Dashticz - Feature Requests
Derik
- Domoticz version: BETA
Re: Dashticz - Feature Requests
option to change the standby screen....
- gielie
- Domoticz version: latest β
Id like to bump this idea up.gielie wrote:Is it possible to create buttons instead a dropdown menu.
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
Derik
A time setting between the device is going in to standby.
Day time no standby
Night always standby
Day time no standby
jjnj
I would like to ask for the following feature:
Turn back to the main screen when Dashticz is in the standby screen when a switch is turned on.
This means I can do the following:
With the app motion sensor and tasker you can use the frontcamera of the tablet displaying Dashticz to switch on a certain switch when motion is detected.
So when you approach Dashticz the screen will switch to the normal mode. A similar approach like the Nest for example.
blacksn0w
So you want to turn on the screen when there is motion in front of the tablet?jjnj wrote:I would like to ask for the following feature:
I've got another solution for this problem, i'm using http://www.ozerov.de/fully-kiosk-browser/ which got the feature motion detection.
The screen is off in standard, but the camera is still looking for motion.
If detected, the screen gets on, and will stay there until the motion is gone and 20s are over.
This might fit your needs better than doing this with 3 apps, sending data to domoticz, get info back and turn the screen on
jjnj
I want to turn the screen on, but from the standby screen of dashticz to the main screen. So the screen of the tablet itself will stay on, it just switching between screen states in dashticz.blacksn0w wrote:So you want to turn on the screen when there is motion in front of the tablet?jjnj wrote:I would like to ask for the following feature:
krizzz
So for me that is exactly what blacksnow is saying. Only his screen comes on from being off and not stand-by as you are requesting. For me the method of blacksnow is easier so it seems!jjnj wrote:I want to turn the screen on, but from the standby screen of dashticz to the main screen. So the screen of the tablet itself will stay on, it just switching between screen states in dashticz.blacksn0w wrote:So you want to turn on the screen when there is motion in front of the tablet?jjnj wrote:I would like to ask for the following feature:
jjnj
That method is endeed easier but doesn't allow you to use the standby screen of Dashticz and just completely turns of the screen.krizzz wrote:So for me that is exactly what blacksnow is saying. Only his screen comes on from being off and not stand-by as you are requesting. For me the method of blacksnow is easier so it seems!jjnj wrote:I want to turn the screen on, but from the standby screen of dashticz to the main screen. So the screen of the tablet itself will stay on, it just switching between screen states in dashticz.blacksn0w wrote: So you want to turn on the screen when there is motion in front of the tablet?
krizzz
True! But when you want to activate the normal Dashticz dashboard when coming closer to the tablet. You will never see the stand-by screen itself because it will always switch to regular one coming closerjjnj wrote:That method is endeed easier but doesn't allow you to use the standby screen of Dashticz and just completely turns of the screen.krizzz wrote:So for me that is exactly what blacksnow is saying. Only his screen comes on from being off and not stand-by as you are requesting. For me the method of blacksnow is easier so it seems!jjnj wrote: I want to turn the screen on, but from the standby screen of dashticz to the main screen. So the screen of the tablet itself will stay on, it just switching between screen states in dashticz.
pmalvino
[*]hello and thank's every one for the help.
My feature request if it is possible to create the possibility to make a graph with the option of method 0 or method 1.
i explain, i want to place in screen1 a graph with my Instantaneous consumption, but i can only make a graph with the energy.
Method=1 power
when i call:
domoticz response:
for method=0 energy:
when i call:
domoticz response:
the graph in domoticz is like this:
in dasticz is like this:
in CONFIG.js:
so, its possible to create a selection of method=1 (power) or method=0 (energy) or both to make a graph similar to domoticz?
I try to modify graph.js in the line:
and modify to:
but when i open the browser it pop up an error.
Thank you all
Method=1 power
when i call:
http://192.168.1.146:8080/json.htm?type=graph&sensor=counter&idx=27&range=day&method=1&jsoncallback=?
var data={
"ValueQuantity" : "",
"ValueUnits" : "",
"method" : 1,
"result" : [
"d" : "2017-06-09 10:10",
"v" : "273.000"
"d" : "2017-06-09 10:15",
"v" : "275.000"
"d" : "2017-06-09 10:20",
"v" : "266.000"
"d" : "2017-06-09 10:25",
"v" : "294.000"
"d" : "2017-06-09 10:30",
"v" : "259.000"
"d" : "2017-06-09 10:35",
"v" : "264.000"
"d" : "2017-06-09 10:40",
"v" : "271.000"
"d" : "2017-06-09 10:45",
"v" : "264.000"
"d" : "2017-06-09 10:50",
"v" : "241.000"
"d" : "2017-06-09 10:55",
"v" : "273.000"
"d" : "2017-06-09 10:00",
"eu" : "21.000"
"d" : "2017-06-09 11:00",
"v" : "282.000"
"d" : "2017-06-09 11:05",
"v" : "271.000"
"d" : "2017-06-09 11:10",
"v" : "248.000"
"d" : "2017-06-09 11:15",
"v" : "271.000"
"d" : "2017-06-09 11:20",
"v" : "271.000"
"d" : "2017-06-09 11:25",
"v" : "259.000"
"d" : "2017-06-09 11:30",
"v" : "262.000"
"d" : "2017-06-09 11:35",
"v" : "289.000"
"d" : "2017-06-09 11:40",
"v" : "271.000"
"d" : "2017-06-09 11:45",
"v" : "269.000"
"d" : "2017-06-09 11:50",
"v" : "273.000"
"d" : "2017-06-09 11:55",
"v" : "271.000"
"eu" : "0.000"
"d" : "2017-06-09 12:00",
"v" : "248.000"
"d" : "2017-06-09 12:05",
"v" : "269.000"
"d" : "2017-06-09 12:10",
"v" : "266.000"
"d" : "2017-06-09 12:15",
"v" : "269.000"
"d" : "2017-06-09 12:20",
"v" : "250.000"
"d" : "2017-06-09 12:25",
"v" : "243.000"
"d" : "2017-06-09 12:30",
"v" : "259.000"
"d" : "2017-06-09 12:35",
"v" : "262.000"
"d" : "2017-06-09 12:40",
"v" : "259.000"
"d" : "2017-06-09 12:45",
"v" : "294.000"
"d" : "2017-06-09 12:50",
"v" : "269.000"
"d" : "2017-06-09 12:55",
"v" : "271.000"
"eu" : "0.000"
"d" : "2017-06-09 13:00",
"v" : "266.000"
"d" : "2017-06-09 13:05",
"v" : "266.000"
"d" : "2017-06-09 13:10",
"v" : "246.000"
"d" : "2017-06-09 13:15",
"v" : "266.000"
"d" : "2017-06-09 13:20",
"v" : "271.000"
"d" : "2017-06-09 13:25",
"v" : "269.000"
"d" : "2017-06-09 13:30",
"v" : "271.000"
"d" : "2017-06-09 13:35",
"v" : "285.000"
"d" : "2017-06-09 13:40",
"v" : "257.000"
"d" : "2017-06-09 13:45",
"v" : "252.000"
"d" : "2017-06-09 13:50",
"v" : "255.000"
"d" : "2017-06-09 13:55",
"v" : "241.000"
"eu" : "0.000"
"d" : "2017-06-09 14:00",
"v" : "271.000"
"d" : "2017-06-09 14:05",
"v" : "269.000"
"d" : "2017-06-09 14:10",
"v" : "269.000"
"d" : "2017-06-09 14:15",
"v" : "271.000"
"d" : "2017-06-09 14:20",
"v" : "239.000"
"d" : "2017-06-09 14:25",
"v" : "271.000"
"d" : "2017-06-09 14:30",
"v" : "271.000"
"d" : "2017-06-09 14:35",
"v" : "271.000"
"d" : "2017-06-09 14:40",
"v" : "294.000"
"d" : "2017-06-09 14:45",
"v" : "292.000"
"d" : "2017-06-09 14:50",
"v" : "259.000"
"d" : "2017-06-09 14:55",
"v" : "257.000"
"eu" : "0.000"
"d" : "2017-06-09 15:00",
"v" : "271.000"
"d" : "2017-06-09 15:05",
"v" : "252.000"
"d" : "2017-06-09 15:10",
"v" : "271.000"
"d" : "2017-06-09 15:15",
"v" : "271.000"
"d" : "2017-06-09 15:20",
"v" : "271.000"
"d" : "2017-06-09 15:25",
"v" : "255.000"
"d" : "2017-06-09 15:30",
"v" : "241.000"
"d" : "2017-06-09 15:35",
"v" : "271.000"
"d" : "2017-06-09 15:40",
"v" : "271.000"
"d" : "2017-06-09 15:45",
"v" : "259.000"
"d" : "2017-06-09 15:50",
"v" : "289.000"
"d" : "2017-06-09 15:55",
"v" : "259.000"
"eu" : "0.000"
"d" : "2017-06-09 16:00",
"v" : "257.000"
"d" : "2017-06-09 16:05",
"v" : "269.000"
"d" : "2017-06-09 16:10",
"v" : "243.000"
"d" : "2017-06-09 16:15",
"v" : "241.000"
"d" : "2017-06-09 16:20",
"v" : "271.000"
"d" : "2017-06-09 16:25",
"v" : "273.000"
"d" : "2017-06-09 16:30",
"v" : "275.000"
"d" : "2017-06-09 16:35",
"v" : "246.000"
"d" : "2017-06-09 16:40",
"v" : "271.000"
"d" : "2017-06-09 16:45",
"v" : "273.000"
"d" : "2017-06-09 16:50",
"v" : "269.000"
"d" : "2017-06-09 16:55",
"v" : "289.000"
"eu" : "0.000"
"d" : "2017-06-09 17:00",
"v" : "257.000"
"d" : "2017-06-09 17:05",
"v" : "379.000"
"d" : "2017-06-09 17:10",
"v" : "374.000"
"d" : "2017-06-09 17:15",
"v" : "372.000"
"d" : "2017-06-09 17:20",
"v" : "241.000"
"d" : "2017-06-09 17:25",
"v" : "269.000"
"d" : "2017-06-09 17:30",
"v" : "264.000"
"d" : "2017-06-09 17:35",
"v" : "269.000"
"d" : "2017-06-09 17:40",
"v" : "239.000"
"d" : "2017-06-09 17:45",
"v" : "266.000"
"d" : "2017-06-09 17:50",
"v" : "257.000"
"d" : "2017-06-09 17:55",
"v" : "285.000"
"eu" : "85.000"
"d" : "2017-06-09 18:00",
"v" : "303.000"
"d" : "2017-06-09 18:05",
"v" : "282.000"
"d" : "2017-06-09 18:10",
"v" : "597.000"
"d" : "2017-06-09 18:15",
"v" : "607.000"
"d" : "2017-06-09 18:20",
"v" : "625.000"
"d" : "2017-06-09 18:25",
"v" : "471.000"
"d" : "2017-06-09 18:30",
"v" : "588.000"
"d" : "2017-06-09 18:35",
"v" : "561.000"
"d" : "2017-06-09 18:40",
"v" : "616.000"
"d" : "2017-06-09 18:45",
"v" : "505.000"
"d" : "2017-06-09 18:50",
"v" : "289.000"
"d" : "2017-06-09 18:55",
"v" : "423.000"
"eu" : "246.000"
"d" : "2017-06-09 19:00",
"v" : "427.000"
"d" : "2017-06-09 19:05",
"v" : "411.000"
"d" : "2017-06-09 19:10",
"v" : "345.000"
"d" : "2017-06-09 19:15",
"v" : "411.000"
"d" : "2017-06-09 19:20",
"v" : "409.000"
"d" : "2017-06-09 19:25",
"v" : "407.000"
"d" : "2017-06-09 19:30",
"v" : "416.000"
"d" : "2017-06-09 19:35",
"v" : "418.000"
"d" : "2017-06-09 19:40",
"v" : "386.000"
"d" : "2017-06-09 19:45",
"v" : "423.000"
"d" : "2017-06-09 19:50",
"v" : "370.000"
"d" : "2017-06-09 19:55",
"v" : "388.000"
"eu" : "0.000"
"d" : "2017-06-09 20:00",
"v" : "420.000"
"d" : "2017-06-09 20:05",
"v" : "423.000"
"d" : "2017-06-09 20:10",
"v" : "407.000"
"d" : "2017-06-09 20:15",
"v" : "358.000"
"d" : "2017-06-09 20:20",
"v" : "407.000"
"d" : "2017-06-09 20:25",
"v" : "409.000"
"d" : "2017-06-09 20:30",
"v" : "381.000"
"d" : "2017-06-09 20:35",
"v" : "471.000"
"d" : "2017-06-09 20:40",
"v" : "489.000"
"d" : "2017-06-09 20:45",
"v" : "460.000"
"d" : "2017-06-09 20:50",
"v" : "494.000"
"d" : "2017-06-09 20:55",
"v" : "492.000"
"eu" : "0.000"
"d" : "2017-06-09 21:00",
"v" : "478.000"
"d" : "2017-06-09 21:05",
"v" : "473.000"
"d" : "2017-06-09 21:10",
"v" : "294.000"
"d" : "2017-06-09 21:15",
"v" : "294.000"
"d" : "2017-06-09 21:20",
"v" : "292.000"
"d" : "2017-06-09 21:25",
"v" : "278.000"
"d" : "2017-06-09 21:30",
"v" : "282.000"
"d" : "2017-06-09 21:35",
"v" : "289.000"
"d" : "2017-06-09 21:40",
"v" : "262.000"
"d" : "2017-06-09 21:45",
"v" : "294.000"
"d" : "2017-06-09 21:50",
"v" : "292.000"
"d" : "2017-06-09 21:55",
"v" : "294.000"
"eu" : "0.000"
"d" : "2017-06-09 22:00",
"v" : "273.000"
"d" : "2017-06-09 22:05",
"v" : "262.000"
"d" : "2017-06-09 22:10",
"v" : "292.000"
"d" : "2017-06-09 22:15",
"v" : "292.000"
"d" : "2017-06-09 22:20",
"v" : "285.000"
"d" : "2017-06-09 22:25",
"v" : "292.000"
"d" : "2017-06-09 22:30",
"v" : "271.000"
"d" : "2017-06-09 22:35",
"v" : "278.000"
"d" : "2017-06-09 22:40",
"v" : "289.000"
"d" : "2017-06-09 22:45",
"v" : "264.000"
"d" : "2017-06-09 22:50",
"v" : "287.000"
"d" : "2017-06-09 22:55",
"v" : "289.000"
"eu" : "0.000"
"d" : "2017-06-09 23:00",
"v" : "287.000"
"d" : "2017-06-09 23:05",
"v" : "278.000"
"d" : "2017-06-09 23:10",
"v" : "259.000"
"d" : "2017-06-09 23:15",
"v" : "287.000"
"d" : "2017-06-09 23:20",
"v" : "292.000"
"d" : "2017-06-09 23:25",
"v" : "278.000"
"d" : "2017-06-09 23:30",
"v" : "296.000"
"d" : "2017-06-09 23:35",
"v" : "273.000"
"d" : "2017-06-09 23:40",
"v" : "269.000"
"d" : "2017-06-09 23:45",
"v" : "292.000"
"d" : "2017-06-09 23:50",
"v" : "271.000"
"eu" : "0.000"
"d" : "2017-06-10 00:00",
"v" : "294.000"
"d" : "2017-06-10 00:05",
"v" : "292.000"
"d" : "2017-06-10 00:10",
"v" : "478.000"
"d" : "2017-06-10 00:15",
"v" : "372.000"
"d" : "2017-06-10 00:20",
"v" : "331.000"
"d" : "2017-06-10 00:25",
"v" : "321.000"
"d" : "2017-06-10 00:30",
"v" : "315.000"
"d" : "2017-06-10 00:35",
"v" : "335.000"
"d" : "2017-06-10 00:40",
"v" : "289.000"
"d" : "2017-06-10 00:45",
"v" : "292.000"
"d" : "2017-06-10 00:50",
"v" : "289.000"
"d" : "2017-06-10 00:55",
"v" : "292.000"
"eu" : "0.000"
"d" : "2017-06-10 01:00",
"v" : "266.000"
"d" : "2017-06-10 01:05",
"v" : "292.000"
"d" : "2017-06-10 01:10",
"v" : "294.000"
"d" : "2017-06-10 01:15",
"v" : "292.000"
"d" : "2017-06-10 01:20",
"v" : "275.000"
"d" : "2017-06-10 01:25",
"v" : "262.000"
"d" : "2017-06-10 01:30",
"v" : "275.000"
"d" : "2017-06-10 01:35",
"v" : "278.000"
"d" : "2017-06-10 01:40",
"v" : "278.000"
"d" : "2017-06-10 01:45",
"v" : "303.000"
"d" : "2017-06-10 01:50",
"v" : "294.000"
"d" : "2017-06-10 01:55",
"v" : "294.000"
"eu" : "0.000"
"d" : "2017-06-10 02:00",
"v" : "292.000"
"d" : "2017-06-10 02:05",
"v" : "282.000"
"d" : "2017-06-10 02:10",
"v" : "262.000"
"d" : "2017-06-10 02:15",
"v" : "292.000"
"d" : "2017-06-10 02:20",
"v" : "292.000"
"d" : "2017-06-10 02:25",
"v" : "289.000"
"d" : "2017-06-10 02:30",
"v" : "266.000"
"d" : "2017-06-10 02:35",
"v" : "273.000"
"d" : "2017-06-10 02:40",
"v" : "278.000"
"d" : "2017-06-10 02:45",
"v" : "280.000"
"d" : "2017-06-10 02:50",
"v" : "273.000"
"d" : "2017-06-10 02:55",
"v" : "264.000"
"eu" : "0.000"
"d" : "2017-06-10 03:00",
"v" : "296.000"
"d" : "2017-06-10 03:05",
"v" : "294.000"
"d" : "2017-06-10 03:10",
"v" : "292.000"
"d" : "2017-06-10 03:15",
"v" : "264.000"
"d" : "2017-06-10 03:20",
"v" : "296.000"
"d" : "2017-06-10 03:25",
"v" : "298.000"
"d" : "2017-06-10 03:30",
"v" : "296.000"
"d" : "2017-06-10 03:35",
"v" : "296.000"
"d" : "2017-06-10 03:40",
"v" : "296.000"
"d" : "2017-06-10 03:45",
"v" : "278.000"
"d" : "2017-06-10 03:50",
"v" : "280.000"
"d" : "2017-06-10 03:55",
"v" : "275.000"
"eu" : "0.000"
"d" : "2017-06-10 04:00",
"v" : "273.000"
"d" : "2017-06-10 04:05",
"v" : "294.000"
"d" : "2017-06-10 04:10",
"v" : "296.000"
"d" : "2017-06-10 04:15",
"v" : "298.000"
"d" : "2017-06-10 04:20",
"v" : "294.000"
"d" : "2017-06-10 04:25",
"v" : "262.000"
"d" : "2017-06-10 04:30",
"v" : "296.000"
"d" : "2017-06-10 04:35",
"v" : "296.000"
"d" : "2017-06-10 04:40",
"v" : "294.000"
"d" : "2017-06-10 04:45",
"v" : "278.000"
"d" : "2017-06-10 04:50",
"v" : "296.000"
"d" : "2017-06-10 04:55",
"v" : "275.000"
"eu" : "0.000"
"d" : "2017-06-10 05:00",
"v" : "271.000"
"d" : "2017-06-10 05:05",
"v" : "292.000"
"d" : "2017-06-10 05:10",
"v" : "266.000"
"d" : "2017-06-10 05:15",
"v" : "294.000"
"d" : "2017-06-10 05:20",
"v" : "294.000"
"d" : "2017-06-10 05:25",
"v" : "294.000"
"d" : "2017-06-10 05:30",
"v" : "294.000"
"d" : "2017-06-10 05:35",
"v" : "262.000"
"d" : "2017-06-10 05:40",
"v" : "296.000"
"d" : "2017-06-10 05:45",
"v" : "292.000"
"d" : "2017-06-10 05:50",
"v" : "273.000"
"d" : "2017-06-10 05:55",
"v" : "273.000"
"eu" : "0.000"
"d" : "2017-06-10 06:00",
"v" : "289.000"
"d" : "2017-06-10 06:05",
"v" : "278.000"
"d" : "2017-06-10 06:10",
"v" : "296.000"
"d" : "2017-06-10 06:15",
"v" : "296.000"
"d" : "2017-06-10 06:20",
"v" : "266.000"
"d" : "2017-06-10 06:25",
"v" : "294.000"
"d" : "2017-06-10 06:30",
"v" : "292.000"
"d" : "2017-06-10 06:35",
"v" : "328.000"
"d" : "2017-06-10 06:40",
"v" : "331.000"
"d" : "2017-06-10 06:45",
"v" : "340.000"
"d" : "2017-06-10 06:50",
"v" : "377.000"
"d" : "2017-06-10 06:55",
"v" : "349.000"
"eu" : "0.000"
"d" : "2017-06-10 07:00",
"v" : "354.000"
"d" : "2017-06-10 07:05",
"v" : "358.000"
"d" : "2017-06-10 07:10",
"v" : "361.000"
"d" : "2017-06-10 07:15",
"v" : "370.000"
"d" : "2017-06-10 07:20",
"v" : "370.000"
"d" : "2017-06-10 07:25",
"v" : "400.000"
"d" : "2017-06-10 07:30",
"v" : "2176.000"
"d" : "2017-06-10 07:35",
"v" : "2786.000"
"d" : "2017-06-10 07:40",
"v" : "2773.000"
"d" : "2017-06-10 07:45",
"v" : "2732.000"
"d" : "2017-06-10 07:50",
"v" : "809.000"
"d" : "2017-06-10 07:55",
"v" : "972.000"
"eu" : "2161.000"
"d" : "2017-06-10 08:00",
"v" : "450.000"
"d" : "2017-06-10 08:05",
"v" : "441.000"
"d" : "2017-06-10 08:10",
"v" : "471.000"
"d" : "2017-06-10 08:15",
"v" : "625.000"
"d" : "2017-06-10 08:20",
"v" : "492.000"
"d" : "2017-06-10 08:25",
"v" : "510.000"
"d" : "2017-06-10 08:30",
"v" : "487.000"
"d" : "2017-06-10 08:35",
"v" : "489.000"
"d" : "2017-06-10 08:40",
"v" : "494.000"
"d" : "2017-06-10 08:45",
"v" : "462.000"
"d" : "2017-06-10 08:50",
"v" : "1282.000"
"d" : "2017-06-10 08:55",
"v" : "480.000"
"eu" : "0.000"
"d" : "2017-06-10 09:00",
"v" : "480.000"
"d" : "2017-06-10 09:05",
"v" : "563.000"
"d" : "2017-06-10 09:10",
"v" : "478.000"
"d" : "2017-06-10 09:15",
"v" : "604.000"
"d" : "2017-06-10 09:20",
"v" : "494.000"
"d" : "2017-06-10 09:25",
"v" : "503.000"
"d" : "2017-06-10 09:30",
"v" : "473.000"
"d" : "2017-06-10 09:35",
"v" : "469.000"
"d" : "2017-06-10 09:40",
"v" : "499.000"
"d" : "2017-06-10 09:45",
"v" : "499.000"
"d" : "2017-06-10 09:50",
"v" : "768.000"
"d" : "2017-06-10 09:55",
"v" : "565.000"
"eu" : "0.000"
"d" : "2017-06-10 10:00",
"v" : "531.000"
"d" : "2017-06-10 10:05",
"v" : "533.000"
"eu" : "0.000"
"d" : "2017-06-10 10:10",
"v" : "508.000"
"status" : "OK",
"title" : "Graph counter day"
?(data);
when i call:
http://192.168.1.146:8080/json.htm?type=graph&sensor=counter&idx=27&range=day&method=0&jsoncallback=?Code: Select all
var data={
"ValueUnits" : "",
"method" : 0,
"result" : [
"v" : "48.000"
"v" : "0.000"
"v" : "90.000"
"v" : "246.000"
"v" : "0.000"
"v" : "0.000"
"v" : "0.000"
"v" : "0.000"
"v" : "0.000"
"v" : "0.000"
"v" : "0.000"
"v" : "0.000"
"v" : "0.000"
"v" : "0.000"
"v" : "0.000"
"v" : "0.000"
"v" : "2161.000"
"v" : "0.000"
"v" : "0.000"
"v" : "0.000"
"d" : "2017-06-10 11:00",
"v" : "122.000"
"d" : "2017-06-10 12:00",
"v" : "0.000"
"d" : "2017-06-10 13:00",
"v" : "230.000"
"d" : "2017-06-10 14:00",
"v" : "0.000"
"status" : "OK",
?(data);
blocks['graph_27'] = {}
blocks['graph_27']['width'] = 5;
url: _HOST_DOMOTICZ+'/json.htm?type=graph&sensor='+sensor+'&idx='+idx+'&range='+realrange+'&time='+new Date().getTime()+'&jsoncallback=?',
url: _HOST_DOMOTICZ+'/json.htm?type=graph&sensor='+sensor+'&idx='+idx+'&range='+realrange+'&method=1&time='+new Date().getTime()+'&jsoncallback=?',
Thank you all
Sundown89
- Domoticz version: 3.7708
Hi!
I would like Spotify integration. I have multiroom audio using RPi's as Spotify Connect devices. See github here.
Currently I am using my android phone as the remote to control them. Would be nice to control the devices from the tablet on the wall through Dashticz.
Domoticz on Ubuntu 14.04
Dashticz V2
Pi-Hole
RFXCom
Dashticz V2
Pi-Hole
RFXCom
I would like to see a feature that you can specify / overrule the width of a block, on a different page.
Issue I have is that on one page the block needs to be a width of 12, on an other page the block needs to have width of 12.
freakshock
I would love this also. It would however probably make more sense to have the Spotify control integrated in Domoticz itself first. I have done some forum searches but cannot find this has been done so far. But I'm not the pro hereSundown89 wrote:Hi!
dutchdevil83
First of all thankx for your hard work! Have everything up and running and will post some screenshots of my config so far. While playing with the right design for my power and gas usage graphs i discovered only morris.area is supported until now. Could it be possible to support also morris.line and morris.bar ? Also like to have more customization options for the graph.js module like line colors/font type/etc.
Hope someone with some spare time will work on this function. Keep up the good work!
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
1x GoodWe Solarpanels
2x FGSD-002 Smoke Detector
1x FGBS-001 Binaire Sensor (RFID lezer)
7x FGMS-001 Motion Sensor
3x ZW089 Verzonken Deursensor
7x NC Wallplug
&lots of KaKu stuff
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
robgeerts
- Domoticz version: 3.7067
Fixed in latest beta, add a image to the img-folder and use:htilburgs wrote:I meant like in the rss feed, etc..
But I like the feature as in the buttons, just the option icon: or image: in the variable.
example:
calendars.f1 = { maxitems: 5, title: 'F1 Calendar', icon: 'fa-calendar ',icalurl: 'https://calendar.google.com/calendar/ical/xx/basic.ics' }
or
calendars.f1 = { maxitems: 5, title: 'F1 Calendar', image: 'img/calendar.png',icalurl: 'https://calendar.google.com/calendar/ical/xx/basic.ics' }
calendars.f1 = { maxitems: 5, title: 'F1 Calendar', [b]image: 'calendar.png'[/b],icalurl: 'https://calendar.google.com/calendar/ical/xx/basic.ics' }
- htilburgs
Hi Rob, great work, thanks!
Looks great...!
Looks great...!
Hardware:
- htilburgs
Rob, one question. Is it possible to change the class of the calendar image?
Now is has class ICON and is it not quite possible to change format of location of the image.
Hardware:
robgeerts
I've added this class in BETA: calendar_iconhtilburgs wrote:Rob, one question. Is it possible to change the class of the calendar image?
- htilburgs
Thnx! Will try it later this afternoon.
Hardware:
WaTTe
- Domoticz version: 3.8153
Change the text of a temperature sensor depending on the measured temperature.
Eg a green color at 5 degrees an orange color at 15 a red at 25 etc.
