Real-time solar data : azimuth, Altitude, Lux sensor... [closed]
- Egregius
- Domoticz version: v2024.7
Re: Real-time solar data : azimuth, Altitude, Lux sensor...
Is wunderground pretty accurate and reliable?
Openweathermap isn't. I get readings like 18.6°, one minute later 19.2, then again 18.6, again 19.2,...
During daytime I now use forecast.io but the number of request is limited to 1000 per day for a free account.
trixwood
I was looking at cloud sensors... this popped up:
http://www.noao.edu/staff/gillespie/pro ... ector.html
could it work?
it looks like all it is, is this sensor https://www.adafruit.com/product/1330 sandwiched between two aluminium plates.
And then measure and mapping out the voltages to actually readings.
could it work?
- Egregius
You also have cloud prediction at forecast.io and openweathermap.
trixwood
Not everybody have a working internet connection on the location they run their stuff...
http://www.farnham-as.co.uk/2013/04/bui ... ud-sensor/
http://downloads.deusm.com/designnews/2 ... ctions.pdf
Going to build this one:
http://www.chrisramsay.co.uk/posts/2014 ... -part-one/
Derik
- Domoticz version: BETA
still something alive..
2016-08-21 19:05:01.317 LUA: Lat: 56.84249878Long: 5.85277796Alt: 22.00000000[/quote]
What do i need to do with data?
Fill in 22.00000000
Sensor still red..
Only my api [ i reset him] is counting..:
Where can i search ...
[attachment=0]ScreenShot210.jpg[/attachment]- Attachments
- ScreenShot210.jpg (4.52 KiB) Viewed 5268 times
trixwood
you can look up the long, lat and altitude here, I think: http://elevationmap.net
Derik
How can i read it from a pressure sensor?trixwood wrote:From the original wiki
without weathe underground you need to repalce that with:Code: Select all
-- API Wunderground local config=assert(io.popen('curl http://api.wunderground.com/api/'..wuAPIkey..'/conditions/q/'..countryCode..'/'..city..'.json')) local location = config:read('*all') config:close() local jsonLocation = json:decode(location) if( DEBUG == 1) then local latitude = jsonLocation.current_observation.display_location.latitude local longitude = jsonLocation.current_observation.display_location.longitude local altitude = jsonLocation.current_observation.display_location.elevation print('Lat: '..latitude..'Long: '..longitude..'Alt: '..altitude) end relativePressure = jsonLocation.current_observation.pressure_mb -- if you have an another way to get the Pressure, (local barometer ...) then you may optimize the script and avoid the call to api.wunderground)
or read it from a pressure sensor...Code: Select all
relativePressure = 1012
That yould fix your nil... now I am also stuck on the cloud coverage not coming in....
And where and How to fill in? When i got this script working i going to drink a very large BEER...
trixwood
--[[ Virtual Lux sensor and other real-time solar data
~/domoticz/scripts/lua/script_time_SolarSensor.lua
-- Autors ----------------------------------------------------------------
V1.0 - Sébastien Joly - Great original work
V1.1 - Neutrino - Adaptation to Domoticz
V1.2 - Jmleglise - An acceptable approximation of the lux below 1° altitude for Dawn and dusk + translation + several changes to be more userfriendly.
V1.3 - Jmleglise - keep the time of black night in lasptUpdate
-- Variables to customize ------------------------------------------------
local city = "Paris" -- Your city for Wunderground API
local countryCode = "FR" -- Your country code for Wunderground API
local idxLux ='72' -- Your virtual Lux Device ID
local idxSolarAzimuth ='85' -- Your virtual Azimuth Device ID
local idxSolarAltitude ='84' -- Your virtual Solar Altitude Device ID
local idxUserVarOcta='2' -- Your user variable ID , named octa
local wuAPIkey = "xxxxxxxxe5db6e4c" -- Your Weather Underground API Key
local latitude = 48.xxxx88 -- your home
local longitude = 2.xxxx00 -- your home
local altitude = 27 -- Your home altitude : run once in debug = 1 to found your altitude in Log and write it here
local WMOID = '07145' -- Your nearest SYNOP Station for ogimet (to get Cloud layer). Run once with debug=1 to get it in the log. (or, better, choose it there : http://www.ogimet.com/gsynop_nav.phtml.en )
local DEBUG = 0 -- 0 , 1 for domoticz log , 2 for file log
-- and customize the URL of api.wunderground around line 104 according to your country.
-- Below , edit at your own risk ------------------------------------------
function leapYear(year)
return year%4==0 and (year%100~=0 or year%400==0)
function split(s, delimiter)
result = {};
for match in (s..delimiter):gmatch("(.-)"..delimiter) do
table.insert(result, match);
return result;
function round(num, dec)
if num == 0 then
return 0
local mult = 10^(dec or 0)
return math.floor(num * mult + 0.5) / mult
time = os.date("*t")
if ((time.min % 5)==0) then -- Run every 5 minutes. Check the wundergroud API limitation before changing this
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- For Linux
--json = (loadfile "D:\\Domoticz\\scripts\\lua\\json.lua")() -- For Windows
local indexArray=0
local arbitraryTwilightLux=4.74 -- W/m² egal 600 Lux
local constantSolarRadiation = 1361 -- Solar Constant W/m²
if (uservariables['octa'] == nil) then print("Error : Did you create the Uservariable octa ?") end
-- API Wunderground
config:close()
local year = os.date("%Y")
local numOfDay = os.date("%j")
if leapYear(year) == true then
nbDaysInYear = 366 -- How many days in the year ?
nbDaysInYear = 365
angularSpeed = 360/365.25
local Declinaison = math.deg(math.asin(0.3978 * math.sin(math.rad(angularSpeed) *(numOfDay - (81 - 2 * math.sin((math.rad(angularSpeed) * (numOfDay - 2))))))))
timeDecimal = (os.date("!%H") + os.date("!%M") / 60) -- Coordinated Universal Time (UTC)
solarHour = timeDecimal + (4 * longitude / 60 ) -- The solar Hour
hourlyAngle = 15 * ( 12 - solarHour ) -- hourly Angle of the sun
sunAltitude = math.deg(math.asin(math.sin(math.rad(latitude))* math.sin(math.rad(Declinaison)) + math.cos(math.rad(latitude)) * math.cos(math.rad(Declinaison)) * math.cos(math.rad(hourlyAngle))))-- the height of the sun in degree, compared with the horizon
local azimuth = math.acos((math.sin(math.rad(Declinaison)) - math.sin(math.rad(latitude)) * math.sin(math.rad(sunAltitude))) / (math.cos(math.rad(latitude)) * math.cos(math.rad(sunAltitude) ))) * 180 / math.pi -- deviation of the sun from the North, in degree
local sinAzimuth = (math.cos(math.rad(Declinaison)) * math.sin(math.rad(hourlyAngle))) / math.cos(math.rad(sunAltitude))
if(sinAzimuth<0) then azimuth=360-azimuth end
sunstrokeDuration = math.deg(2/15 * math.acos(- math.tan(math.rad(latitude)) * math.tan(math.rad(Declinaison)))) -- duration of sunstroke in the day . Not used in this calculation.
RadiationAtm = constantSolarRadiation * (1 +0.034 * math.cos( math.rad( 360 * numOfDay / nbDaysInYear ))) -- Sun radiation (in W/m²) in the entrance of atmosphere.
-- Coefficient of mitigation M
absolutePressure = relativePressure - round((altitude/ 8.3),1) -- hPa
sinusSunAltitude = math.sin(math.rad(sunAltitude))
M0 = math.sqrt(1229 + math.pow(614 * sinusSunAltitude,2)) - 614 * sinusSunAltitude
M = M0 * relativePressure/absolutePressure
if (DEBUG == 1) then
print('<b style="color:Blue"============== SUN LOG ==================</b>')
print(os.date("%Y-%m-%d %H:%M:%S", os.time()))
print(city .. ", latitude:" .. latitude .. ", longitude:" .. longitude)
print("Home altitude = " .. tostring(altitude) .. " m")
print("number Of Day = " .. numOfDay)
if nbDaysInYear==366 then
print(year .." is a leap year !")
print(year.." is not a leap year")
print("Angular Speed = " .. angularSpeed .. " per day")
print("Declinaison = " .. Declinaison .. "°")
print("Universel Coordinated Time (UTC)".. timeDecimal .." H.dd")
print("Solar Hour ".. solarHour .." H.dd")
print("Altitude of the sun = " .. sunAltitude .. "°")
print("Angular hourly = ".. hourlyAngle .. "°")
print("Azimuth of the sun = " .. azimuth .. "°")
print("Duration of the sunstroke of the day = " .. round(sunstrokeDuration,2) .." H.dd") -- not used
print("Radiation max en atmosphere = " .. round(RadiationAtm,2) .. " W/m²")
print("Local relative pressure = " .. relativePressure .. " hPa")
print("Absolute pressure in atmosphere = " .. absolutePressure .. " hPa")
print("Coefficient of mitigation M = " .. M .." M0:"..M0)
-- Get SYNOP message from Ogimet web site
hourUTCminus1 = os.date("!%H")-1
if string.len(hourUTCminus1) == 1 then
hourUTCminus1 = "0" .. hourUTCminus1
UTC = os.date("%Y%m%d").. hourUTCminus1.."00" -- os.date("!%M")
local WMOID = jsonLocation.current_observation.display_location.wmo
cmd='curl "http://www.ogimet.com/cgi-bin/getsynop?block='..WMOID..'&begin='..UTC..'"'
if( DEBUG == 1) then print(cmd) end
local ogimet=assert(io.popen(cmd))
local synop = ogimet:read('*all')
ogimet:close()
if( DEBUG == 1) then print('ogimet:'..synop) end
if string.find(synop,"Status: 500") == nil
then
rslt = split(synop,",")
CodeStation = rslt[1]
rslt = split(synop, " "..CodeStation.. " ")
Trame = string.gsub(rslt[2], "=", "")
Trame = CodeStation .." ".. Trame
rslt = split(Trame, " ")
Octa = string.sub(rslt[3], 1, 1) -- 3rd char is the cloud layer. 0=no cloud , 1-8= cloudy from 1 to 8 max , 9 =Fog , / = no data
if Octa == "/" then -- not defined ? take the previous value
Octa = uservariables['octa']
elseif Octa == "9" then
Octa = 8
--commandArray['Variable:octa']=tostring(Octa) -- store the octa variable
--os.execute('curl "http://127.0.0.1:8081/json.htm?type=command¶m=updateuservariable&idx='..idxUserVarOcta..'&vname=octa&vtype=0&vvalue='..tostring(Octa)..'"')
commandArray[indexArray] = {['Variable:octa'] = tostring(Octa)}
indexArray=indexArray+1
Kc=1-0.75*math.pow(Octa/8,3.4) -- Factor of mitigation for the cloud layer
if sunAltitude > 1 then -- Below 1° of Altitude , the formulae reach their limit of precision.
directRadiation = RadiationAtm * math.pow(0.6,M) * sinusSunAltitude
scatteredRadiation = RadiationAtm * (0.271 - 0.294 * math.pow(0.6,M)) * sinusSunAltitude
totalRadiation = scatteredRadiation + directRadiation
Lux = totalRadiation / 0.0079 -- Radiation in Lux. 1 Lux = 0,0079 W/m²
weightedLux = Lux * Kc -- radiation of the Sun with the cloud layer
elseif sunAltitude <= 1 and sunAltitude >= -6 then -- apply theoretical Lux of twilight
directRadiation = 0
scatteredRadiation = 0
arbitraryTwilightLux=arbitraryTwilightLux-(1-sunAltitude)/7*arbitraryTwilightLux
totalRadiation = scatteredRadiation + directRadiation + arbitraryTwilightLux
elseif sunAltitude < -6 then -- no management of nautical and astronomical twilight...
directRadiation = 0
totalRadiation = 0
Lux = 0
weightedLux = 0 -- should be around 3,2 Lux for the nautic twilight. Nevertheless.
print("Station SYNOP = " .. WMOID)
print( Octa .. " Octa")
print("Kc = " .. Kc)
print("Direct Radiation = ".. round(directRadiation,2) .." W/m²")
print("Scattered Radiation = ".. round(scatteredRadiation,2) .." W/m²")
print("Total radiation = " .. round(totalRadiation,2) .." W/m²")
print("Total Radiation in lux = ".. round(Lux,2).." Lux")
print("and at last, Total weighted lux = ".. round(weightedLux,2).." Lux")
-- cmd='curl "http://127.0.0.1:8081/json.htm?type=command¶m=udevice&idx='..idxLux..'&svalue='..tostring(round(weightedLux,0))..'"'
-- if( DEBUG == 1) then print(cmd) end
-- os.execute(cmd)
if tonumber(otherdevices_svalues['Lux'])+round(weightedLux,0)>0 -- No update if Lux is already 0. So lastUpdate of the sensor switch will keep the time of day when Lux has reached 0. (Kind of timeofday['SunsetInMinutes'])
then
commandArray[indexArray] = {['UpdateDevice'] = idxLux..'|0|'..tostring(round(weightedLux,0))}
commandArray[indexArray] = {['UpdateDevice'] = idxSolarAzimuth..'|0|'..tostring(round(azimuth,0))}
commandArray[indexArray] = {['UpdateDevice'] = idxSolarAltitude..'|0|'..tostring(round(sunAltitude,0))}
if (DEBUG == 2) then
logDebug=os.date("%Y-%m-%d %H:%M:%S",os.time())
logDebug=logDebug.." Azimuth:" .. azimuth .. " Height:" .. sunAltitude
logDebug=logDebug.." Octa:" .. Octa.." KC:".. Kc
logDebug=logDebug.." Direct:"..directRadiation.." inDirect:"..scatteredRadiation.." TotalRadiation:"..totalRadiation.." LuxCloud:".. round(weightedLux,2)
os.execute('echo '..logDebug..' >>logSun.txt') -- Windows platform !!
which you need to fill in:
local altitude = 35 -- Your home altitude : run once in debug = 1 to found your altitude in Log and write it here
local DEBUG = 1 -- 0 , 1 for domoticz log , 2 for file log
without weather underground:
replace
-- API Wunderground
config:close()
relativePressure = tonumber(otherdevices_svalues['YourPressureSensor'])
and at least change:
if ((time.min % 1)==0)
Derik
I throw the towel ..
If someone has him working and wants to help me ..
All day...
And not going ...
Hope Trixwood helps. ... [ love you xxx ]
All day...
And not going ...
Derik
Perhaps i have a linaro user instead of pi?
trixwood
Well it crashed for me on:
so i commented that out...
My lux sensor is called "Sun Lux", so change 'Lux' into the name you have chosen yourself.(around line 190)... since it does not use the defaults idx but a name...
- So to get it working... setup the virtual sensors
- use a time lua event with the wiki code...
- Fill in the default value (idx, long, lat, etc... put debug=1 to see nice values in log for testing..)
- Use to look up Station ID in the netherlands:
http://www.ogimet.com/cgi-bin/gsynop?la ... =18&vsg=Sg
You could use 06260
- Remove weatherundergroudn api, and use a pressure sensor of domoticz***
- Remove the jsonLocation thing code line... (whatever it is...)
- Change the name "Lux", to your sensor name around line 190 (somebody should fix this... it leads to confusing...)
*** (much beter solution anyway, if you are going to use weatherunderground then do it through domoticz hardware and read that value from there...)
and whalla!
That would work... on a time event...
-- if (DEBUG == 1) then
--local WMOID = jsonLocation.current_observation.display_location.wmo
-- end
You could use 06260
and whalla!
2016-08-21 21:02:00.553 LUA: Azimuth of the sun = 293.47327387855°
2016-08-21 21:02:00.553 LUA: Duration of the sunstroke of the day = 14.05 H.dd
2016-08-21 21:02:00.553 LUA: Radiation max en atmosphere = 1331.36 W/m²
2016-08-21 21:02:00.553 LUA: Local relative pressure = 1012 hPa
2016-08-21 21:02:00.553 LUA: Absolute pressure in atmosphere = 1011.4 hPa
2016-08-21 21:02:00.553 LUA: Coefficient of mitigation M = 80.973898320526 M0:80.925890080415
2016-08-21 21:02:00.553 LUA: curl "http://www.ogimet.com/cgi-bin/getsynop?block=07145&begin=201608211800"
2016-08-21 21:02:01.616 LUA: ogimet:07145,2016,08,21,18,00,AAXX 21184 07145 01775 12703 10208 20088 30036 40240 53009 69962 70186 81101 333 10214 20136 60007 81850 90710 91116 93100 555 60005=
2016-08-21 21:02:01.616 LUA: Station SYNOP = 07145
2016-08-21 21:02:01.616 LUA: 1 Octa
2016-08-21 21:02:01.616 LUA: Kc = 0.99936238972415
2016-08-21 21:02:01.616 LUA: Direct Radiation = 0 W/m²
2016-08-21 21:02:01.616 LUA: Scattered Radiation = 0 W/m²
2016-08-21 21:02:01.616 LUA: Total radiation = 1.98 W/m²
2016-08-21 21:02:01.616 LUA: Total Radiation in lux = 251.25 Lux
2016-08-21 21:02:01.616 LUA: and at last, Total weighted lux = 251.09 Lux
Derik
mmm
Your are FU^*^*ing good.....
Only... you are going to fast for me..
Please your code here??
trixwood
Look for the: VERANDER HIER what you need to change... (throughout the code, thus also at the end of the code
If your sensors are correct and you make it a time,event... it updates every minutes...
local city = "Somewhere" -- Your city for Wunderground API
-- local countryCode = "FR" -- Your country code for Wunderground API
-- VERANDER HIER!!!
-- de idx van de sensors en uservariable..
local idxLux ='450' -- Your virtual Lux Device ID
local idxSolarAzimuth ='451' -- Your virtual Azimuth Device ID
local idxSolarAltitude ='452' -- Your virtual Solar Altitude Device ID
-- local wuAPIkey = "xxxxxxxxe5db6e4c" -- Your Weather Underground API Key
-- VERANDER HIER!!! ZOEK OP MET http://elevationmap.net
local latitude = 55.934321 -- your home
local longitude = 4.206940 -- your home
local altitude = 5 -- Your home altitude : run once in debug = 1 to found your altitude in Log and write it here
--- ZOEK OP MET http://www.ogimet.com/cgi-bin/gsynop?lang=en&esc=2&nav=Yes&lat=50N&lon=005E&proy=orto&base=bluem&ano=2016&mes=08&day=21hora=18&vsg=Sg
local WMOID = '06260' --De Bilt: '06260' -- Your nearest SYNOP Station for ogimet (to get Cloud layer). Run once with debug=1 to get it in the log. (or, better, choose it there : http://www.ogimet.com/gsynop_nav.phtml.en )
result = {};
return result;
if num == 0 then
return 0
if ((time.min % 1)==0) then -- Run every 5 minutes. Check the wundergroud API limitation before changing this
local indexArray=0
-- VERANDER HIER!!! DE Naam van de pressure sensor, uncomment als je die gebruikt..
-- relativePressure = tonumber(otherdevices_svalues['Pressure SENSOR'])
nbDaysInYear = 365
-- end
ogimet:close()
then
Octa = 8
directRadiation = 0
directRadiation = 0
totalRadiation = 0
Lux = 0
-- os.execute(cmd)
-- VERANDER HIER!!! DE Naam van de Lux sensor
if tonumber(otherdevices_svalues['Sun Lux'])+round(weightedLux,0)>0 -- No update if Lux is already 0. So lastUpdate of the sensor switch will keep the time of day when Lux has reached 0. (Kind of timeofday['SunsetInMinutes'])
then
-- VERANDER HIER!!! KLAAR
Derik
2016-08-21 21:51:00.940 Error: EventSystem: in /home/linaro/domoticz/scripts/lua/script_time_SolarSensor.lua: .../linaro/domoticz/scripts/lua/script_time_SolarSensor.lua:117: attempt to perform arithmetic on global 'relativePressure' (a nil value)This is what i made:
local city = "Nijmegen" -- Your city for Wunderground API
-- VERANDER HIER!!!
local idxLux ='4750' -- Your virtual Lux Device ID
local idxSolarAzimuth ='4752' -- Your virtual Azimuth Device ID
local idxSolarAltitude ='4790' -- Your virtual Solar Altitude Device ID
local latitude = 59.87957 -- your home
local longitude = 5.82391 -- your home
local WMOID = '06725' --Deelen: '06260' -- Your nearest SYNOP Station for ogimet (to get Cloud layer). Run once with debug=1 to get it in the log. (or, better, choose it there : http://www.ogimet.com/gsynop_nav.phtml.en )
result = {};
return result;
if num == 0 then
return 0
local indexArray=0
relativePressure = tonumber(otherdevices_svalues['WuB: Temp'])
nbDaysInYear = 365
-- end
ogimet:close()
then
Octa = 8
directRadiation = 0
directRadiation = 0
totalRadiation = 0
Lux = 0
-- os.execute(cmd)
if tonumber(otherdevices_svalues['D.M.: Lux'])+round(weightedLux,0)>0 -- No update if Lux is already 0. So lastUpdate of the sensor switch will keep the time of day when Lux has reached 0. (Kind of timeofday['SunsetInMinutes'])
then
Derik
And Trixwood how did you name the Dummy's..
In the wiki are the names different...
Sun Azimuth or Solar azimuth and D or degrees
Sun altitude or Solar Altitude etc etc etc..
trixwood
i just setup weatherunderdround...I gonna find out,
in the mean time does it run with 1012 as relativePressure instead of the sensor...??
Derik
Something ALIVE....!!!!!!!
2 -- for my own presure sensor
Derik
2016-08-21 22:39:00.833 LUA:
2016-08-21 22:39:00.833 LUA: 2016-08-21 22:39:00
2016-08-21 22:39:00.834 LUA: Nijmegen, latitude:59.87957, longitude:5.82391
2016-08-21 22:39:00.834 LUA: Home altitude = 5 m
2016-08-21 22:39:00.834 LUA: number Of Day = 234
2016-08-21 22:39:00.834 LUA: 2016 is a leap year !
2016-08-21 22:39:00.834 LUA: Angular Speed = 0.98562628336756 per day
2016-08-21 22:39:00.834 LUA: Declinaison = 11.710720522258�
2016-08-21 22:39:00.834 LUA: Universel Coordinated Time (UTC)20.65 H.dd
2016-08-21 22:39:00.834 LUA: Solar Hour 21.038260666667 H.dd
2016-08-21 22:39:00.834 LUA: Altitude of the sun = -15.783463415723�
2016-08-21 22:39:00.834 LUA: Angular hourly = -135.57391�
2016-08-21 22:39:00.834 LUA: Azimuth of the sun = 314.57981118914�
2016-08-21 22:39:00.834 LUA: Duration of the sunstroke of the day = 14.04 H.dd
2016-08-21 22:39:00.834 LUA: Radiation max en atmosphere = 1331.36 W/m�
2016-08-21 22:39:00.834 LUA: Local relative pressure = 1012 hPa
2016-08-21 22:39:00.835 LUA: Absolute pressure in atmosphere = 1011.4 hPa
2016-08-21 22:39:00.835 LUA: Coefficient of mitigation M = 337.85917749437 M0:337.65886572906
2016-08-21 22:39:00.835 LUA: curl "http://www.ogimet.com/cgi-bin/getsynop?block=06725&begin=201608211900"
2016-08-21 22:39:01.053 LUA: ogimet:06725,2016,08,21,19,00,AAXX 21194 06725 23/// /0302 10103 20051 38533 48571 52016 333 55300 20022 60005 91107 91202=
06725,2016,08,21,20,00,AAXX 21204 06725 23/// /1002 10087 20038 38538 48576 53021 333 55300 20004 60005 91107 91203=
2016-08-21 22:39:01.055 LUA: Station SYNOP = 06725
2016-08-21 22:39:01.055 LUA: 0 Octa
2016-08-21 22:39:01.055 LUA: Kc = 1
2016-08-21 22:39:01.055 LUA: Direct Radiation = 0 W/m�
2016-08-21 22:39:01.056 LUA: Scattered Radiation = 0 W/m�
2016-08-21 22:39:01.056 LUA: Total radiation = 0 W/m�
2016-08-21 22:39:01.056 LUA: Total Radiation in lux = 0 Lux
2016-08-21 22:39:01.056 LUA: and at last, Total weighted lux = 0 LuxXu4: Beta Extreme antenna RFXcomE,WU Fi Ping ip P1 Gen5 PVOutput Harmony HUE SolarmanPv OTG Winddelen Alive ESP Buienradar MySensors WOL Winddelen counting RPi: Beta SMAspot RFlinkTest Domoticz ...Different backups
trixwood
Ok, so that works... now for the last part if you use the sensor from Weatherunderground hardware:
instead of:
use:
Where "Weather TempHumBaro" is the combined temp/humidity/pressure sensor so we have to decode it...
instead of:
temp, hum, uv, pres = otherdevices_svalues['Weather TempHumBaro']:match("([^;]+);([^;]+);([^;]+);([^;]+)")
relativePressure = tonumber(pres)
