domoticz in synology as package! Available now.
Geoff332
Re: domoticz in synology as package! Available now.
hi there,
I'm trying to get Domoticz running on my DS214+ DSM5.1-5022 Update 3. I've got a RazBerry controller on a Pi I'm trying to connect to.
I've installed SynoZWave and then the Domoticz package. Both installed correctly and run properly (thanks for all the work setting up the package too!)
When I try and add hardware I can see RazBerry Z-Wave via LAN Interface (HTTP) - and this connects.
But I can't see any OpenZwave options.
Have a missed something along the way? Is it better to use OpenZWave for this set-up?
Thanks,
Geoff.
Thanks,
Geoff.
tehnoinstyle
- Domoticz version: 2.0.2276
Try to completely clean your web browser.Geoff332 wrote:hi there,
Thanks,
Geoff.
Syn DS3615xs DMS 5.1-5022U5(xpenology;Intel2700MUD;4GbRAM;2*3TbHDD->JBOD)
Syn DS3615xs DMS 5.2-5592(xpenology;asus p8-z68;I3;4GbRAM;6*2TbHDD->JBOD)
Z-Wave Aeon Labs Z-Stick S2->OpenRemote;Domoticz
Geoff332
Thanks.tehnoinstyle wrote:Try to completely clean your web browser.
I'm on Chrome. I did a cache clear and hard reload for the Domoticz domain - that's not fixed it.
I do have it working using HTTP - which does the job. I'm not sure if that's the best option.
tanebisse
I have the same problem as moonface.
I installed the Domoticz application on My Synology with the package automatically.
But I don't have any device type for my Aeon Lab Z stick on dropdownlist (see domoticz.jpg).
How can I install an Open Z wave pakage to recognize my device ?
- domoticz.jpg (157.7 KiB) Viewed 4617 times
mschut
- Domoticz version: V3.5613
Trying to upgrade manually, but it won't.
It should be a newer version, or not?
Eternity
@mschut
This helped me to sort out the version problems. I had to re-boot my Syno between reinstalls, otherwise it failed to install Domoticz!Decipher wrote:At some point the numbering of the SynoCommunity changed to more closely reflect that of the numbering in the Domoticz history file. The Syno sees 2.0.2276-6 to be an earlier version number than 2246-7.
I was not involved with this project at that time, it just is what it is. The simplest solution is to backup your Domoticz DB, uninstall and reinstall.
Synology DS218+
Homey controller
Z-Wave stuff (Fibaro / Aeotec / NEO Coolcam)
Zigbee stuff (Aqara)
HUE lights
Logitech Harmony Ultimate + Hub
IP camera's
Homey controller
HUE lights
IP camera's
mschut
Thanks, I was hoping to prevent this scenario.
Eternity
Well, at least I can confirm that it works. But yes, it does take about 5 minutes and 10 mouse clicksmschut wrote:Thanks, I was hoping to prevent this scenario.
Synology DS218+
Homey controller
HUE lights
IP camera's
Homey controller
HUE lights
IP camera's
mschut
I performed the upgrade by uninstalling and installing manually. The first thing my Synology said, was that I should upgrade the domoticz package. Guess what. It did the upgrade to the previous version.
Eternity
Yes, that is what happens (if you don't read)...
A couple of post up on this page I quoted Decipher and his explanation of the new version numbering.
Your Syno thinks it can upgrade Domoticz, but downgrades. This is due to the altered history numbering. Hopefully this will get sorted out soon. In the meantime you could upgrade mnanually (backup and restore your database) and ignore the update message.
Synology DS218+
Homey controller
HUE lights
IP camera's
Homey controller
HUE lights
IP camera's
Is there a pakkage for syn 210+ as well.
Is the qoriq?
Is the qoriq?
- LouiS22
FYI Synocommunity's database has been updated to .2284 - at least the cross compiler is updated to make 2284 versions.
thruhge
I don't get it, I'm trying to install domoticz from synocommunity, but it only shows this build:
v2.0.2112-5
Isn't this an old package?
When installed, I cant update.
v2.0.2112-5
ThinkPad
Same question here, i am interested in the most actual version for the Synology that is available.thruhge wrote:I don't get it, I'm trying to install domoticz from synocommunity, but it only shows this build:
v2.0.2112-5
I installed the package from the SynoCommunity repo through package center a few months ago and updated it to 2284 (which i shouldn't have done i read somewhere).
https://synocommunity.com/package/domoticz also still shows 2.0.2112-5
Eternity
When I try to make Domoticz update itself, the log shows:
2015-04-04 16:38:43.482 Executing script: /usr/local/domoticz/scripts/update_domoticz
2015-04-04 16:38:59.180 Error: Error executing script command (/usr/local/domoticz/scripts/update_domoticz /usr/local/domoticz/). returned: 32512
The second line is RED.
How can I solve this?
Synology DS218+
Homey controller
HUE lights
IP camera's
Homey controller
HUE lights
IP camera's
ThinkPad
Just installed domoticz_armada370-5.1_2.0.2362-6.spk from https://github.com/SynoCommunity/spksrc ... t-91066842 on my DS114 and so far seems to work fine.
jhsim
Also installed from github and 2.0.2362 is working here on a DS413 qoriq 5.1.
RFCXOM is fine, but having problems with USB permissions for a Z-Wave stick, the Domiticz log file includes this: Error, ERROR: Cannot open serial port /dev/ttyUSB1. Error code 13
I can just about find my way around with Telnet (although I'm not familiar with Linux), permissions are OK for the port with RFXCOM plugged in:
DiskStation> ls -l /dev/ttyUSB0
crwxrwxrwx 1 root root 188, 0 Apr 10 15:44 /dev/ttyUSB0
But not OK for the Z-Wave port:
DiskStation> ls -l /dev/ttyUSB1
crw------- 1 root root 188, 1 Apr 10 14:44 /dev/ttyUSB1
How can I change the permissions for /dev/ttyUSB1?
- Doume
- Domoticz version: 8038
chmod 777 /dev/ttyUSB1
jhsim
Apparently not
DiskStation> chmod 777 /dev/ttyUSB1
chmod: /dev/ttyUSB1: Operation not permitted
- Doume
You can only do that if your telnet session is 'root' itself....
