Dashticz - Feature Requests
Locked
Derik
Re: Dashticz - Feature Requests
Post by Derik »
option to change the standby screen....
gielie
Domoticz version: latest β
Post by gielie »
gielie wrote:Is it possible to create buttons instead a dropdown menu.
Id like to bump this idea up.
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
Derik
Post by Derik »
A time setting between the device is going in to standby.
Day time no standby
Night always standby
jjnj
Post by jjnj »
I would like to ask for the following feature:
Turn back to the main screen when Dashticz is in the standby screen when a switch is turned on.
This means I can do the following:
With the app motion sensor and tasker you can use the frontcamera of the tablet displaying Dashticz to switch on a certain switch when motion is detected.
So when you approach Dashticz the screen will switch to the normal mode. A similar approach like the Nest for example.
blacksn0w
Post by blacksn0w »
jjnj wrote:I would like to ask for the following feature:
So you want to turn on the screen when there is motion in front of the tablet?
I've got another solution for this problem, i'm using http://www.ozerov.de/fully-kiosk-browser/ which got the feature motion detection.
The screen is off in standard, but the camera is still looking for motion.
If detected, the screen gets on, and will stay there until the motion is gone and 20s are over.
This might fit your needs better than doing this with 3 apps, sending data to domoticz, get info back and turn the screen on :lol:
jjnj
Post by jjnj »
This might fit your needs better than doing this with 3 apps, sending data to domoticz, get info back and turn the screen on Image
I want to turn the screen on, but from the standby screen of dashticz to the main screen. So the screen of the tablet itself will stay on, it just switching between screen states in dashticz.
krizzz
Post by krizzz »
So for me that is exactly what blacksnow is saying. Only his screen comes on from being off and not stand-by as you are requesting. For me the method of blacksnow is easier so it seems!
jjnj
Post by jjnj »
krizzz wrote:
jjnj wrote:
blacksn0w wrote: So you want to turn on the screen when there is motion in front of the tablet?
That method is endeed easier but doesn't allow you to use the standby screen of Dashticz and just completely turns of the screen.
krizzz
Post by krizzz »
jjnj wrote:
krizzz wrote:
jjnj wrote: I want to turn the screen on, but from the standby screen of dashticz to the main screen. So the screen of the tablet itself will stay on, it just switching between screen states in dashticz.
True! But when you want to activate the normal Dashticz dashboard when coming closer to the tablet. You will never see the stand-by screen itself because it will always switch to regular one coming closerImage
pmalvino
Post by pmalvino »
[*]hello and thank's every one for the help.
My feature request if it is possible to create the possibility to make a graph with the option of method 0 or method 1.
i explain, i want to place in screen1 a graph with my Instantaneous consumption, but i can only make a graph with the energy.
Method=1 power
when i call:
http://192.168.1.146:8080/json.htm?type=graph&sensor=counter&idx=27&range=day&method=1&jsoncallback=?
domoticz response:
var data={
   "ValueQuantity" : "",
   "ValueUnits" : "",
   "method" : 1,
   "result" : [
         "d" : "2017-06-09 10:10",
         "v" : "273.000"
         "d" : "2017-06-09 10:15",
         "v" : "275.000"
         "d" : "2017-06-09 10:20",
         "v" : "266.000"
         "d" : "2017-06-09 10:25",
         "v" : "294.000"
         "d" : "2017-06-09 10:30",
         "v" : "259.000"
         "d" : "2017-06-09 10:35",
         "v" : "264.000"
         "d" : "2017-06-09 10:40",
         "v" : "271.000"
         "d" : "2017-06-09 10:45",
         "v" : "264.000"
         "d" : "2017-06-09 10:50",
         "v" : "241.000"
         "d" : "2017-06-09 10:55",
         "v" : "273.000"
         "d" : "2017-06-09 10:00",
         "eu" : "21.000"
         "d" : "2017-06-09 11:00",
         "v" : "282.000"
         "d" : "2017-06-09 11:05",
         "v" : "271.000"
         "d" : "2017-06-09 11:10",
         "v" : "248.000"
         "d" : "2017-06-09 11:15",
         "v" : "271.000"
         "d" : "2017-06-09 11:20",
         "v" : "271.000"
         "d" : "2017-06-09 11:25",
         "v" : "259.000"
         "d" : "2017-06-09 11:30",
         "v" : "262.000"
         "d" : "2017-06-09 11:35",
         "v" : "289.000"
         "d" : "2017-06-09 11:40",
         "v" : "271.000"
         "d" : "2017-06-09 11:45",
         "v" : "269.000"
         "d" : "2017-06-09 11:50",
         "v" : "273.000"
         "d" : "2017-06-09 11:55",
         "v" : "271.000"
         "eu" : "0.000"
         "d" : "2017-06-09 12:00",
         "v" : "248.000"
         "d" : "2017-06-09 12:05",
         "v" : "269.000"
         "d" : "2017-06-09 12:10",
         "v" : "266.000"
         "d" : "2017-06-09 12:15",
         "v" : "269.000"
         "d" : "2017-06-09 12:20",
         "v" : "250.000"
         "d" : "2017-06-09 12:25",
         "v" : "243.000"
         "d" : "2017-06-09 12:30",
         "v" : "259.000"
         "d" : "2017-06-09 12:35",
         "v" : "262.000"
         "d" : "2017-06-09 12:40",
         "v" : "259.000"
         "d" : "2017-06-09 12:45",
         "v" : "294.000"
         "d" : "2017-06-09 12:50",
         "v" : "269.000"
         "d" : "2017-06-09 12:55",
         "v" : "271.000"
         "eu" : "0.000"
         "d" : "2017-06-09 13:00",
         "v" : "266.000"
         "d" : "2017-06-09 13:05",
         "v" : "266.000"
         "d" : "2017-06-09 13:10",
         "v" : "246.000"
         "d" : "2017-06-09 13:15",
         "v" : "266.000"
         "d" : "2017-06-09 13:20",
         "v" : "271.000"
         "d" : "2017-06-09 13:25",
         "v" : "269.000"
         "d" : "2017-06-09 13:30",
         "v" : "271.000"
         "d" : "2017-06-09 13:35",
         "v" : "285.000"
         "d" : "2017-06-09 13:40",
         "v" : "257.000"
         "d" : "2017-06-09 13:45",
         "v" : "252.000"
         "d" : "2017-06-09 13:50",
         "v" : "255.000"
         "d" : "2017-06-09 13:55",
         "v" : "241.000"
         "eu" : "0.000"
         "d" : "2017-06-09 14:00",
         "v" : "271.000"
         "d" : "2017-06-09 14:05",
         "v" : "269.000"
         "d" : "2017-06-09 14:10",
         "v" : "269.000"
         "d" : "2017-06-09 14:15",
         "v" : "271.000"
         "d" : "2017-06-09 14:20",
         "v" : "239.000"
         "d" : "2017-06-09 14:25",
         "v" : "271.000"
         "d" : "2017-06-09 14:30",
         "v" : "271.000"
         "d" : "2017-06-09 14:35",
         "v" : "271.000"
         "d" : "2017-06-09 14:40",
         "v" : "294.000"
         "d" : "2017-06-09 14:45",
         "v" : "292.000"
         "d" : "2017-06-09 14:50",
         "v" : "259.000"
         "d" : "2017-06-09 14:55",
         "v" : "257.000"
         "eu" : "0.000"
         "d" : "2017-06-09 15:00",
         "v" : "271.000"
         "d" : "2017-06-09 15:05",
         "v" : "252.000"
         "d" : "2017-06-09 15:10",
         "v" : "271.000"
         "d" : "2017-06-09 15:15",
         "v" : "271.000"
         "d" : "2017-06-09 15:20",
         "v" : "271.000"
         "d" : "2017-06-09 15:25",
         "v" : "255.000"
         "d" : "2017-06-09 15:30",
         "v" : "241.000"
         "d" : "2017-06-09 15:35",
         "v" : "271.000"
         "d" : "2017-06-09 15:40",
         "v" : "271.000"
         "d" : "2017-06-09 15:45",
         "v" : "259.000"
         "d" : "2017-06-09 15:50",
         "v" : "289.000"
         "d" : "2017-06-09 15:55",
         "v" : "259.000"
         "eu" : "0.000"
         "d" : "2017-06-09 16:00",
         "v" : "257.000"
         "d" : "2017-06-09 16:05",
         "v" : "269.000"
         "d" : "2017-06-09 16:10",
         "v" : "243.000"
         "d" : "2017-06-09 16:15",
         "v" : "241.000"
         "d" : "2017-06-09 16:20",
         "v" : "271.000"
         "d" : "2017-06-09 16:25",
         "v" : "273.000"
         "d" : "2017-06-09 16:30",
         "v" : "275.000"
         "d" : "2017-06-09 16:35",
         "v" : "246.000"
         "d" : "2017-06-09 16:40",
         "v" : "271.000"
         "d" : "2017-06-09 16:45",
         "v" : "273.000"
         "d" : "2017-06-09 16:50",
         "v" : "269.000"
         "d" : "2017-06-09 16:55",
         "v" : "289.000"
         "eu" : "0.000"
         "d" : "2017-06-09 17:00",
         "v" : "257.000"
         "d" : "2017-06-09 17:05",
         "v" : "379.000"
         "d" : "2017-06-09 17:10",
         "v" : "374.000"
         "d" : "2017-06-09 17:15",
         "v" : "372.000"
         "d" : "2017-06-09 17:20",
         "v" : "241.000"
         "d" : "2017-06-09 17:25",
         "v" : "269.000"
         "d" : "2017-06-09 17:30",
         "v" : "264.000"
         "d" : "2017-06-09 17:35",
         "v" : "269.000"
         "d" : "2017-06-09 17:40",
         "v" : "239.000"
         "d" : "2017-06-09 17:45",
         "v" : "266.000"
         "d" : "2017-06-09 17:50",
         "v" : "257.000"
         "d" : "2017-06-09 17:55",
         "v" : "285.000"
         "eu" : "85.000"
         "d" : "2017-06-09 18:00",
         "v" : "303.000"
         "d" : "2017-06-09 18:05",
         "v" : "282.000"
         "d" : "2017-06-09 18:10",
         "v" : "597.000"
         "d" : "2017-06-09 18:15",
         "v" : "607.000"
         "d" : "2017-06-09 18:20",
         "v" : "625.000"
         "d" : "2017-06-09 18:25",
         "v" : "471.000"
         "d" : "2017-06-09 18:30",
         "v" : "588.000"
         "d" : "2017-06-09 18:35",
         "v" : "561.000"
         "d" : "2017-06-09 18:40",
         "v" : "616.000"
         "d" : "2017-06-09 18:45",
         "v" : "505.000"
         "d" : "2017-06-09 18:50",
         "v" : "289.000"
         "d" : "2017-06-09 18:55",
         "v" : "423.000"
         "eu" : "246.000"
         "d" : "2017-06-09 19:00",
         "v" : "427.000"
         "d" : "2017-06-09 19:05",
         "v" : "411.000"
         "d" : "2017-06-09 19:10",
         "v" : "345.000"
         "d" : "2017-06-09 19:15",
         "v" : "411.000"
         "d" : "2017-06-09 19:20",
         "v" : "409.000"
         "d" : "2017-06-09 19:25",
         "v" : "407.000"
         "d" : "2017-06-09 19:30",
         "v" : "416.000"
         "d" : "2017-06-09 19:35",
         "v" : "418.000"
         "d" : "2017-06-09 19:40",
         "v" : "386.000"
         "d" : "2017-06-09 19:45",
         "v" : "423.000"
         "d" : "2017-06-09 19:50",
         "v" : "370.000"
         "d" : "2017-06-09 19:55",
         "v" : "388.000"
         "eu" : "0.000"
         "d" : "2017-06-09 20:00",
         "v" : "420.000"
         "d" : "2017-06-09 20:05",
         "v" : "423.000"
         "d" : "2017-06-09 20:10",
         "v" : "407.000"
         "d" : "2017-06-09 20:15",
         "v" : "358.000"
         "d" : "2017-06-09 20:20",
         "v" : "407.000"
         "d" : "2017-06-09 20:25",
         "v" : "409.000"
         "d" : "2017-06-09 20:30",
         "v" : "381.000"
         "d" : "2017-06-09 20:35",
         "v" : "471.000"
         "d" : "2017-06-09 20:40",
         "v" : "489.000"
         "d" : "2017-06-09 20:45",
         "v" : "460.000"
         "d" : "2017-06-09 20:50",
         "v" : "494.000"
         "d" : "2017-06-09 20:55",
         "v" : "492.000"
         "eu" : "0.000"
         "d" : "2017-06-09 21:00",
         "v" : "478.000"
         "d" : "2017-06-09 21:05",
         "v" : "473.000"
         "d" : "2017-06-09 21:10",
         "v" : "294.000"
         "d" : "2017-06-09 21:15",
         "v" : "294.000"
         "d" : "2017-06-09 21:20",
         "v" : "292.000"
         "d" : "2017-06-09 21:25",
         "v" : "278.000"
         "d" : "2017-06-09 21:30",
         "v" : "282.000"
         "d" : "2017-06-09 21:35",
         "v" : "289.000"
         "d" : "2017-06-09 21:40",
         "v" : "262.000"
         "d" : "2017-06-09 21:45",
         "v" : "294.000"
         "d" : "2017-06-09 21:50",
         "v" : "292.000"
         "d" : "2017-06-09 21:55",
         "v" : "294.000"
         "eu" : "0.000"
         "d" : "2017-06-09 22:00",
         "v" : "273.000"
         "d" : "2017-06-09 22:05",
         "v" : "262.000"
         "d" : "2017-06-09 22:10",
         "v" : "292.000"
         "d" : "2017-06-09 22:15",
         "v" : "292.000"
         "d" : "2017-06-09 22:20",
         "v" : "285.000"
         "d" : "2017-06-09 22:25",
         "v" : "292.000"
         "d" : "2017-06-09 22:30",
         "v" : "271.000"
         "d" : "2017-06-09 22:35",
         "v" : "278.000"
         "d" : "2017-06-09 22:40",
         "v" : "289.000"
         "d" : "2017-06-09 22:45",
         "v" : "264.000"
         "d" : "2017-06-09 22:50",
         "v" : "287.000"
         "d" : "2017-06-09 22:55",
         "v" : "289.000"
         "eu" : "0.000"
         "d" : "2017-06-09 23:00",
         "v" : "287.000"
         "d" : "2017-06-09 23:05",
         "v" : "278.000"
         "d" : "2017-06-09 23:10",
         "v" : "259.000"
         "d" : "2017-06-09 23:15",
         "v" : "287.000"
         "d" : "2017-06-09 23:20",
         "v" : "292.000"
         "d" : "2017-06-09 23:25",
         "v" : "278.000"
         "d" : "2017-06-09 23:30",
         "v" : "296.000"
         "d" : "2017-06-09 23:35",
         "v" : "273.000"
         "d" : "2017-06-09 23:40",
         "v" : "269.000"
         "d" : "2017-06-09 23:45",
         "v" : "292.000"
         "d" : "2017-06-09 23:50",
         "v" : "271.000"
         "eu" : "0.000"
         "d" : "2017-06-10 00:00",
         "v" : "294.000"
         "d" : "2017-06-10 00:05",
         "v" : "292.000"
         "d" : "2017-06-10 00:10",
         "v" : "478.000"
         "d" : "2017-06-10 00:15",
         "v" : "372.000"
         "d" : "2017-06-10 00:20",
         "v" : "331.000"
         "d" : "2017-06-10 00:25",
         "v" : "321.000"
         "d" : "2017-06-10 00:30",
         "v" : "315.000"
         "d" : "2017-06-10 00:35",
         "v" : "335.000"
         "d" : "2017-06-10 00:40",
         "v" : "289.000"
         "d" : "2017-06-10 00:45",
         "v" : "292.000"
         "d" : "2017-06-10 00:50",
         "v" : "289.000"
         "d" : "2017-06-10 00:55",
         "v" : "292.000"
         "eu" : "0.000"
         "d" : "2017-06-10 01:00",
         "v" : "266.000"
         "d" : "2017-06-10 01:05",
         "v" : "292.000"
         "d" : "2017-06-10 01:10",
         "v" : "294.000"
         "d" : "2017-06-10 01:15",
         "v" : "292.000"
         "d" : "2017-06-10 01:20",
         "v" : "275.000"
         "d" : "2017-06-10 01:25",
         "v" : "262.000"
         "d" : "2017-06-10 01:30",
         "v" : "275.000"
         "d" : "2017-06-10 01:35",
         "v" : "278.000"
         "d" : "2017-06-10 01:40",
         "v" : "278.000"
         "d" : "2017-06-10 01:45",
         "v" : "303.000"
         "d" : "2017-06-10 01:50",
         "v" : "294.000"
         "d" : "2017-06-10 01:55",
         "v" : "294.000"
         "eu" : "0.000"
         "d" : "2017-06-10 02:00",
         "v" : "292.000"
         "d" : "2017-06-10 02:05",
         "v" : "282.000"
         "d" : "2017-06-10 02:10",
         "v" : "262.000"
         "d" : "2017-06-10 02:15",
         "v" : "292.000"
         "d" : "2017-06-10 02:20",
         "v" : "292.000"
         "d" : "2017-06-10 02:25",
         "v" : "289.000"
         "d" : "2017-06-10 02:30",
         "v" : "266.000"
         "d" : "2017-06-10 02:35",
         "v" : "273.000"
         "d" : "2017-06-10 02:40",
         "v" : "278.000"
         "d" : "2017-06-10 02:45",
         "v" : "280.000"
         "d" : "2017-06-10 02:50",
         "v" : "273.000"
         "d" : "2017-06-10 02:55",
         "v" : "264.000"
         "eu" : "0.000"
         "d" : "2017-06-10 03:00",
         "v" : "296.000"
         "d" : "2017-06-10 03:05",
         "v" : "294.000"
         "d" : "2017-06-10 03:10",
         "v" : "292.000"
         "d" : "2017-06-10 03:15",
         "v" : "264.000"
         "d" : "2017-06-10 03:20",
         "v" : "296.000"
         "d" : "2017-06-10 03:25",
         "v" : "298.000"
         "d" : "2017-06-10 03:30",
         "v" : "296.000"
         "d" : "2017-06-10 03:35",
         "v" : "296.000"
         "d" : "2017-06-10 03:40",
         "v" : "296.000"
         "d" : "2017-06-10 03:45",
         "v" : "278.000"
         "d" : "2017-06-10 03:50",
         "v" : "280.000"
         "d" : "2017-06-10 03:55",
         "v" : "275.000"
         "eu" : "0.000"
         "d" : "2017-06-10 04:00",
         "v" : "273.000"
         "d" : "2017-06-10 04:05",
         "v" : "294.000"
         "d" : "2017-06-10 04:10",
         "v" : "296.000"
         "d" : "2017-06-10 04:15",
         "v" : "298.000"
         "d" : "2017-06-10 04:20",
         "v" : "294.000"
         "d" : "2017-06-10 04:25",
         "v" : "262.000"
         "d" : "2017-06-10 04:30",
         "v" : "296.000"
         "d" : "2017-06-10 04:35",
         "v" : "296.000"
         "d" : "2017-06-10 04:40",
         "v" : "294.000"
         "d" : "2017-06-10 04:45",
         "v" : "278.000"
         "d" : "2017-06-10 04:50",
         "v" : "296.000"
         "d" : "2017-06-10 04:55",
         "v" : "275.000"
         "eu" : "0.000"
         "d" : "2017-06-10 05:00",
         "v" : "271.000"
         "d" : "2017-06-10 05:05",
         "v" : "292.000"
         "d" : "2017-06-10 05:10",
         "v" : "266.000"
         "d" : "2017-06-10 05:15",
         "v" : "294.000"
         "d" : "2017-06-10 05:20",
         "v" : "294.000"
         "d" : "2017-06-10 05:25",
         "v" : "294.000"
         "d" : "2017-06-10 05:30",
         "v" : "294.000"
         "d" : "2017-06-10 05:35",
         "v" : "262.000"
         "d" : "2017-06-10 05:40",
         "v" : "296.000"
         "d" : "2017-06-10 05:45",
         "v" : "292.000"
         "d" : "2017-06-10 05:50",
         "v" : "273.000"
         "d" : "2017-06-10 05:55",
         "v" : "273.000"
         "eu" : "0.000"
         "d" : "2017-06-10 06:00",
         "v" : "289.000"
         "d" : "2017-06-10 06:05",
         "v" : "278.000"
         "d" : "2017-06-10 06:10",
         "v" : "296.000"
         "d" : "2017-06-10 06:15",
         "v" : "296.000"
         "d" : "2017-06-10 06:20",
         "v" : "266.000"
         "d" : "2017-06-10 06:25",
         "v" : "294.000"
         "d" : "2017-06-10 06:30",
         "v" : "292.000"
         "d" : "2017-06-10 06:35",
         "v" : "328.000"
         "d" : "2017-06-10 06:40",
         "v" : "331.000"
         "d" : "2017-06-10 06:45",
         "v" : "340.000"
         "d" : "2017-06-10 06:50",
         "v" : "377.000"
         "d" : "2017-06-10 06:55",
         "v" : "349.000"
         "eu" : "0.000"
         "d" : "2017-06-10 07:00",
         "v" : "354.000"
         "d" : "2017-06-10 07:05",
         "v" : "358.000"
         "d" : "2017-06-10 07:10",
         "v" : "361.000"
         "d" : "2017-06-10 07:15",
         "v" : "370.000"
         "d" : "2017-06-10 07:20",
         "v" : "370.000"
         "d" : "2017-06-10 07:25",
         "v" : "400.000"
         "d" : "2017-06-10 07:30",
         "v" : "2176.000"
         "d" : "2017-06-10 07:35",
         "v" : "2786.000"
         "d" : "2017-06-10 07:40",
         "v" : "2773.000"
         "d" : "2017-06-10 07:45",
         "v" : "2732.000"
         "d" : "2017-06-10 07:50",
         "v" : "809.000"
         "d" : "2017-06-10 07:55",
         "v" : "972.000"
         "eu" : "2161.000"
         "d" : "2017-06-10 08:00",
         "v" : "450.000"
         "d" : "2017-06-10 08:05",
         "v" : "441.000"
         "d" : "2017-06-10 08:10",
         "v" : "471.000"
         "d" : "2017-06-10 08:15",
         "v" : "625.000"
         "d" : "2017-06-10 08:20",
         "v" : "492.000"
         "d" : "2017-06-10 08:25",
         "v" : "510.000"
         "d" : "2017-06-10 08:30",
         "v" : "487.000"
         "d" : "2017-06-10 08:35",
         "v" : "489.000"
         "d" : "2017-06-10 08:40",
         "v" : "494.000"
         "d" : "2017-06-10 08:45",
         "v" : "462.000"
         "d" : "2017-06-10 08:50",
         "v" : "1282.000"
         "d" : "2017-06-10 08:55",
         "v" : "480.000"
         "eu" : "0.000"
         "d" : "2017-06-10 09:00",
         "v" : "480.000"
         "d" : "2017-06-10 09:05",
         "v" : "563.000"
         "d" : "2017-06-10 09:10",
         "v" : "478.000"
         "d" : "2017-06-10 09:15",
         "v" : "604.000"
         "d" : "2017-06-10 09:20",
         "v" : "494.000"
         "d" : "2017-06-10 09:25",
         "v" : "503.000"
         "d" : "2017-06-10 09:30",
         "v" : "473.000"
         "d" : "2017-06-10 09:35",
         "v" : "469.000"
         "d" : "2017-06-10 09:40",
         "v" : "499.000"
         "d" : "2017-06-10 09:45",
         "v" : "499.000"
         "d" : "2017-06-10 09:50",
         "v" : "768.000"
         "d" : "2017-06-10 09:55",
         "v" : "565.000"
         "eu" : "0.000"
         "d" : "2017-06-10 10:00",
         "v" : "531.000"
         "d" : "2017-06-10 10:05",
         "v" : "533.000"
         "eu" : "0.000"
         "d" : "2017-06-10 10:10",
         "v" : "508.000"
   "status" : "OK",
   "title" : "Graph counter day"
?(data);
for method=0 energy:
when i call:
http://192.168.1.146:8080/json.htm?type=graph&sensor=counter&idx=27&range=day&method=0&jsoncallback=?
domoticz response:
var data={
   "ValueUnits" : "",
   "method" : 0,
   "result" : [
         "v" : "48.000"
         "v" : "0.000"
         "v" : "90.000"
         "v" : "246.000"
         "v" : "0.000"
         "v" : "0.000"
         "v" : "0.000"
         "v" : "0.000"
         "v" : "0.000"
         "v" : "0.000"
         "v" : "0.000"
         "v" : "0.000"
         "v" : "0.000"
         "v" : "0.000"
         "v" : "0.000"
         "v" : "0.000"
         "v" : "2161.000"
         "v" : "0.000"
         "v" : "0.000"
         "v" : "0.000"
         "d" : "2017-06-10 11:00",
         "v" : "122.000"
         "d" : "2017-06-10 12:00",
         "v" : "0.000"
         "d" : "2017-06-10 13:00",
         "v" : "230.000"
         "d" : "2017-06-10 14:00",
         "v" : "0.000"
   "status" : "OK",
?(data);
the graph in domoticz is like this:
energy+power graph.PNG (60.57 KiB) Viewed 3708 times
in dasticz is like this:
dashticz graph.PNG (87.63 KiB) Viewed 3708 times
in CONFIG.js:
blocks['graph_27'] = {}
blocks['graph_27']['width'] = 5;
so, its possible to create a selection of method=1 (power) or method=0 (energy) or both to make a graph similar to domoticz?
I try to modify graph.js in the line:
url: _HOST_DOMOTICZ+'/json.htm?type=graph&sensor='+sensor+'&idx='+idx+'&range='+realrange+'&time='+new Date().getTime()+'&jsoncallback=?',
and modify to:
url: _HOST_DOMOTICZ+'/json.htm?type=graph&sensor='+sensor+'&idx='+idx+'&range='+realrange+'&method=1&time='+new Date().getTime()+'&jsoncallback=?',
but when i open the browser it pop up an error.
Thank you all
Sundown89
Domoticz version: 3.7708
Post by Sundown89 »
Hi!
I would like Spotify integration. I have multiroom audio using RPi's as Spotify Connect devices. See github here.
Currently I am using my android phone as the remote to control them. Would be nice to control the devices from the tablet on the wall through Dashticz.
Domoticz on Ubuntu 14.04
Dashticz V2
Pi-Hole
RFXCom
TapNL
Post by TapNL »
I would like to see a feature that you can specify / overrule the width of a block, on a different page.
Issue I have is that on one page the block needs to be a width of 12, on an other page the block needs to have width of 12.
freakshock
Post by freakshock »
Sundown89 wrote:Hi!
I would love this also. It would however probably make more sense to have the Spotify control integrated in Domoticz itself first. I have done some forum searches but cannot find this has been done so far. But I'm not the pro here :lol:
dutchdevil83
Post by dutchdevil83 »
First of all thankx for your hard work! Have everything up and running and will post some screenshots of my config so far. While playing with the right design for my power and gas usage graphs i discovered only morris.area is supported until now. Could it be possible to support also morris.line and morris.bar ? Also like to have more customization options for the graph.js module like line colors/font type/etc.
Hope someone with some spare time will work on this function. Keep up the good work!
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
1x GoodWe Solarpanels
2x FGSD-002 Smoke Detector
1x FGBS-001 Binaire Sensor (RFID lezer)
7x FGMS-001 Motion Sensor
3x ZW089 Verzonken Deursensor
7x NC Wallplug
&lots of KaKu stuff
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
htilburgs wrote:I meant like in the rss feed, etc..
But I like the feature as in the buttons, just the option icon: or image: in the variable.
example:
calendars.f1 = { maxitems: 5, title: 'F1 Calendar', icon: 'fa-calendar ',icalurl: 'https://calendar.google.com/calendar/ical/xx/basic.ics' }
or
calendars.f1 = { maxitems: 5, title: 'F1 Calendar', image: 'img/calendar.png',icalurl: 'https://calendar.google.com/calendar/ical/xx/basic.ics' }
Fixed in latest beta, add a image to the img-folder and use:
calendars.f1 = { maxitems: 5, title: 'F1 Calendar', [b]image: 'calendar.png'[/b],icalurl: 'https://calendar.google.com/calendar/ical/xx/basic.ics' }
So do not enter img/
htilburgs
Post by htilburgs »
Hi Rob, great work, thanks!
Looks great...!
Hardware:
htilburgs
Post by htilburgs »
Rob, one question. Is it possible to change the class of the calendar image?
Now is has class ICON and is it not quite possible to change format of location of the image.
Hardware:
robgeerts
Post by robgeerts »
htilburgs wrote:Rob, one question. Is it possible to change the class of the calendar image?
I've added this class in BETA: calendar_icon
htilburgs
Post by htilburgs »
Thnx! Will try it later this afternoon.
Hardware:
WaTTe
Domoticz version: 3.8153
Post by WaTTe »
Change the text of a temperature sensor depending on the measured temperature.
Eg a green color at 5 degrees an orange color at 15 a red at 25 etc.
Locked
