when not sure where to post, post here and mods will move it to right forum .
Moderators: leecollings , remb0
rogerthn
Posts: 28 Joined: Thursday 26 July 2018 12:07
Post
by rogerthn » Monday 05 May 2025 14:01
I did try SolarEdge_ModbusTCP on bookworm with no luck
I ended up using pymodbus-2.4.0, pyserial-3.4 and solaredge_modbus-0.6.5 that I did have running on buster.
On bookworm as normal user
mv /home/USER/.local/lib/python3.11/site-packages/* /home/USER/SAVED_site-packages/
scp -pr pi@buster:/home/pi/.local/lib/python3.7/site-packages/pymodbus ~/.local/lib/python3.11/site-packages/
scp -pr pi@buster:/home/pi/.local/lib/python3.7/site-packages/pymodbus-2.4.0.dist-info ~/.local/lib/python3.11/site-packages/
scp -pr pi@buster:/home/pi/.local/lib/python3.7/site-packages/pyserial-3.4.dist-info ~/.local/lib/python3.11/site-packages/
scp -pr pi@buster:/home/pi/.local/lib/python3.7/site-packages/serial ~/.local/lib/python3.11/site-packages/
scp -pr pi@buster:/home/pi/.local/lib/python3.7/site-packages/solaredge_modbus ~/.local/lib/python3.11/site-packages/
scp -pr pi@buster:/home/pi/.local/lib/python3.7/site-packages/solaredge_modbus-0.6.5.dist-info ~/.local/lib/python3.11/site-packages/
Total size of site packages 3.1MB, compressed 650kB.
Please let me know if I should try to upload the tarball
Good luck
jannl
Posts: 871 Joined: Thursday 02 October 2014 6:36
Domoticz version: 2026.1.x
Post
by jannl » Monday 05 May 2025 14:20
This is how I got the modbus connection working, in buster.
pip3 install modbus==0.8.0
pip3 uninstall pymodbus
pip3 install pymodbus==3.6.9
The code used runs in my customstartup.sh I use in docker.
The problem for me is more computing the correct value for raw sun production, escpecially when using a battery and ev-charger. There is actually no value in the modbus registers for the raw sun production. But I am getting there and may be I will take the occasional miscalculculation for granted.
madpatrick
Posts: 900 Joined: Monday 26 December 2016 12:17
Post
by madpatrick » Monday 05 May 2025 16:59
Hi Guys,
I have found this plugin which works with my Soleradge (and also of JvdZ)
https://github.com/addiejanssen/domotic ... tcp-plugin
This is how i got it to work
git clone https://github.com/addiejanssen/domoticz-solaredge-modbustcp-plugin
Restart your domoticz and check your devices
Maybe somebody know how to use the latest version of pymodbus instead of downgrading ?
Using the latetst version give the following error
No module named 'pymodbus.client.sync'
jannl
Post
by jannl » Tuesday 06 May 2025 9:35
It works here with pymodbus 3.6.9 as is in my previous post.
jvdz
Posts: 2486 Joined: Tuesday 30 December 2014 19:25
Domoticz version: 4.107
Post
by jvdz » Tuesday 06 May 2025 10:08
jannl wrote: Tuesday 06 May 2025 9:35
That indeed works too! Thanks for sharing.
EDIT: When you update requirements.txt in the plugin directory to:
pymodbus==3.6.9
solaredge_modbus==0.8.0
and then run : sudo pip3 install -r /home/pi/domoticz/plugins/SolarEdge/requirements.txt
It will also be fine as the newer version of pymodbus is uninstalled in favor of 3.6.9
madpatrick
Post
by madpatrick » Sunday 25 May 2025 20:03
Hi Guys,
I've a strange daily value which i don't see in the reports or logs
2025-05-25 20_00_05-Domoticz - Overige.png (13.73 KiB) Viewed 6135 times
2025-05-25 20_03_47-Domoticz - Devices_891_Log.png (7.76 KiB) Viewed 6134 times
Any idea where this is coming from or how to correct?
Posts: 7029 Joined: Monday 28 January 2019 18:48
Domoticz version: 2026.3
Post
by waltervl » Sunday 25 May 2025 23:52
I have seen this reported more before. Seems to be an error on the SolarEdge side suddenly reporting strange values.
madpatrick
Post
by madpatrick » Saturday 31 May 2025 8:22
Are you sure ?
My Toon is also givin a large number and this is readingout the P1
2025-05-31 08_50_43-Domoticz - Overige.png (8.73 KiB) Viewed 5979 times
And i installed the plugin on an old Version: 2023.2 (build 15462)
Which looks correct
2025-05-31 08_51_06-Domoticz - Overige.png (9.41 KiB) Viewed 5979 times
SunnyDomoticz
Posts: 7 Joined: Friday 02 May 2025 17:51
Post
by SunnyDomoticz » Saturday 31 May 2025 9:15
madpatrick wrote: Saturday 31 May 2025 8:22
Are you sure ?
Which looks correct
Isn't this the total production of the PV installation? (Labeled wrong)
SunnyDomoticz
Post
by SunnyDomoticz » Saturday 31 May 2025 9:24
Did anyone get the AddieJanssen plugin working on Pi OS Bookworm ? Whatever I try I keep getting the × This environment is externally managed message.
The same happens when I try the sunspec_ardexa method.
Post
by waltervl » Saturday 31 May 2025 12:15
SunnyDomoticz wrote: Saturday 31 May 2025 9:24
See this section in the wiki
https://wiki.domoticz.com/Using_Python_ ... ules_fails
Bookworm handles Python modules differently then before.
See also the following link where one of the plugin authors explains the issue
https://zigbeefordomoticz.github.io/wik ... alEnv.html
SunnyDomoticz
Post
by SunnyDomoticz » Sunday 01 June 2025 20:07
Thank you, I actually got the message after using the second tutorial you posted: "Successfully installed pymodbus-3.9.2 solaredge_modbus-0.7"!
I can find SolarEdge ModbusTCP in hardware and when adding I get a message stating the devices are added to the devices, but none show up. Any tips?
imautohuttraeger
Posts: 448 Joined: Saturday 14 March 2020 13:40
Domoticz version: latest
Post
by imautohuttraeger » Wednesday 04 June 2025 10:18
SunnyDomoticz wrote: Sunday 01 June 2025 20:07
I had the same problem and solved it by @jannl 's instruction in above post from May 05.
viewtopic.php?p=326370#p326370
Quoting:
Post by jannl » Monday 05 May 2025 14:20
Stop, look and listen.
imautohuttraeger
Post
by imautohuttraeger » Wednesday 04 June 2025 11:46
Has anyone managed to get the Solaredge batterie via Modbus TCP? Or any other solution to get the batterie data and integrated intoto the energy dashboard?
Quest24
Posts: 15 Joined: Tuesday 17 November 2020 22:00
Domoticz version: 2025-2
Post
by Quest24 » Friday 12 December 2025 14:44
I have it working on my pi-5 running 64 bit bookworm using the instruction above.
I extended all python instructions with --break-system-packages
This is the dirty way to ignore the 'venv' errors
