domoticz in synology as package! Available now.
Smiggel
Domoticz version: 4.9700
Re: domoticz in synology as package! Available now.
Post by Smiggel »
I installed version 3.0.5877-7 through the package manager. I added http://www.jadahl.com/domoticz_stable/ to my package sources and installed Domoticz on my DS214+ using DSM Beta 6.2. However, the package fails to start. Tried a reboot of my NAS, but still did not help.
Does anyone have a solution for me on how I can get the package to start? Really want to try out Domoticz.
Gravityz
Domoticz version: 2025.1
Post by Gravityz »
well you probably installed the wrong package.
you say you have a DS214+ with DSM beta 6.2 but you show the link which is the stable 5.2 version.
i think you need to uninstall everything(do areboot to make sure evrything starts up normal)
then just go to this page , download the armadaxp version and install that one
i think the 6.1 version will also run on the 6.2 beta dsm version
http://www.jadahl.com/domoticz_beta_6.1/
maybee Jumbotroll can compile the armadaxp 6.2 version for you.
you could also add this link to the packet manager to get the same result
http://www.jadahl.com/domoticz_stable_6.1/
again i think 6.1 will run on 6.2 beta but not 100%sure
Smiggel
Post by Smiggel »
Whoops, I see the link is wrong indeed. Installed the 6.1 version manually and that works. :-)
Now I can figure out how Domoticz works. :-)
jumbotroll
Post by jumbotroll »
Gravityz wrote: Friday 23 March 2018 20:15
I can confirm that DSM 6.1 version should work on DS214+ (armadaxp) because the toolchain and kernel is the same for armadaxp in DSM 6.2 Beta.
https://paypal.me/Jumbotroll
Jumbotroll
Smiggel
Post by Smiggel »
Yep, thanks again! It’s running. :-)
Gravityz
Post by Gravityz »
glad i could help.
You will find that Domoticz is not 100 perfect but you can customize a lot to make it 100% perfect with scripting.
teo1966
Post by teo1966 »
hello i have a problem 1 veld is red ( AANVOER-TEGEL )how is this possible
Screenshot-2018-3-24 Domoticz(1).jpg (77.49 KiB) Viewed 2737 times
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
Gravityz
Post by Gravityz »
it turns read when it is not seen for a while.
if you turn polling for this device on it will probably be solved
without polling the device needs to report the status either on a regular base(reporting) or on a change base.(if temp changes by a certain degree.)
if the reporting is turned of and you have a temp delta set for lets say 0.5 degrees and that temp never changes with a max of .5 degrees then nothing gets send to domoticz.
ofcourse there could be something wrong with the module itself
what module is this?
teo1966
Post by teo1966 »
this is Universele Binaire Sensor FIBARO FIBARO Temperatuur whit 4x Sensor ds18b20 Waterproof and Z-wave Plus USB Controller Batterij Z-stick AeonLabs
Release: 11
Codename: bullseye
Gravityz
Post by Gravityz »
check parameter 11 and 12
11 is about forcing to send a report(must be non 0)
12 is about the delta temperature (the change in temperature when a report is send(set to 1 or 2)
teo1966 wrote: Sunday 25 March 2018 16:19 this is Universele Binaire Sensor FIBARO FIBARO Temperatuur whit 4x Sensor ds18b20 Waterproof and Z-wave Plus USB Controller Batterij Z-stick AeonLabs
gijsje
Domoticz version: Stable
Post by gijsje »
Can the latest beta be made with python?
Thanks in advance
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
jumbotroll
gijsje wrote: Monday 26 March 2018 16:56 Can the latest beta be made with python?
Thanks in advance
For DSM 6.1 ?
Jumbotroll
gijsje
Post by gijsje »
yes please
jumbotroll
gijsje wrote: Monday 26 March 2018 17:06yes please
It take a couple of hour to compile all versions, what version do you want and I can build that version first...
Jumbotroll
gijsje
Post by gijsje »
it is for the DS218+ so i think it is the Appololake?
jumbotroll
gijsje wrote: Monday 26 March 2018 17:23 it is for the DS218+ so i think it is the Appololake?
Yes it's Apollolake.
Check here in 20 min..
http://www.jadahl.com/domoticz_beta_6.1_python/
Jumbotroll
gijsje
Post by gijsje »
Thanks very much
gijsje
Post by gijsje »
made a small donation for some beers
Thanks for all the work
jumbotroll
gijsje wrote: Monday 26 March 2018 17:31 made a small donation for some beers
Thanks :D
Apollolake is updated.
Jumbotroll
mcwieger
Domoticz version: 2020.1
Post by mcwieger »
After updating DSM to 6.1.5-15254 Update 1, Domoticz has become unresponsive. I can open Domoticz, when pressing buttons they respond, but the actual devices don't switch on or off. Anyone else experiencing this? I have a DS414 (ArmadaXP).
I moved to HomeAssistant. It was fun while it lasted!
