Derik
Posts: 1605 Joined: Friday 18 October 2013 23:33
Post
by Derik » Monday 12 September 2016 18:27
corbin wrote: Derik wrote:
Only i do not understand the ssdp protocol? Working with putty?
Or how do i send the request.
some one understand this..?
Are you able to run a command like this?
printf '{"id":1,"method":"toggle","params":[]}\r\n' > /dev/tcp/192.168.0.2/55443
change 192.168.0.2 to the IP address of your bulb. Also check that you have developer mode enabled on the bulb. The quotes may need escaping, I'd check myself but don't have a Linux install handy.
Corbin...
If you planed a hardware plugin... [ love that option..xxxx]
Only i do not understand the methode..
In my browser?
in putty?
Or in a linux [ and then? ]
Sorry for my dombo questions
TwoEasy
Posts: 13 Joined: Friday 09 September 2016 18:29
Post
by TwoEasy » Monday 12 September 2016 23:18
I found another temporary way to control the bulbs. Not the most effective or smoothest way to do it but it works..
I have a old Android tablet that I use as a on the wall dashboard, always connected to a charger and always at home, connected to wifi. I have tasker installed. So I made a virtual switch in domoticz that sends a on/off message via pushbullet that my Android tablet listen for and then runs the wanted command on the wanted bulb.
Like I said, dirty, not local but It works for now I think. (not actully tested yet)
corbin
Posts: 463 Joined: Saturday 20 August 2016 22:57
Post
by corbin » Tuesday 13 September 2016 12:00
Derik wrote:
Corbin...
In my browser?
in putty?
try this from Linux command line (terminal)
echo -ne '{"id":1,"method":"toggle","params":[]}\r\n' | nc -w1 192.168.5.19 55443
corbin
Post
by corbin » Friday 30 September 2016 12:46
Any Windows Domoticz users want to test my Yeelight code?
corbin
Post
by corbin » Monday 03 October 2016 1:06
TwoEasy
Post
by TwoEasy » Sunday 09 October 2016 10:00
Oh amazing Corbin! Really awesome! Unfortunately I use Raspberry pi so I cannot test it, I can happily test it if possible on pi
Derik
Post
by Derik » Sunday 09 October 2016 11:06
Looks there are people that have supported the yeelight in windows domoticz....
TwoEasy
Post
by TwoEasy » Sunday 09 October 2016 11:10
Derik wrote: Looks there are people that have supported the yeelight in windows domoticz....
Yeah, as you can see two posts up it is Corbin who created this.
Derik
Post
by Derik » Sunday 09 October 2016 11:18
TwoEasy wrote: Derik wrote: Looks there are people that have supported the yeelight in windows domoticz....
O real?
Will try a linux version... [ have bulb]
Only i do not understand the way i should use:
Derik
Post
by Derik » Sunday 09 October 2016 17:42
Did install the last Windows Beta, on my NUC
No Yeelight?
corbin
Post
by corbin » Monday 10 October 2016 7:48
Derik wrote: Did install the last Windows Beta, on my NUC
No Yeelight?
Derik, try this link - compiled for Windows.
https://1drv.ms/f/s!AiVyh7yRnMKPgT1s4nzWDgJX7UaO
The code on github probably isn't working right now - I am rewriting it to work in Linux.
Derik
Post
by Derik » Monday 10 October 2016 18:50
corbin wrote: Derik wrote: Did install the last Windows Beta, on my NUC
No Yeelight?
Did install this version on my pc.
Ad the yeelight..
Only see no thing happend?
While my light is on and visible in my lan.
What do i need to do more?
corbin
Post
by corbin » Monday 10 October 2016 20:45
Have you enabled development mode on your Yeelight?
Derik
Post
by Derik » Monday 10 October 2016 20:54
corbin wrote: Have you enabled development mode on your Yeelight?
mmm
I do only have the bulb and a android app?
Is that ok?
Where can i find this mode?
corbin
Post
by corbin » Monday 10 October 2016 20:58
Use the main Yeelight app, link on top right to settings
corbin
Post
by corbin » Monday 10 October 2016 21:07
Yes the Android app is what I use, but the link to developer mode is only there in the main Yeelight app, it isn't in shortcuts to individual lights.
Derik
Post
by Derik » Monday 10 October 2016 21:22
Got him
Only have a other problem..
My X64 [ windows] nuc is not working as a slave for my master.. [ endium problem or something ]
Why not in Beta Windows?
corbin
Post
by corbin » Monday 10 October 2016 21:29
Derik wrote: Got him
Awesome!
With Windows not working as a slave, yeah is to do with big/little endian - not going to work.
But, I almost have the Linux version working...
Derik
Post
by Derik » Monday 10 October 2016 21:42
corbin wrote: With Windows not working as a slave, yeah is to do with big/little endian - not going to work.
What is that for problem endian... [ when i run Domoticz on X86 is that better? ]
When you have linux let me now i test...[ when i have time ]
Are all Yeelights working?
Like the strips and the small bulbs?
http://www.ebay.com/itm/Original-Xiaomi ... SwHoFXs-G7
Great JOB!!!
