superelch
Post by superelch »
theo69 wrote:
theo69 wrote:Hi there I have a aqara http://www.gearbest.com/access-control/pp_626696.htmlpush button. I am trying to configure it to use on/off. However it shows on but I can not switch it off if i press the button again, tried delay on button off button on/off button nothing is working :-(
Is nobody using one of these wireless wall switches?
I use blocky as the switch dont send on / off...... just "click"
ist a button, not a switch
Raspberry / Domoticz (beta) / z-wave & xiaomi & habridge & 5x Alexa & google dots & milight & yeelight & harmony hub & Netatmo & ITTT & sonoff & Conbee II .... & a girlfriend who hates that stuff ...
Andae
Domoticz version: 3.7686
Post by Andae »
Hi all
I know the questions has been asked before, but I didn't find an answer.
I have a Xiaomi Cube, what are the movements for "alert" and "swing". All other options work fine.
Thanks to those who integrated the Xiaomi Gateway to Domotizc. Love it.
theo69
Domoticz version: la. beta
Post by theo69 »
Hi, thanks for the tipp! Could you show me you blocky screenshot, I tried but failed (new to this)
Love my Xiaomi Gateway in connection with homebridge and domoticz on my PI3
Xiaomi Gateway Domoticz Wiki
theo69
Post by theo69 »
theo69 wrote:Hi, thanks for the tipp! Could you show me you blocky screenshot, I tried but failed (new to this)
Sort of working Einzelschalter = Aqara Wireless Single Switch, Testschalter = Dummy Switch
quack3d
Post by quack3d »
This works nicely for my wireless buttons (the round ones). Click = 5% light. Double Click is 30 % and Long Click is 100 %. One click if lamp is on = turn off. I have Off Delay set to 1 second on the switch. Bryter - nattlampe = Switch, Soverom - Nattlampe = light.
2017-06-08 18_14_43-Domoticz.png (58.82 KiB) Viewed 3224 times
Mooseknuckle
Post by Mooseknuckle »
Hi there,
For those of you that are interested:
http://faire-ca-soi-meme.fr/news/2017/0 ... ticipatif/
A kickstarter project for a universal Zigbee gateway, a really nice way to get around the max of 30 devices from the xiaomi gateway.
RPI 3, Philips Hue,Toon Thermostat, Harmony Smart Control, Yeelights
Mysensors wifi gateway + sensors, RFXtrx433E, Kaku stuff, Xiaomi gateway + sensors
Domoticz controlled DIY ambilight, Selectplus chime, Mi-light led controller
deennoo
Re: RE: Re: RE: Re: Xiaomi Smart Home Suite (very cheap) compatibilty?
Post by deennoo »
SwordFish wrote:
deennoo wrote:
SwordFish wrote:
Sory for asking but is it on your blog already?
Cant find it.
A simple how to is online for yeelight bedside lamp & Domoticz : http://domo-attitude.fr/tuto-lampe-de-c ... -domoticz/
That in simple french word, google translate do a good job, i'll provied a how to on domoticz wiki next week.
If some one can help by provieding a Python Plugin this can be perfect
benbammens
Post by benbammens »
I just got an update for the gateway (1.4.1_147.0143) but still can not see the new temperature sensor...
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
deennoo wrote:
SwordFish wrote:
Cant find it.
Thanks will try it asap
deennoo
Post by deennoo »
benbammens wrote:I just got an update for the gateway (1.4.1_147.0143) but still can not see the new temperature sensor...
Same for me, i believe that until we can't see pictures of the square device they are not inclueded
benbammens
Probably. But the weird thing is, the sensors seems to connect when I do the pairing and in the Mi Home app it says "2 devices connected" under the gateway (I have 2 sensors). But they just don't show up...
Let's hope it gets fixed soon.
I find it weird they sell these sensors without support in the app...
warmaniac
Post by warmaniac »
There is update for xiaomi gateway today , let's test it if it was fixed up.
Odoslané z môjho iPhone cez Tapatalk
benbammens
warmaniac wrote:There is update for xiaomi gateway today , let's test it if it was fixed up.
It wasn't...
Swifty
Post by Swifty »
Swifty wrote:Does anyone have any suggestions for a (cheap) doorbell pusher that can be fitted outside? (in the British weather!) :)
My current doorbell (some Siemens junk) keeps failing, so I'd like to get a wireless button that is weather proof which I can integrate with Domoticz to trigger the Xiaomi gateways :D
At the risk of talking to myself - I have now found a solution for this :)
I took a spare Xiaomi door sensor, pulled it apart and wired a push button between GND and D0 pins, then fitted it all inside my old doorbell pusher casing.
Now I have a Xiaomi smart doorbell :D - The gateway rings when the doorbell is pushed (using a bit of blocky in Domoticz).
However, I've noticed that once the tune has finished playing on the gateway, the state of the 'Xiaomi Smart Gateway Doorbell' (the one where you pick a sound) does not go back to 'Off' state in Domoticz - is this normal?
theo69
Post by theo69 »
quack3d wrote:This works nicely for my wireless buttons (the round ones). Click = 5% light. Double Click is 30 % and Long Click is 100 %. One click if lamp is on = turn off. I have Off Delay set to 1 second on the switch. Bryter - nattlampe = Switch, Soverom - Nattlampe = light.
Great thanks for the tipp with, now i dont need the delay :lol:
theo69
Post by theo69 »
Did you try a off delay of 1 sec?
chatainsim
Domoticz version: v4.11307
Post by chatainsim »
You're not talking only to yourself :D
I'm interested about this. Can you post some pics of your setup?
Swifty
Post by Swifty »
@theo69 - I did think about that, but when I clicked the gateway doorbell sound device to 'Off' while the sound was playing it stopped the sound mid-playback.
I guess I could time the playback and set the off delay accordingly - but I figured the device should go back to 'off' once the sound finished by it's self?
@chatainsim - Sure, I will try and detail what I've done slightly more once I return home later.
deennoo
Post by deennoo »
Swifty wrote:@theo69 - I did think about that, but when I clicked the gateway doorbell sound device to 'Off' while the sound was playing it stopped the sound mid-playback.
Forget about blocky this doesn't fit to your need and it doesn't help to learn and understand how domoticz is powerfull...
You need to use a Lua script with :
if devicechanged = this command trigger your script only if the device ? changed of course ! he don't care about which state it was before (On off click long Click etc)
For a doorbell every body have his own way to ring, simple clikc, double click, long clik....
You start point have to be :
if devicechanged['xiaomiroundswitchbutton'] then
commendarray['Xiaomi doorbell'] = 'Set level : xx'
deennoo
Post by deennoo »
   commendarray['Xiaomi doorbell'] = 'Set level : xx'[/quote]
