Dashticz - Feature Requests
Locked
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Add new feature request here.
I will extend this list with all requests, if it's not yet in here after a few days, please quote me ;)
  • Moving blocks from within the dashboard
  • Adding blocks from within the dashboard
  • RGB selector for colored lights
  • StationClock
  • Open camera on doorbell
  • Different colors in the graphs
  • Multiple versions of dashticz
htilburgs
Re: Dashticz - Feature Requests
Post by htilburgs »
@Robgeerts, you have been working on a color selecter (for hue) http://www.domoticz.com/forum/viewtopic ... 80#p132112. Since yesterday I've a Yeelight Color RGBW Led in my Domoticz configuration.
When I add this to Dashticz I get a standard Dimmer whitout the posibility to change color (only dimmer and on/off function).
I've added the infomration from Domoticz.
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "Off",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 9,
"HardwareName" : "YeeLight Controller",
"HardwareType" : "YeeLight LED",
"HardwareTypeVal" : 91,
"HaveDimmer" : true,
"HaveGroupCmd" : false,
"HaveTimeout" : false,
"ID" : "C0A80032",
"Image" : "Light",
"IsSubDevice" : false,
"LastUpdate" : "2017-05-05 09:54:53",
"Level" : 99,
"LevelInt" : 99,
"MaxDimLevel" : 100,
"Name" : "Yeelight Huiskamer",
"Notifications" : "false",
"PlanID" : "2",
"PlanIDs" : [ 2 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "RGBW",
"SwitchType" : "Dimmer",
"SwitchTypeVal" : 7,
"Timers" : "false",
"Type" : "Lighting Limitless/Applamp",
"TypeImg" : "dimmer",
"Unit" : 0,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "267",
"YOffset" : "194",
"idx" : "213"
Request: Button like you've been working on in the added post.
Hardware:
HansieNL
Post by HansieNL »
3Quarks » Station Clock http://www.3quarks.com/en/StationClock/
Naamloos 1.jpg (22.73 KiB) Viewed 23758 times
Blah blah blah
robgeerts
Post by robgeerts »
HansieNL wrote:3Quarks » Station Clock http://www.3quarks.com/en/StationClock/
Check out latest beta and add:
columns[1]['blocks'] = ['stationclock']
HansieNL
Post by HansieNL »
Blah blah blah
bsmeding
Post by bsmeding »
Also added to GitHub (https://github.com/robgeerts/dashticz_v2/issues/55), but it would be great to have an popup (for x seconds) of the camera when my (doorbell) switch in On so i can see in larger image who is at the frontdoor
clubeddie
Post by clubeddie »
:lol: :lol: :lol: :lol: :lol: :lol: :lol:
pvdhelm
Post by pvdhelm »
Maybe it's an option to make a frontpage where you can sellect a room when you press the button of the room the dashboard goes directly to the page of that room. After let say 1 minute it goes back to the frontpage
b00n
Post by b00n »
In my previous dashboard i got a doorbell function maybe rob can do something with is
	function checkdoorbell(){
	var idx=69
	console.log("checking to see if Doorbell is On "+idx)
	var xmlhttp = new XMLHttpRequest();
	var url = "http://192.168.178.30:8080/json.htm?type=devices&rid="+idx;
	var onoff
	xmlhttp.onreadystatechange = function() {
    	if (xmlhttp.readyState == 4 && xmlhttp.status == 200) {
        	var myArr = JSON.parse(xmlhttp.responseText);
			onoff = myArr.result[0].Status;
       // myFunction(myArr);
		if (onoff == "On") {
		MM_goToURL('parent','cameras1.htm');
		} else {}
lukev
Post by lukev »
Maybe a block for streaming video cams? Support of RTSP would be awesome, I have big problems with the image-based webcam possibilities at the moment.
b00n
Post by b00n »
Temp + Humidity in one box like:
woody4165
Post by woody4165 »
I would like to have the possibility to define an refresh time for weather, different than the Dashticz and Domoticz refresh that are already in the Config.js
Is it possible to do it in a simple way?
capman
Post by capman »
A have a question about the music controls. Is it possible to make the buttons larger for play , pause, etc... ? A have my Logitech media server on my synology nas and when a use squeezeplay on my phone , tablet ,a see a cover from what is playing with some radiostations. A think that these come from http://www.tunein.com . These covers see a also on my LMS , so they must keep them from some online source.
Should it be possible to see these also on my dashboard screen ? A have searching for this a lot , but a found nothing how to do that. Maybe are here some users who are more capable for how to do this. Also thanks in advance.
Here some screenshot from my LMS where you see the whats playing cover.
radio cover.JPG (50.88 KiB) Viewed 23532 times
And also from my dashticz so far. :D
HansieNL
Post by HansieNL »
Rename of custom.css to custom_default.css and rename of custom.js to custom_default.js.
Now these custom files are overwritten by a new pull or zip unpack.
Blah blah blah
poudenes
Domoticz version: 3.8993
Post by poudenes »
Use this clock, but when i switch screens the clock become black.
Blueone
Post by Blueone »
The following improvement points would be nice:
-A better way to authenticate. Currently the format username:password@ip is used but it is a deprecated method which can't be used anymore from june.
-When you run the dashboard 24/7 a day it sometimes happens that domoticz can't be reached for whatever reason, bad wifi, domoticz busy or something. This result is an alert pop-up which stays in the screen. Maybe it better to write this error to the browser console log so the dashboard continuous
-While running 24/7 it sometimes happens the weather isn't loaded for whatever reason (api not available, internet hick-up) and is empty and the layout is messed up. A dashboard refresh fixes it. When you run 24/7 with a tablet on the wall you won't want to refresh the dashboard every 30 minutes as it is distractive. Maybe the refresh process can be more invisible without going out of stand-by are something. A bit the same as the domoticz refresh but not every few seconds, but a invisible refresh for the internet data every 10 minutes or so.
But overall, I really like this dashboard :)
clubeddie
Post by clubeddie »
Is it possible to show the costs of consumed power and gas?
These data is available in the log section of domoticz, and a user can adjust the kwh and m3 price of his supplier.
I don't know if this data can be extracted somehow?
No is also an answer :-)
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
Is it possible to add custom colors for graph. Now i do this in the graph.js
robgeerts
Post by robgeerts »
clubeddie wrote:Is it possible to show the costs of consumed power and gas?
Do you get this data back from the json output?
http://URL_TO_DOMOTICZ/json.htm?type=devices
MarceldeJongNL
Domoticz version: 3.5108
Post by MarceldeJongNL »
I would love to use one instance of Dashticz for multiple custom configurations (Desktop, Tablet, Phone, etc)
Could you make an option, to specify as specific Custom folder in the HTML file? Like a simple variable you put in the HTML file
Example:
index.html uses /custom (default)
mobile.html uses /custom_mobile
tablet_second_floor.html uses /custom_tablet_second_floor
That would make managing multiple instances a breeze
Thanks for all you effort!
Hardware: Raspberry Pi 2B | RFXCOM RFXtrx433E v1 | Synology DS213+ | KaKu Clones | Conrad RSL switches | KAKu Doorbell Clone | USB Webcam | ICY Thermostat | Resol DL2 | Imatic Relay Board | Eminent 6230 | Eminent 6220 | iMatic 16 ports Relay Board
Locked
