domoticz in synology as package! Available now.
Smiggel
- Domoticz version: 4.9700
I installed version 3.0.5877-7 through the package manager. I added http://www.jadahl.com/domoticz_stable/ to my package sources and installed Domoticz on my DS214+ using DSM Beta 6.2. However, the package fails to start. Tried a reboot of my NAS, but still did not help.
Does anyone have a solution for me on how I can get the package to start? Really want to try out Domoticz.
Gravityz
- Domoticz version: 2026.3
well you probably installed the wrong package.
you say you have a DS214+ with DSM beta 6.2 but you show the link which is the stable 5.2 version.
i think you need to uninstall everything(do areboot to make sure evrything starts up normal)
then just go to this page , download the armadaxp version and install that one
i think the 6.1 version will also run on the 6.2 beta dsm version
http://www.jadahl.com/domoticz_beta_6.1/
maybee Jumbotroll can compile the armadaxp 6.2 version for you.
you could also add this link to the packet manager to get the same result
http://www.jadahl.com/domoticz_stable_6.1/
again i think 6.1 will run on 6.2 beta but not 100%sure
Smiggel
Whoops, I see the link is wrong indeed. Installed the 6.1 version manually and that works.
Now I can figure out how Domoticz works.
- jumbotroll
I can confirm that DSM 6.1 version should work on DS214+ (armadaxp) because the toolchain and kernel is the same for armadaxp in DSM 6.2 Beta.
https://paypal.me/Jumbotroll
Jumbotroll
Jumbotroll
Smiggel
Yep, thanks again! It’s running.
Gravityz
glad i could help.
You will find that Domoticz is not 100 perfect but you can customize a lot to make it 100% perfect with scripting.
teo1966
- Domoticz version: 2025.1
hello i have a problem 1 veld is red ( AANVOER-TEGEL )how is this possible
- Screenshot-2018-3-24 Domoticz(1).jpg (77.49 KiB) Viewed 3363 times
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
Release: 11
Codename: bullseye
Gravityz
it turns read when it is not seen for a while.
if you turn polling for this device on it will probably be solved
without polling the device needs to report the status either on a regular base(reporting) or on a change base.(if temp changes by a certain degree.)
if the reporting is turned of and you have a temp delta set for lets say 0.5 degrees and that temp never changes with a max of .5 degrees then nothing gets send to domoticz.
ofcourse there could be something wrong with the module itself
what module is this?
teo1966
this is Universele Binaire Sensor FIBARO FIBARO Temperatuur whit 4x Sensor ds18b20 Waterproof and Z-wave Plus USB Controller Batterij Z-stick AeonLabs
Release: 11
Codename: bullseye
Release: 11
Codename: bullseye
Gravityz
check parameter 11 and 12
11 is about forcing to send a report(must be non 0)
12 is about the delta temperature (the change in temperature when a report is send(set to 1 or 2)
teo1966 wrote: Sunday 25 March 2018 16:19 this is Universele Binaire Sensor FIBARO FIBARO Temperatuur whit 4x Sensor ds18b20 Waterproof and Z-wave Plus USB Controller Batterij Z-stick AeonLabs
- gijsje
- Domoticz version: Stable
Can the latest beta be made with python?
Thanks in advance
Thanks in advance
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
- jumbotroll
For DSM 6.1 ?
Jumbotroll
Jumbotroll
- gijsje
yes please
- jumbotroll
It take a couple of hour to compile all versions, what version do you want and I can build that version first...
Jumbotroll
Jumbotroll
- gijsje
it is for the DS218+ so i think it is the Appololake?
- jumbotroll
Jumbotroll
Jumbotroll
- gijsje
Thanks very much
- gijsje
made a small donation for some beers
Thanks for all the work
- jumbotroll
Thanksgijsje wrote: Monday 26 March 2018 17:31 made a small donation for some beers
Apollolake is updated.
Jumbotroll
Jumbotroll
mcwieger
- Domoticz version: 2020.1
After updating DSM to 6.1.5-15254 Update 1, Domoticz has become unresponsive. I can open Domoticz, when pressing buttons they respond, but the actual devices don't switch on or off. Anyone else experiencing this? I have a DS414 (ArmadaXP).
I moved to HomeAssistant. It was fun while it lasted!
