Locked
Dynamic
Re: New Dashboard Design
Post by Dynamic »
I'm getting pretty far with my own dashboard. An old iPad will be mounted to the wall next week to facilitate this awesome dashboard.
I've got a couple of devices that I would like to activate from the dashboard (switch command should be on/off or push). I will need this to controll my Sonos speakers. What is the easiest way to create a manual button and assign it to an on/off or push-switch?
koowee
Post by koowee »
This dashboard is great!
I have some problems when I try to add Netatmo CO2 sensor, I get result "undefind". Is there something wrong on my code or do you need to add support to this kind of device?
if(data.result[r]['idx']==199){
$('.insideco').html(data.result[r]['Air Quality']+' ppm');
$('.insideco').parents('.hideinit').show();
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "1060 ppm",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 13,
         "HardwareName" : "Netatmo",
         "HardwareType" : "Netatmo",
         "HardwareTypeVal" : 54,
         "HaveTimeout" : false,
         "ID" : "0079",
         "LastUpdate" : "2017-03-28 19:42:01",
         "Name" : "Living room CO2",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "Quality" : "Fair",
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "SubType" : "Voltcraft CO-20",
         "Timers" : "false",
         "Type" : "Air Quality",
         "TypeImg" : "air",
         "Unit" : 165,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "199"
EdwinK
Post by EdwinK »
Not sure if it's possible, but ..
I would like to control my Logitech Media Server (on Synology). Play/stop volume up/down, and on/off. Maybe even a playlist. It doesn't need to play on the site, iv'e got a Raspberry for that.
Just in case:
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "The Beatles - Sgt. Pepper's Lonely Hearts Club Band (1967)",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 22,
         "HardwareName" : "LMS",
         "HardwareType" : "Logitech Media Server",
         "HardwareTypeVal" : 60,
         "HaveDimmer" : true,
         "HaveGroupCmd" : true,
         "ID" : "000002E",
         "Image" : "Light",
         "IsSubDevice" : false,
         "LastUpdate" : "2017-03-28 19:34:59",
         "Level" : 0,
         "LevelInt" : 0,
         "MaxDimLevel" : 15,
         "Name" : "Huiskamer",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Status" : "Playing",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "AC",
         "SwitchType" : "Media Player",
         "SwitchTypeVal" : 17,
         "Timers" : "false",
         "Type" : "Lighting 2",
         "TypeImg" : "LogitechMediaServer",
         "Unit" : 1,
         "Used" : 1,
         "UsedByCamera" : false,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "102"
   "status" : "OK",
   "title" : "Devices"
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
koowee wrote:Hi,
NEEDS TO BE:
$('.insideco').html(data.result[r]['Data']);
robgeerts
Post by robgeerts »
EdKo66 wrote: "Data" : "The Beatles - Sgt. Pepper's Lonely Hearts Club Band (1967)",
Nice choice!
EdKo66 wrote: I would like to control my Logitech Media Server (on Synology). Play/stop volume up/down, and on/off. Maybe even a playlist. It doesn't need to play on the site, iv'e got a Raspberry for that.
In this case, you need to know wich commands it uses.
When you open your existing webpage of the Media Server (assuming there's one), you can check (f12, network tab) wich urls it calls when you click on a button.
Could you retrieve these?
koowee
Post by koowee »
robgeerts wrote:
NEEDS TO BE:
robgeerts
Post by robgeerts »
Dynamic wrote:I'm getting pretty far with my own dashboard. An old iPad will be mounted to the wall next week to facilitate this awesome dashboard.
Well, you could copy the next code from main.js and change this to fit your needs.
else if(data.result[r]['Type']=='Group'){
	var switchHTML = '<div class="col-md-4 mb no-pr" data-light="'+data.result[r]['idx']+'" onclick="switchGroup(this);">';
			switchHTML+='<div class="transbg"> ';
				switchHTML+='<div class="col-md-4 no-padding">';
					if(data.result[r]['Status']=='Off') switchHTML+='<img src="img/'+buttonimg+'_off.png" class="off icon" />';
					else switchHTML+='<img src="img/'+buttonimg+'_on.png" class="on icon" />';
				switchHTML+='</div>';
				switchHTML+='<div class="col-md-8 no-padding">';
					switchHTML+='<strong class="title">'+data.result[r]['Name']+'</strong><br />';
					if(data.result[r]['Status']=='Off') switchHTML+='<span class="state">UIT</span>';
					else switchHTML+='<span class="state">AAN</span>';
	$('#groups').append(switchHTML);
You can also post your json-output if you want us to help you, take a look at this post:
http://domoticz.com/forum/viewtopic.php ... 60#p124168
EdwinK
Post by EdwinK »
I've got this in jsonrpc.js
{"result":{"lastscan":"1489419015","version":"7.9.0","uuid":"66e16fd3-bf2f-4e86-9793-efec66a38a6d","info total albums":199,"info total artists":580,"info total genres":33,"info total songs":2510,"info total duration":523574.062000001,"player count":1,"players_loop":[{"playerid":"00:1d:43:10:15:92","uuid":null,"ip":"192.168.0.103:49961","name":"Huiskamer","seq_no":0,"model":"squeezelite","power":"1","isplaying":1,"displaytype":"none","canpoweroff":1,"connected":1,"isplayer":1}],"sn player count":0,"other player count":0},"params":["",["serverstatus","0","999"]],"id":1,"method":"slim.request"}
This created for every song, so I hope this might be it.
Maartenkr
Domoticz version: 3.7196
Post by Maartenkr »
Hello I have a question.
Is it possible to control my Nest termostaat?
And how do I get the barometer and wind on the right see picture.
robgeerts
Post by robgeerts »
Maartenkr wrote:Hello I have a question.
could you send me the complete output, as described here:
Maartenkr
Post by Maartenkr »
"AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "18.4",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 3,
         "HardwareName" : "Nest",
         "HardwareType" : "Nest Thermostat/Protect",
         "HardwareTypeVal" : 52,
         "ID" : "0000001",
         "LastUpdate" : "2017-03-29 11:03:38",
         "Name" : "Setpoint Verwarming",
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "SetPoint" : "18.4",
         "SubType" : "SetPoint",
         "Timers" : "false",
         "Type" : "Thermostat",
         "TypeImg" : "override_mini",
         "Unit" : 0,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "7"
This is the output of the nest thermostat
EdwinK
Post by EdwinK »
Accidently posted this in my previous post.
Dynamic
Post by Dynamic »
Hmm, i'm not having success myself...
What I want: in the middle column I want to have 4 buttons next to each other to control my sonos speakers (stop, play, volume up, volume down).
This is the JSON-output:
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 2,
         "HardwareName" : "Dummy",
         "HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
         "HardwareTypeVal" : 15,
         "ID" : "0005000A",
         "Image" : "Light",
         "LastUpdate" : "2017-03-29 19:51:03",
         "Level" : 0,
         "LevelActions" : "||||",
         "LevelInt" : 0,
         "LevelNames" : "Off|Play|Pause|Volume up|Volume down",
         "LevelOffHidden" : true,
         "MaxDimLevel" : 100,
         "Name" : "Sonos",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SelectorStyle" : 0,
         "SignalLevel" : 0,
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "Selector Switch",
         "SwitchType" : "Selector",
         "SwitchTypeVal" : 18,
         "Timers" : "false",
         "Type" : "Light/Switch",
         "TypeImg" : "Light",
         "Unit" : 9,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "771"
robgeerts
Post by robgeerts »
The output of your nest thermostat is only for displaying the temperature and for controlling it?
If you want the barometer and wind on the right, try this:
Find:
else if(data.result[r]['Type']=='General' && data.result[r]['SubType']=='Barometer'){
Change the complete elseif-statement to:
	$('.block'+data.result[r]['idx']).remove();
	var switchHTML = '<div class="col-md-12 mb block'+data.result[r]['idx']+'" data-light="'+data.result[r]['idx']+'">';
			switchHTML+='<div class="transbg">';
					switchHTML+='<em class="wi wi-barometer"></em>';
					switchHTML+='<strong class="title">'+data.result[r]['Data']+'</strong><br />';
					switchHTML+='<span>'+data.result[r]['Name']+'</span>';
	$('.blocks').append(switchHTML);
AND FOR WIND:
Find:
else if(data.result[r]['Type']=='Wind'){
And change it to:
					switchHTML+='<em class="wi wi-wind-direction"></em>';
					switchHTML+='<strong class="title">'+data.result[r]['Gust']+'km/u, '+data.result[r]['DirectionStr']+'</strong><br />';
Last edited by robgeerts on Wednesday 29 March 2017 20:58, edited 2 times in total.
robgeerts
Post by robgeerts »
Dynamic wrote: This is the JSON-output:
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 2,
         "LevelInt" : 0,
         "idx" : "771"
First, you have to enable the switch as a favorite in Domoticz.
Second, the LevelActions for each buttons are empty?
Dynamic
Post by Dynamic »
robgeerts wrote: First, you have to enable the switch as a favorite in Domoticz.
Done!
The LevelActions are empty for the moment, because I created this device for the new dashboard. I'm going to assign actions to those buttons (it will run a Python-script).
robgeerts
Post by robgeerts »
In the meantime, I'm changing some things, take a look at this screenshot:
It seems that more people have blocks like you can see in the middle (status of devices etc.). By moving them here (they were on the right before) you can have more blocks of this type before falling of the screen ;)
I also changed a lot in the CSS-files regarding the spaces between blocks.
I updated gitlab, If you wanna keep the old version, backup or rename your current folder and clone the latest version.
If you experience css problems, make sure you've cleared your cache.
pvm
Domoticz version: 4.10538
Post by pvm »
EdKo66 wrote:Not sure if it's possible, but ..
This triggered me to display whats currently playing (not controlling something yet) based on Domoticz data, screenshot of the new part of the dashboard:
Updates to main.js :
			if(!sliding){
					-------keep default code here ------
					$('#LMSPlayers').html('');
					for(r in data.result){
						if(data.result[r]['HardwareType']=='Logitech Media Server'){
							if(data.result[r]['Status']=='Playing'){
								var html='<div class="transbg">';
								html +='<div class="col-md-1 no-padding">';
								html +='<em class="fa fa-music"></em>';
								html +='</div>';
								html +='<div class="col-md-11 no-padding">';
								html +='<strong class="title">'+data.result[r]['Name']+'</strong><br />';
								html +='<span class="h2">'+data.result[r]['Data']+'</span>';
								html +='</div>';
								$('#LMSPlayers').append(html);
						------ keep default code here ------
update to config.js, addition to titles part:
titles.LMSPlayers = 'Muziekspelers';
and the index.html addition (I've kept the part on traffic and buttons as default and added LMSPlayers in between)
						<div class="row containstraffic mb">
							<div class="titletraffic"><h3 class="transbg"></h3></div>
							<div id="traffic"></div>
						</div>
						<div class="row mb">
							<div class="titleLMSPlayers"><h3 class="transbg"></h3></div>
							<div id="LMSPlayers"></div>
						</div>
						<div class="row mb" id="buttons">
Somethings wrong when using this on a small screen, the data is not displayed... I'm not an html expert, guess I've made a mistake somehere
Is it possible to add this to the repository?
edit: (improvement could be to show the playing status based on the Status field by coloring the icon green? and not hiding the titles?)
pvm
Post by pvm »
EdKo66 / robgeerts
To control the player you need the following urls
Previous song
/json.htm?type=command&param=lmsmediacommand&idx=XXYYZZ&action=Rewind
Next song
/json.htm?type=command&param=lmsmediacommand&idx=XXYYZZ&action=Forward
Pause
/json.htm?type=command&param=lmsmediacommand&idx=XXYYZZ&action=Pause
Play
/json.htm?type=command&param=lmsmediacommand&idx=XXYYZZ&action=Play
Stop
/json.htm?type=command&param=lmsmediacommand&idx=XXYYZZ&action=Stop
Volume up
/json.htm?type=command&param=lmsmediacommand&idx=XXYYZZ&action=VolumeUp
Mute
/json.htm?type=command&param=lmsmediacommand&idx=XXYYZZ&action=Mute
Volume down
/json.htm?type=command&param=lmsmediacommand&idx=XXYYZZ&action=VolumeDown
Shuffle and repeat buttons have 'strange' behaviour it switches between non shuffling, shuffle by album and shuffle, for repeat: no repeat, repeat number, repeatplaylist, that's why I did not add those urls
Sorry, do not have time today to integrate this in the dashboard... I would also have to look into adding buttons and behaviour... EdKo66, can you help?
pvm
Post by pvm »
The slider does not work for my fibaro dimmer as its expecting a 0-100% value
Like 71%:
/json.htm?type=command&param=switchlight&idx=26&switchcmd=Set%20Level&level=71
information on this dimmer
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Set Level: 70 %",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 6,
         "HardwareName" : "Aeonlabs Z-wave stick",
         "HardwareTypeVal" : 21,
         "ID" : "00001301",
         "Image" : "Light",
         "LastUpdate" : "2017-03-30 00:34:26",
         "Level" : 70,
         "LevelInt" : 70,
         "Name" : "Dimmer2tst",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Status" : "Set Level: 70 %",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "Switch",
         "SwitchType" : "Dimmer",
         "SwitchTypeVal" : 7,
         "Timers" : "false",
         "TypeImg" : "dimmer",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "26"
Do you see an option to give dim levels between 0 and 100% for this device (and 0-16 for the device for which it has been developed by you)
Based on maxdimlevel?
ah... and compliments!! Nice dashboard!
Locked
