, now it seems to be in its place
EDIT:
ziaziung
Hi. I have RGBWW milight bulbs and Gu10 and RGBCCT milight bulbs working with a 2.4G wifi controller ibox (see picture below, please), a FUT089 Wireless LED Controller, a FUT96 remote.
I can control all RGBWW bulbs and GU10 with Domoticz but not the RGB+CCT bulbs.
Do you know if Domoticz can control RGB+CCT bulbs with the 2.4G wifi controller ibox or only ibox2 works with RGB+CCT?
Thankl you.
Thankl you.
- WiFiBox.jpg (99.14 KiB) Viewed 9711 times
