SolarEdge via LAN interface
rogerthn
Re: SolarEdge via LAN interface
Post by rogerthn »
I did try SolarEdge_ModbusTCP on bookworm with no luck :( :(
I ended up using pymodbus-2.4.0, pyserial-3.4 and solaredge_modbus-0.6.5 that I did have running on buster.
On bookworm as normal user
mv /home/USER/.local/lib/python3.11/site-packages/* /home/USER/SAVED_site-packages/
scp -pr pi@buster:/home/pi/.local/lib/python3.7/site-packages/pymodbus ~/.local/lib/python3.11/site-packages/
scp -pr pi@buster:/home/pi/.local/lib/python3.7/site-packages/pymodbus-2.4.0.dist-info ~/.local/lib/python3.11/site-packages/
scp -pr pi@buster:/home/pi/.local/lib/python3.7/site-packages/pyserial-3.4.dist-info ~/.local/lib/python3.11/site-packages/
scp -pr pi@buster:/home/pi/.local/lib/python3.7/site-packages/serial ~/.local/lib/python3.11/site-packages/
scp -pr pi@buster:/home/pi/.local/lib/python3.7/site-packages/solaredge_modbus ~/.local/lib/python3.11/site-packages/
scp -pr pi@buster:/home/pi/.local/lib/python3.7/site-packages/solaredge_modbus-0.6.5.dist-info ~/.local/lib/python3.11/site-packages/
Total size of site packages 3.1MB, compressed 650kB.
Please let me know if I should try to upload the tarball
Good luck
jannl
Domoticz version: 2026.1.x
Post by jannl »
This is how I got the modbus connection working, in buster.
pip3 install modbus==0.8.0
pip3 uninstall pymodbus
pip3 install pymodbus==3.6.9
The code used runs in my customstartup.sh I use in docker.
The problem for me is more computing the correct value for raw sun production, escpecially when using a battery and ev-charger. There is actually no value in the modbus registers for the raw sun production. But I am getting there and may be I will take the occasional miscalculculation for granted.
madpatrick
Post by madpatrick »
Hi Guys,
I have found this plugin which works with my Soleradge (and also of JvdZ)
https://github.com/addiejanssen/domotic ... tcp-plugin
This is how i got it to work
git clone https://github.com/addiejanssen/domoticz-solaredge-modbustcp-plugin
pip3 install -r requirements.txt
pip3 install -U pymodbus==2.5.3
Restart your domoticz and check your devices
Maybe somebody know how to use the latest version of pymodbus instead of downgrading ?
Using the latetst version give the following error
No module named 'pymodbus.client.sync'
jannl
Post by jannl »
It works here with pymodbus 3.6.9 as is in my previous post.
jvdz
Domoticz version: 4.107
Post by jvdz »
jannl wrote: Tuesday 06 May 2025 9:35 It works here with pymodbus 3.6.9 as is in my previous post.
That indeed works too! Thanks for sharing.
EDIT: When you update requirements.txt in the plugin directory to:
pymodbus==3.6.9
solaredge_modbus==0.8.0
and then run : sudo pip3 install -r /home/pi/domoticz/plugins/SolarEdge/requirements.txt
It will also be fine as the newer version of pymodbus is uninstalled in favor of 3.6.9
madpatrick
Hi Guys,
I've a strange daily value which i don't see in the reports or logs
2025-05-25 20_00_05-Domoticz - Overige.png (13.73 KiB) Viewed 5973 times
2025-05-25 20_03_47-Domoticz - Devices_891_Log.png (7.76 KiB) Viewed 5972 times
Any idea where this is coming from or how to correct?
I have seen this reported more before. Seems to be an error on the SolarEdge side suddenly reporting strange values.
madpatrick
Are you sure ?
My Toon is also givin a large number and this is readingout the P1
2025-05-31 08_50_43-Domoticz - Overige.png (8.73 KiB) Viewed 5817 times
And i installed the plugin on an old Version: 2023.2 (build 15462)
Which looks correct
2025-05-31 08_51_06-Domoticz - Overige.png (9.41 KiB) Viewed 5817 times
SunnyDomoticz
Post by SunnyDomoticz »
madpatrick wrote: Saturday 31 May 2025 8:22 Are you sure ?
Which looks correct
Isn't this the total production of the PV installation? (Labeled wrong)
SunnyDomoticz
Did anyone get the AddieJanssen plugin working on Pi OS Bookworm? Whatever I try I keep getting the × This environment is externally managed message.
The same happens when I try the sunspec_ardexa method.
SunnyDomoticz wrote: Saturday 31 May 2025 9:24 Did anyone get the AddieJanssen plugin working on Pi OS Bookworm? Whatever I try I keep getting the × This environment is externally managed message.
See this section in the wiki https://wiki.domoticz.com/Using_Python_ ... ules_fails
Bookworm handles Python modules differently then before.
See also the following link where one of the plugin authors explains the issue https://zigbeefordomoticz.github.io/wik ... alEnv.html
SunnyDomoticz
Thank you, I actually got the message after using the second tutorial you posted: "Successfully installed pymodbus-3.9.2 solaredge_modbus-0.7"!
I can find SolarEdge ModbusTCP in hardware and when adding I get a message stating the devices are added to the devices, but none show up. Any tips?
imautohuttraeger
Domoticz version: latest
Post by imautohuttraeger »
SunnyDomoticz wrote: Sunday 01 June 2025 20:07 Thank you, I actually got the message after using the second tutorial you posted: "Successfully installed pymodbus-3.9.2 solaredge_modbus-0.7"!
I had the same problem and solved it by @jannl 's instruction in above post from May 05.
viewtopic.php?p=326370#p326370
Quoting:
Post by jannl » Monday 05 May 2025 14:20
Stop, look and listen.
imautohuttraeger
Has anyone managed to get the Solaredge batterie via Modbus TCP? Or any other solution to get the batterie data and integrated intoto the energy dashboard?
Quest24
Domoticz version: 2025-2
Post by Quest24 »
I have it working on my pi-5 running 64 bit bookworm using the instruction above.
I extended all python instructions with --break-system-packages
This is the dirty way to ignore the 'venv' errors
