Real-time solar data : azimuth, Altitude, Lux sensor... [closed]
Locked
Egregius
Domoticz version: v2024.7
Re: Real-time solar data : azimuth, Altitude, Lux sensor...
Post by Egregius »
Is wunderground pretty accurate and reliable?
Openweathermap isn't. I get readings like 18.6°, one minute later 19.2, then again 18.6, again 19.2,...
During daytime I now use forecast.io but the number of request is limited to 1000 per day for a free account.
trixwood
Post by trixwood »
I was looking at cloud sensors... this popped up:
http://www.noao.edu/staff/gillespie/pro ... ector.html
could it work?
it looks like all it is, is this sensor https://www.adafruit.com/product/1330 sandwiched between two aluminium plates.
And then measure and mapping out the voltages to actually readings.
Egregius
Post by Egregius »
You also have cloud prediction at forecast.io and openweathermap.
trixwood
Post by trixwood »
Not everybody have a working internet connection on the location they run their stuff... :?
http://www.farnham-as.co.uk/2013/04/bui ... ud-sensor/
http://downloads.deusm.com/designnews/2 ... ctions.pdf
Going to build this one:
http://www.chrisramsay.co.uk/posts/2014 ... -part-one/
Derik
Post by Derik »
still something alive..
 2016-08-21 19:05:01.317 LUA: Lat: 56.84249878Long: 5.85277796Alt: 22.00000000[/quote]
What do i need to do with data?
Fill in  22.00000000
Sensor still red..
Only my api [ i reset him] is counting..:
Where can i search ...
[attachment=0]ScreenShot210.jpg[/attachment]
trixwood
Post by trixwood »
you can look up the long, lat and altitude here, I think: http://elevationmap.net
Derik
Post by Derik »
trixwood wrote:From the original wiki
  --  API Wunderground
       local config=assert(io.popen('curl http://api.wunderground.com/api/'..wuAPIkey..'/conditions/q/'..countryCode..'/'..city..'.json'))
       local location = config:read('*all')
       config:close()
       local jsonLocation = json:decode(location)
       if( DEBUG == 1) then
          local latitude = jsonLocation.current_observation.display_location.latitude
          local longitude = jsonLocation.current_observation.display_location.longitude
          local altitude = jsonLocation.current_observation.display_location.elevation
          print('Lat: '..latitude..'Long: '..longitude..'Alt: '..altitude)
       relativePressure = jsonLocation.current_observation.pressure_mb   -- if you have an another way to get the Pressure, (local barometer ...) then you may optimize the script and avoid the call to api.wunderground)
without weathe underground you need to repalce that with:
relativePressure = 1012
or read it from a pressure sensor...
That yould fix your nil... now I am also stuck on the cloud coverage not coming in.... :-)
How can i read it from a pressure sensor?
And where and How to fill in?
When i got this script working i going to drink a very large BEER...
trixwood
Post by trixwood »
    --[[      Virtual Lux sensor and other real-time solar data
    ~/domoticz/scripts/lua/script_time_SolarSensor.lua
    -- Autors  ----------------------------------------------------------------
    V1.0 - Sébastien Joly - Great original work
    V1.1 - Neutrino - Adaptation to Domoticz
    V1.2 - Jmleglise - An acceptable approximation of the lux below 1° altitude for Dawn and dusk + translation + several changes to be more userfriendly.
    V1.3 - Jmleglise - keep the time of black night in lasptUpdate
    -- Variables to customize ------------------------------------------------
       local city = "Paris"            -- Your city for Wunderground API
       local countryCode = "FR"            -- Your country code for Wunderground API
       local idxLux ='72'            -- Your virtual Lux Device ID
       local idxSolarAzimuth ='85'       -- Your virtual Azimuth Device ID
       local idxSolarAltitude ='84'       -- Your virtual Solar Altitude Device ID
       local idxUserVarOcta='2'           -- Your user variable ID , named octa
       local wuAPIkey = "xxxxxxxxe5db6e4c" -- Your Weather Underground API Key
       local latitude = 48.xxxx88        -- your home
       local longitude = 2.xxxx00       -- your home
       local altitude = 27              -- Your home altitude : run once in debug = 1 to found your altitude in Log and write it here
       local WMOID = '07145'    -- Your nearest SYNOP Station for ogimet (to get Cloud layer). Run once with debug=1 to get it in the log. (or, better, choose it there : http://www.ogimet.com/gsynop_nav.phtml.en )
       local DEBUG = 0             -- 0 , 1 for domoticz log , 2 for file log
       -- and customize the URL of api.wunderground around line 104 according to your country.
    -- Below , edit at your own risk ------------------------------------------
    function leapYear(year)
       return year%4==0 and (year%100~=0 or year%400==0)
    function split(s, delimiter)
       result = {};
       for match in (s..delimiter):gmatch("(.-)"..delimiter) do
         table.insert(result, match);
       return result;
    function round(num, dec)
       if num == 0 then
         return 0
         local mult = 10^(dec or 0)
         return math.floor(num * mult + 0.5) / mult
    time = os.date("*t")
    if  ((time.min % 5)==0)  then -- Run every 5 minutes. Check the wundergroud API limitation before changing this
       json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()  -- For Linux
       --json = (loadfile "D:\\Domoticz\\scripts\\lua\\json.lua")()  -- For Windows
       local indexArray=0
       local arbitraryTwilightLux=4.74     -- W/m²  egal 600 Lux
       local constantSolarRadiation = 1361 -- Solar Constant W/m²
       if (uservariables['octa'] == nil) then print("Error : Did you create the Uservariable octa ?") end
       --  API Wunderground
       config:close()
       local year = os.date("%Y")
       local numOfDay = os.date("%j")
       if  leapYear(year) == true then
          nbDaysInYear = 366  -- How many days in the year ?
          nbDaysInYear = 365
       angularSpeed = 360/365.25
       local Declinaison = math.deg(math.asin(0.3978 * math.sin(math.rad(angularSpeed) *(numOfDay - (81 - 2 * math.sin((math.rad(angularSpeed) * (numOfDay - 2))))))))
       timeDecimal = (os.date("!%H") + os.date("!%M") / 60) -- Coordinated Universal Time  (UTC)
       solarHour = timeDecimal + (4 * longitude / 60 )    -- The solar Hour
       hourlyAngle = 15 * ( 12 - solarHour )          -- hourly Angle of the sun
       sunAltitude = math.deg(math.asin(math.sin(math.rad(latitude))* math.sin(math.rad(Declinaison)) + math.cos(math.rad(latitude)) * math.cos(math.rad(Declinaison)) * math.cos(math.rad(hourlyAngle))))-- the height of the sun in degree, compared with the horizon
       local azimuth = math.acos((math.sin(math.rad(Declinaison)) - math.sin(math.rad(latitude)) * math.sin(math.rad(sunAltitude))) / (math.cos(math.rad(latitude)) * math.cos(math.rad(sunAltitude) ))) * 180 / math.pi -- deviation of the sun from the North, in degree
       local sinAzimuth = (math.cos(math.rad(Declinaison)) * math.sin(math.rad(hourlyAngle))) / math.cos(math.rad(sunAltitude))
       if(sinAzimuth<0) then azimuth=360-azimuth end
       sunstrokeDuration = math.deg(2/15 * math.acos(- math.tan(math.rad(latitude)) * math.tan(math.rad(Declinaison)))) -- duration of sunstroke in the day . Not used in this calculation.
       RadiationAtm = constantSolarRadiation * (1 +0.034 * math.cos( math.rad( 360 * numOfDay / nbDaysInYear )))    -- Sun radiation  (in W/m²) in the entrance of atmosphere.
       -- Coefficient of mitigation M
       absolutePressure = relativePressure - round((altitude/ 8.3),1) -- hPa
       sinusSunAltitude = math.sin(math.rad(sunAltitude))
       M0 = math.sqrt(1229 + math.pow(614 * sinusSunAltitude,2)) - 614 * sinusSunAltitude
       M = M0 * relativePressure/absolutePressure
       if (DEBUG == 1) then
          print('<b style="color:Blue"==============  SUN  LOG ==================</b>')
          print(os.date("%Y-%m-%d %H:%M:%S", os.time()))
          print(city .. ", latitude:" .. latitude .. ", longitude:" .. longitude)
          print("Home altitude = " .. tostring(altitude) .. " m")
          print("number Of Day = " .. numOfDay)
          if nbDaysInYear==366 then
             print(year .." is a leap year !")
             print(year.." is not a leap year")
          print("Angular Speed = " .. angularSpeed .. " per day")
          print("Declinaison = " .. Declinaison .. "°")
          print("Universel Coordinated Time (UTC)".. timeDecimal .." H.dd")
          print("Solar Hour ".. solarHour .." H.dd")
          print("Altitude of the sun = " .. sunAltitude .. "°")
          print("Angular hourly = ".. hourlyAngle .. "°")
          print("Azimuth of the sun = " .. azimuth .. "°")
          print("Duration of the sunstroke of the day = " .. round(sunstrokeDuration,2) .." H.dd")  -- not used
          print("Radiation max en atmosphere = " .. round(RadiationAtm,2) .. " W/m²")
          print("Local relative pressure = " .. relativePressure .. " hPa")
          print("Absolute pressure in atmosphere = " .. absolutePressure .. " hPa")
          print("Coefficient of mitigation M = " .. M .." M0:"..M0)
       -- Get  SYNOP  message from  Ogimet web  site
       hourUTCminus1 = os.date("!%H")-1
       if string.len(hourUTCminus1) == 1 then
          hourUTCminus1 = "0" .. hourUTCminus1
       UTC = os.date("%Y%m%d").. hourUTCminus1.."00" -- os.date("!%M")
          local WMOID = jsonLocation.current_observation.display_location.wmo
       cmd='curl "http://www.ogimet.com/cgi-bin/getsynop?block='..WMOID..'&begin='..UTC..'"'
       if( DEBUG == 1) then print(cmd) end
       local ogimet=assert(io.popen(cmd))
       local synop = ogimet:read('*all')
       ogimet:close()
       if( DEBUG == 1) then print('ogimet:'..synop) end
       if string.find(synop,"Status: 500") == nil
       then
          rslt = split(synop,",")
          CodeStation = rslt[1]
          rslt = split(synop, " "..CodeStation.. " ")
          Trame = string.gsub(rslt[2], "=", "")
          Trame = CodeStation .." ".. Trame
          rslt = split(Trame, " ")
          Octa = string.sub(rslt[3], 1, 1)  -- 3rd char is the cloud layer.  0=no cloud , 1-8= cloudy from 1 to 8 max , 9 =Fog , / = no data
          if Octa == "/" then   -- not defined ? take the previous value
             Octa = uservariables['octa']
          elseif Octa == "9" then
             Octa = 8
       --commandArray['Variable:octa']=tostring(Octa)  -- store the  octa variable
       --os.execute('curl "http://127.0.0.1:8081/json.htm?type=command&param=updateuservariable&idx='..idxUserVarOcta..'&vname=octa&vtype=0&vvalue='..tostring(Octa)..'"')
       commandArray[indexArray] = {['Variable:octa'] = tostring(Octa)}
       indexArray=indexArray+1
       Kc=1-0.75*math.pow(Octa/8,3.4)  -- Factor of mitigation for the cloud layer
       if sunAltitude > 1 then -- Below 1° of Altitude , the formulae reach their limit of precision.
          directRadiation = RadiationAtm * math.pow(0.6,M) * sinusSunAltitude
          scatteredRadiation = RadiationAtm * (0.271 - 0.294 * math.pow(0.6,M)) * sinusSunAltitude
          totalRadiation = scatteredRadiation + directRadiation
          Lux = totalRadiation / 0.0079  -- Radiation in Lux. 1 Lux = 0,0079 W/m²
          weightedLux = Lux * Kc   -- radiation of the Sun with the cloud layer
       elseif sunAltitude <= 1 and sunAltitude >= -6  then -- apply theoretical Lux of twilight
          directRadiation = 0
          scatteredRadiation = 0
          arbitraryTwilightLux=arbitraryTwilightLux-(1-sunAltitude)/7*arbitraryTwilightLux
          totalRadiation = scatteredRadiation + directRadiation + arbitraryTwilightLux
       elseif sunAltitude < -6 then  -- no management of nautical and astronomical twilight...
          directRadiation = 0
          totalRadiation = 0
          Lux = 0
          weightedLux = 0  --  should be around 3,2 Lux for the nautic twilight. Nevertheless.
          print("Station SYNOP = " .. WMOID)
          print( Octa .. " Octa")
          print("Kc = " .. Kc)
          print("Direct Radiation = ".. round(directRadiation,2) .." W/m²")
          print("Scattered Radiation = ".. round(scatteredRadiation,2) .." W/m²")
          print("Total radiation = " .. round(totalRadiation,2) .." W/m²")
          print("Total Radiation in lux = ".. round(Lux,2).." Lux")
          print("and at last, Total weighted lux  = ".. round(weightedLux,2).." Lux")
       -- cmd='curl "http://127.0.0.1:8081/json.htm?type=command&param=udevice&idx='..idxLux..'&svalue='..tostring(round(weightedLux,0))..'"'
       -- if( DEBUG == 1) then print(cmd) end
       -- os.execute(cmd)
	if tonumber(otherdevices_svalues['Lux'])+round(weightedLux,0)>0   -- No update if Lux is already 0. So lastUpdate of the sensor switch will keep the time of day when Lux has reached 0. (Kind of timeofday['SunsetInMinutes'])
	then
		commandArray[indexArray] = {['UpdateDevice'] = idxLux..'|0|'..tostring(round(weightedLux,0))}
       commandArray[indexArray] = {['UpdateDevice'] = idxSolarAzimuth..'|0|'..tostring(round(azimuth,0))}
       commandArray[indexArray] = {['UpdateDevice'] = idxSolarAltitude..'|0|'..tostring(round(sunAltitude,0))}
       if (DEBUG == 2) then
          logDebug=os.date("%Y-%m-%d %H:%M:%S",os.time())
          logDebug=logDebug.." Azimuth:" .. azimuth .. " Height:" .. sunAltitude
          logDebug=logDebug.." Octa:" .. Octa.."  KC:".. Kc
          logDebug=logDebug.." Direct:"..directRadiation.." inDirect:"..scatteredRadiation.." TotalRadiation:"..totalRadiation.." LuxCloud:".. round(weightedLux,2)
          os.execute('echo '..logDebug..' >>logSun.txt')  -- Windows platform !!
currently on wiki...
which you need to fill in:
       local altitude = 35              -- Your home altitude : run once in debug = 1 to found your altitude in Log and write it here
       local DEBUG = 1             -- 0 , 1 for domoticz log , 2 for file log
look up and fill in the value's from http://elevationmap.net
without weather underground:
replace
  --  API Wunderground
       config:close()
with
or, i think that will work...
relativePressure = tonumber(otherdevices_svalues['YourPressureSensor'])
that's how far I got, still, do not have it running...
and at least change:
into one minute waiting, we do not use weatherundergroudn.. and waiting 5 minutes is too long for test/debug purpuse...
if  ((time.min % 1)==0)
Derik
Post by Derik »
I throw the towel .. :oops: :oops:
If someone has him working and wants to help me .. :idea: :D
All day... :cry: :roll:
And not going ... :-(
Hope Trixwood helps. ... [ love you xxx ]
Derik
Post by Derik »
Perhaps i have a linaro user instead of pi?
trixwood
Post by trixwood »
Well it crashed for me on:
       -- if (DEBUG == 1) then
          --local WMOID = jsonLocation.current_observation.display_location.wmo
       -- end
so i commented that out...
My lux sensor is called "Sun Lux", so change 'Lux' into the name you have chosen yourself.(around line 190)... since it does not use the defaults idx but a name...
- So to get it working... setup the virtual sensors
- use a time lua event with the wiki code...
- Fill in the default value (idx, long, lat, etc... put debug=1 to see nice values in log for testing..)
- Use to look up Station ID in the netherlands:
http://www.ogimet.com/cgi-bin/gsynop?la ... =18&vsg=Sg
You could use 06260
- Remove weatherundergroudn api, and use a pressure sensor of domoticz***
- Remove the jsonLocation thing code line... (whatever it is...)
- Change the name "Lux", to your sensor name around line 190 (somebody should fix this... it leads to confusing...)
*** (much beter solution anyway, if you are going to use weatherunderground then do it through domoticz hardware and read that value from there...)
and whalla!
2016-08-21 21:02:00.553 LUA: Azimuth of the sun = 293.47327387855°
2016-08-21 21:02:00.553 LUA: Duration of the sunstroke of the day = 14.05 H.dd
2016-08-21 21:02:00.553 LUA: Radiation max en atmosphere = 1331.36 W/m²
2016-08-21 21:02:00.553 LUA: Local relative pressure = 1012 hPa
2016-08-21 21:02:00.553 LUA: Absolute pressure in atmosphere = 1011.4 hPa
2016-08-21 21:02:00.553 LUA: Coefficient of mitigation M = 80.973898320526 M0:80.925890080415
2016-08-21 21:02:00.553 LUA: curl "http://www.ogimet.com/cgi-bin/getsynop?block=07145&begin=201608211800"
2016-08-21 21:02:01.616 LUA: ogimet:07145,2016,08,21,18,00,AAXX 21184 07145 01775 12703 10208 20088 30036 40240 53009 69962 70186 81101 333 10214 20136 60007 81850 90710 91116 93100 555 60005=
2016-08-21 21:02:01.616 LUA: Station SYNOP = 07145
2016-08-21 21:02:01.616 LUA: 1 Octa
2016-08-21 21:02:01.616 LUA: Kc = 0.99936238972415
2016-08-21 21:02:01.616 LUA: Direct Radiation = 0 W/m²
2016-08-21 21:02:01.616 LUA: Scattered Radiation = 0 W/m²
2016-08-21 21:02:01.616 LUA: Total radiation = 1.98 W/m²
2016-08-21 21:02:01.616 LUA: Total Radiation in lux = 251.25 Lux
2016-08-21 21:02:01.616 LUA: and at last, Total weighted lux = 251.09 Lux
That would work... on a time event...
Derik
Post by Derik »
mmm
Your are FU^*^*ing good.....
Only... you are going to fast for me..
Please your code here??
trixwood
Post by trixwood »
Look for the: VERANDER HIER what you need to change... (throughout the code, thus also at the end of the code :-)
If your sensors are correct and you make it a time,event... it updates every minutes...
       local city = "Somewhere"            -- Your city for Wunderground API
      -- local countryCode = "FR"            -- Your country code for Wunderground API
      -- VERANDER HIER!!!
    --  de idx van de sensors en uservariable..
       local idxLux ='450'            -- Your virtual Lux Device ID
       local idxSolarAzimuth ='451'       -- Your virtual Azimuth Device ID
       local idxSolarAltitude ='452'       -- Your virtual Solar Altitude Device ID
     --  local wuAPIkey = "xxxxxxxxe5db6e4c" -- Your Weather Underground API Key
    -- VERANDER HIER!!! ZOEK OP MET http://elevationmap.net
       local latitude = 55.934321      -- your home
       local longitude = 4.206940       -- your home
       local altitude = 5              -- Your home altitude : run once in debug = 1 to found your altitude in Log and write it here
    --- ZOEK OP MET http://www.ogimet.com/cgi-bin/gsynop?lang=en&esc=2&nav=Yes&lat=50N&lon=005E&proy=orto&base=bluem&ano=2016&mes=08&day=21hora=18&vsg=Sg
       local WMOID = '06260'  --De Bilt: '06260'    -- Your nearest SYNOP Station for ogimet (to get Cloud layer). Run once with debug=1 to get it in the log. (or, better, choose it there : http://www.ogimet.com/gsynop_nav.phtml.en )
       result = {};
       return result;
       if num == 0 then
         return 0
    if  ((time.min % 1)==0)  then -- Run every 5 minutes. Check the wundergroud API limitation before changing this
       local indexArray=0
     -- VERANDER HIER!!!  DE Naam van de pressure sensor, uncomment als je die gebruikt..
       -- relativePressure = tonumber(otherdevices_svalues['Pressure SENSOR'])
          nbDaysInYear = 365
       -- end
       ogimet:close()
       then
             Octa = 8
          directRadiation = 0
          directRadiation = 0
          totalRadiation = 0
          Lux = 0
       -- os.execute(cmd)
    -- VERANDER HIER!!!  DE Naam van de Lux sensor
	if tonumber(otherdevices_svalues['Sun Lux'])+round(weightedLux,0)>0   -- No update if Lux is already 0. So lastUpdate of the sensor switch will keep the time of day when Lux has reached 0. (Kind of timeofday['SunsetInMinutes'])
	then
    -- VERANDER HIER!!!  KLAAR
Derik
Post by Derik »
2016-08-21 21:51:00.940 Error: EventSystem: in /home/linaro/domoticz/scripts/lua/script_time_SolarSensor.lua: .../linaro/domoticz/scripts/lua/script_time_SolarSensor.lua:117: attempt to perform arithmetic on global 'relativePressure' (a nil value)
Still got this error:
This is what i made:
       local city = "Nijmegen"            -- Your city for Wunderground API
      -- VERANDER HIER!!!
       local idxLux ='4750'            -- Your virtual Lux Device ID
       local idxSolarAzimuth ='4752'       -- Your virtual Azimuth Device ID
       local idxSolarAltitude ='4790'       -- Your virtual Solar Altitude Device ID
       local latitude = 59.87957     -- your home
       local longitude =  5.82391      -- your home
       local WMOID = '06725'  --Deelen: '06260'    -- Your nearest SYNOP Station for ogimet (to get Cloud layer). Run once with debug=1 to get it in the log. (or, better, choose it there : http://www.ogimet.com/gsynop_nav.phtml.en )
       result = {};
       return result;
       if num == 0 then
         return 0
       local indexArray=0
       relativePressure = tonumber(otherdevices_svalues['WuB: Temp'])
          nbDaysInYear = 365
       -- end
       ogimet:close()
       then
             Octa = 8
          directRadiation = 0
          directRadiation = 0
          totalRadiation = 0
          Lux = 0
       -- os.execute(cmd)
   if tonumber(otherdevices_svalues['D.M.: Lux'])+round(weightedLux,0)>0   -- No update if Lux is already 0. So lastUpdate of the sensor switch will keep the time of day when Lux has reached 0. (Kind of timeofday['SunsetInMinutes'])
   then
Stil that relative i am not good in math..:-(
Derik
Post by Derik »
And Trixwood how did you name the Dummy's..
In the wiki are the names different...
Sun Azimuth or Solar azimuth and D or degrees
Sun altitude or Solar Altitude etc etc etc..
trixwood
Post by trixwood »
Screen Shot 2016-08-21 at 22.21.32.png (73.69 KiB) Viewed 5351 times
Screen Shot 2016-08-21 at 22.20.50.png (43.5 KiB) Viewed 5351 times
trixwood
Post by trixwood »
i just setup weatherunderdround...I gonna find out,
in the mean time does it run with 1012 as relativePressure instead of the sensor...??
Derik
Post by Derik »
Something ALIVE....!!!!!!!
2 -- for my own presure sensor
Derik
Post by Derik »
2016-08-21 22:39:00.833 LUA:
2016-08-21 22:39:00.833 LUA: 2016-08-21 22:39:00
2016-08-21 22:39:00.834 LUA: Nijmegen, latitude:59.87957, longitude:5.82391
2016-08-21 22:39:00.834 LUA: Home altitude = 5 m
2016-08-21 22:39:00.834 LUA: number Of Day = 234
2016-08-21 22:39:00.834 LUA: 2016 is a leap year !
2016-08-21 22:39:00.834 LUA: Angular Speed = 0.98562628336756 per day
2016-08-21 22:39:00.834 LUA: Declinaison = 11.710720522258�
2016-08-21 22:39:00.834 LUA: Universel Coordinated Time (UTC)20.65 H.dd
2016-08-21 22:39:00.834 LUA: Solar Hour 21.038260666667 H.dd
2016-08-21 22:39:00.834 LUA: Altitude of the sun = -15.783463415723�
2016-08-21 22:39:00.834 LUA: Angular hourly = -135.57391�
2016-08-21 22:39:00.834 LUA: Azimuth of the sun = 314.57981118914�
2016-08-21 22:39:00.834 LUA: Duration of the sunstroke of the day = 14.04 H.dd
2016-08-21 22:39:00.834 LUA: Radiation max en atmosphere = 1331.36 W/m�
2016-08-21 22:39:00.834 LUA: Local relative pressure = 1012 hPa
2016-08-21 22:39:00.835 LUA: Absolute pressure in atmosphere = 1011.4 hPa
2016-08-21 22:39:00.835 LUA: Coefficient of mitigation M = 337.85917749437 M0:337.65886572906
2016-08-21 22:39:00.835 LUA: curl "http://www.ogimet.com/cgi-bin/getsynop?block=06725&begin=201608211900"
2016-08-21 22:39:01.053 LUA: ogimet:06725,2016,08,21,19,00,AAXX 21194 06725 23/// /0302 10103 20051 38533 48571 52016 333 55300 20022 60005 91107 91202=
06725,2016,08,21,20,00,AAXX 21204 06725 23/// /1002 10087 20038 38538 48576 53021 333 55300 20004 60005 91107 91203=
2016-08-21 22:39:01.055 LUA: Station SYNOP = 06725
2016-08-21 22:39:01.055 LUA: 0 Octa
2016-08-21 22:39:01.055 LUA: Kc = 1
2016-08-21 22:39:01.055 LUA: Direct Radiation = 0 W/m�
2016-08-21 22:39:01.056 LUA: Scattered Radiation = 0 W/m�
2016-08-21 22:39:01.056 LUA: Total radiation = 0 W/m�
2016-08-21 22:39:01.056 LUA: Total Radiation in lux = 0 Lux
2016-08-21 22:39:01.056 LUA: and at last, Total weighted lux = 0 Lux
trixwood
Post by trixwood »
Ok, so that works... now for the last part if you use the sensor from Weatherunderground hardware:
instead of:
use:
      temp, hum, uv, pres = otherdevices_svalues['Weather TempHumBaro']:match("([^;]+);([^;]+);([^;]+);([^;]+)")
      relativePressure = tonumber(pres)
Where "Weather TempHumBaro" is the combined temp/humidity/pressure sensor so we have to decode it...
Screen Shot 2016-08-21 at 22.44.56.png (28.2 KiB) Viewed 5342 times
Locked
