corbin
Post by corbin »
StefanoA wrote: Ok, done
:D perfect!
corbin
Post by corbin »
warmaniac wrote: My other sensors works well, like human body , door, but this new not appearing in new devices , i can't see it at log file when added , already restarted xiaomi gateway try to compile new beta version of domoticz , nothing works , has anybody idea ? Thanks
I think it is need of a firmware update, probably not much longer to wait
benbammens
Post by benbammens »
warmaniac wrote:Hi there , i want to ask if somebody use the new temperature and humidity sensor link : http://m.gearbest.com/access-control/pp_626702.html
I have the same problem. The app says there are 2 sub devices (I have 2 temp sensors) but they do not show up in the list... Not in the app, not in Domoticz.
I have ordered 1 older sensor too see if that will work.
I read somewhere that the ios app does work OK with the new sensor. I'm not an Apple guy so can't test...
warmaniac
Post by warmaniac »
In ios app it is ok, showing both new temperature sensors correctly Image
Swifty
Post by Swifty »
@StefanoA - My suggestion was just a shot in the dark based on the trouble you described, so I'm glad it's working for you now :)
Does anyone have any suggestions for a (cheap) doorbell pusher that can be fitted outside? (in the British weather!) :)
My current doorbell (some Siemens junk) keeps failing, so I'd like to get a wireless button that is weather proof which I can integrate with Domoticz to trigger the Xiaomi gateways :D
benbammens
warmaniac wrote:In ios app it is ok, showing both new temperature sensors correctly
Lucky you. Hope they update the android app soon...
warmaniac
Post by warmaniac »
Im looking at wireshark output by UDP packets xiaomi gateway sending report only for gateway, motion and magnet sensors , that it must by failure of xiaomi gateway not domoticz .
deennoo
Post by deennoo »
Confirming m'y observation.
Xiaomi didn't update Gateway already for n'es design devices. App pictures doesn't show the Real one.
We have to wait from Xiaomi Update
http://domo-attitude.fr
doxikus
Post by doxikus »
Yep, I have the same problem, waiting for APP update :-(. There is a few video reviews and they said that new sensor type (aqara, cubed shape) works on iOS. Se we need to wait for update on Android.
theo69
Domoticz version: la. beta
Post by theo69 »
Hi i have the Dual Button Wireless Switch http://www.gearbest.com/alarm-systems/pp_610095.html in my domoticz it shows like:
however it shows not supported in homekit ;-(, need some help
Love my Xiaomi Gateway in connection with homebridge and domoticz on my PI3
Xiaomi Gateway Domoticz Wiki
theo69
Post by theo69 »
I also have the single wireless wall switch http://www.gearbest.com/access-control/pp_626696.html I can switch it on but not off (both homekit and domotics Dashboard, it shows like this:
I tried Selector and on/off, however its not working :-(
marcotrumpet
Post by marcotrumpet »
Try to set an off delay in switch settings to 1 sec
Inviato dal mio SM-G950F utilizzando Tapatalk
theo69
Post by theo69 »
Thanks, however if i do that i only can switch off ;-) and in homekit the switch goes on and 1 second later off
warmaniac
Post by warmaniac »
Android app update did not solve problem with domoticz visibility of device, hopeit solves gateway update
Odoslané z môjho iPhone cez Tapatalk
theo69
Post by theo69 »
Hi there I have a aqara http://www.gearbest.com/access-control/pp_626696.htmlpush button. I am trying to configure it to use on/off. However it shows on but I can not switch it off if i press the button again, tried delay on button off button on/off button nothing is working :-(
langoo
Post by langoo »
Hello
I got the new type of temperature/humidity sensor today from Gearbest. No problem getting the Gateway to show up in Domoticz. I can mate the sensors to the Gateway in the iOS-app but they never show up in Domoticz, anyone know why?
warmaniac
Post by warmaniac »
Hi , I wrote it before, it is because xiaomi gateway didn't updating status of sensor throught wifi , we must wait for update of gateway :(
langoo wrote:Hello
I got the new type of temperature/humidity sensor today from Gearbest. I can mate the sensors to the gateway but they never show up in Domoticz, anyone know why?
theo69
Post by theo69 »
theo69 wrote:Hi there I have a aqara http://www.gearbest.com/access-control/pp_626696.htmlpush button. I am trying to configure it to use on/off. However it shows on but I can not switch it off if i press the button again, tried delay on button off button on/off button nothing is working :-(
Is nobody using one of these wireless wall switches?
NuNca
Post by NuNca »
Hi, first of all thank you corbin for all the work you've done. i've been using this some time now and it works perfectly.
today i received a new aqara doorsensor (wanted to test it) http://www.gearbest.com/access-control/pp_626703.html
it can be connected to the gateway using the Mi-app (iOS) and it shows up as a normal doorsensor with log and everything.
But it isn't shown in the Domoticz log.
When you use it (removing the magnet from the base and putting it back) there isn't a message in the Domoticz log, but when it's connected to the gateway and you press pair button on the doorsensor you will get a message in the Domoticz log:
2017-06-07 22:33:38.235 XiaomiGateway: unhandled model:
2017-06-07 22:33:38.235 {"cmd":"heartbeat","model":"","sid":"158d0001a3e8f3","short_id":35014,"data":"{\"voltage\":3155}"}
when i look at the developers mode i can see the device as:
{ Model: lumi.sensor_magnet.aq2,did: lumi.158d0001a3e8f3,name: Test }
i don't know if it's possible to get this new doorsensor also added to Domoticz. Hopefully you can show your magic once again.
If you need anything else please let me know.
warmaniac
Post by warmaniac »
There is a problem with aqara ones devices because it not updating status via UDP from gateway, so it must be done from xiaomi , maybe after some firmware update, it can work correctly ,btw I try to watch it via wireshark but nothing shows at output from xiaomi gateway ,(have too door and temperature aqara devices) .
:x
