[Plugin now available in Beta] Help with Yeelight Bulb
Derik
Re: Help with Yeelight Bulb
Post by Derik »
corbin wrote:
Derik wrote: Only i do not understand the ssdp protocol? Working with putty?
Or how do i send the request.
some one understand this..?
Are you able to run a command like this?
printf '{"id":1,"method":"toggle","params":[]}\r\n' > /dev/tcp/192.168.0.2/55443
change 192.168.0.2 to the IP address of your bulb. Also check that you have developer mode enabled on the bulb. The quotes may need escaping, I'd check myself but don't have a Linux install handy.
Corbin...
If you planed a hardware plugin... [ love that option..xxxx]
Only i do not understand the methode..
In my browser?
in putty?
Or in a linux [ and then? ]
Sorry for my dombo questions
TwoEasy
Post by TwoEasy »
I found another temporary way to control the bulbs. Not the most effective or smoothest way to do it but it works..
I have a old Android tablet that I use as a on the wall dashboard, always connected to a charger and always at home, connected to wifi. I have tasker installed. So I made a virtual switch in domoticz that sends a on/off message via pushbullet that my Android tablet listen for and then runs the wanted command on the wanted bulb.
Like I said, dirty, not local but It works for now I think. (not actully tested yet)
farhanito
Post by farhanito »
I you want local, i think this tasker plugin will work better
https://play.google.com/store/apps/deta ... .httpevent
corbin
Post by corbin »
Derik wrote: Corbin...
In my browser?
in putty?
try this from Linux command line (terminal)
echo -ne '{"id":1,"method":"toggle","params":[]}\r\n' | nc -w1 192.168.5.19 55443
corbin
Post by corbin »
Any Windows Domoticz users want to test my Yeelight code?
corbin
Post by corbin »
TwoEasy
Post by TwoEasy »
Oh amazing Corbin! Really awesome! Unfortunately I use Raspberry pi so I cannot test it, I can happily test it if possible on pi
Derik
Post by Derik »
Looks there are people that have supported the yeelight in windows domoticz....
TwoEasy
Post by TwoEasy »
  • u
Derik wrote:Looks there are people that have supported the yeelight in windows domoticz....
Yeah, as you can see two posts up it is Corbin who created this.
Derik
Post by Derik »
TwoEasy wrote:
  • u
O real? :D :D :D
Will try a linux version... [ have bulb]
Only i do not understand the way i should use:
Derik
Post by Derik »
Did install the last Windows Beta, on my NUC
No Yeelight?
corbin
Post by corbin »
Derik wrote:Did install the last Windows Beta, on my NUC
No Yeelight?
Derik, try this link - compiled for Windows. https://1drv.ms/f/s!AiVyh7yRnMKPgT1s4nzWDgJX7UaO
The code on github probably isn't working right now - I am rewriting it to work in Linux.
Derik
Post by Derik »
No Yeelight?
Did install this version on my pc.
Ad the yeelight..
Only see no thing happend?
While my light is on and visible in my lan.
What do i need to do more?
corbin
Post by corbin »
Have you enabled development mode on your Yeelight?
Derik
Post by Derik »
corbin wrote:Have you enabled development mode on your Yeelight?
mmm
I do only have the bulb and a android app?
Is that ok?
Where can i find this mode?
corbin
Post by corbin »
Use the main Yeelight app, link on top right to settings
corbin
Post by corbin »
Yes the Android app is what I use, but the link to developer mode is only there in the main Yeelight app, it isn't in shortcuts to individual lights.
Derik
Post by Derik »
Got him :-)
Only have a other problem..
My X64 [ windows] nuc is not working as a slave for my master.. [ endium problem or something ]
Why not in Beta Windows?
corbin
Post by corbin »
Derik wrote:Got him :-)
Awesome!
With Windows not working as a slave, yeah is to do with big/little endian - not going to work.
But, I almost have the Linux version working...
Derik
Post by Derik »
corbin wrote:With Windows not working as a slave, yeah is to do with big/little endian - not going to work.
What is that for problem endian... [ when i run Domoticz on X86 is that better? ]
When you have linux let me now i test...[ when i have time ]
Are all Yeelights working?
Like the strips and the small bulbs?
http://www.ebay.com/itm/Original-Xiaomi ... SwHoFXs-G7
Great JOB!!!
