How to update RFLink firmware
- Stuntteam
Re: How to update RFLink firmware
- When Domoticz starts / connects to the RFLink, it will show the version number
- You can also use "RFLink Loader" to see the version number. It will tell you when it connects to the RFLink.
- Alternatively you can use any termninal program and send the command 10;VERSION; it will then tell you the installed version.
woody4165
Dlanor
It seams firmware R42 is ready and build R43 has been started. I don't see the download link for R42. Hasn't it been released yet?
Domoticz| Zigbee | SONOFF
- Stuntteam
not yet.. but soon..
- bizziebis
- Domoticz version: 3.8805
Do you have the source anywhere hosted on svn or Git? I only seem te be able to find an old version cloned by someone.
piokuc
Good option will be add to Domoticz and RFLink option update firmware by using GUI Domoticz. As is in RFXCom. This will be very good option. Because some user has set box RFLink in very accessible place and must disconnect it from Raspberry and connect to PC.
Also good will be add option debug mode to domoticz to read code from RFLink example from new devices to send to developer to add support
- Stuntteam
Firmware updates within Domoticz might be added later. Adding new protocols has more priority at the moment.
Debug mode will not be added to Domoticz. Domoticz should be treated as normal operational platform.
If you want to experiment and debug, you either connect RFlink temporary to a PC or for less than 10 euros you could build yourself a second RFlink!
piokuc
Ok thanks. But please think about add to domoticz update FW in future.
Wysłane z mojego Galaxy S6 za pomocą Tapatalk
- bizziebis
With a shell script it's possible to flash it from the raspberry itself. It's not as easy as flashing from Domoticz, but it keeps you from removing your RFLink and plugging it into your pc.
piokuc
But i postulate to also RFLink can be flash as RFXCom by using GUI Domoticz...by webbrowser
- Stuntteam
If you can organize that the duration of a day will go from 24 to 48 hours then we can get more done in a day
Otherwise just be patient..
georgesattali
@ bizziebis,
shell script !! nice !
Do you have an example or some hints ?
NietGiftig
- Domoticz version: V3.6224
Why don't you buy an RFXcom.piokuc wrote:But i postulate to also RFLink can be flash as RFXCom by using GUI Domoticz...by webbrowser
You be happy, and we have no more multiple posts from you on different forums.
So everybody happy!
RPI-2 + SSD / ESPEasy Sensors & Switches / Sonoff / RFLink / Action Switches / TP-Link switch / Node-Red / Reacticz
- Stuntteam
I am pretty sure he would still cross post, just about a different device
- bizziebis
Re: RE: Re: How to update RFLink firmware
I made a small script which disables Monit, stops Domoticz and then executes the following command:georgesattali wrote:@ bizziebis,
sudo avrdude -v -p atmega2560 -c stk500 -P /dev/ttyACM0 -b 115200 -D -U flash:w:/home/pi/RFLink.cpp.hex:iCode: Select all
sudo apt-get install Avrdude-
georgesattali
Thanks for the command ! I'll try it soon.
htca
Is there a location where you could download the zip besides the google link? it seems impossible to download it from the CLI (I am on a distance, so easy plugging in a USB stick with the files is not an option).
marcels
Guys, I'm having trouble updating the rflink firmware version to R44.
I used the instructions in the startpost. But although I think everything should be OK, the program button is greyed out..
The logging window shows the following information:
Any idea's?
20;00;Nodo RadioFrequencyLink V1.1;
10;version;
20;01;VER=1.1;REV=28;BUILD=000;
10;status;
20;02;CMD UNKNOWN;
- Westcott
I successfully use the method in the 3rd and 4th posts by downloading the new zip file to my Windows PC. then unpacking it and sending just the RFLink.cpp.hex file to the RPi.
You don't need to stop Domotics - simply update your RFlink device in Setup->Hardware with 'Enabled' unchecked.
Note its Port, then use it in the avrdude command.
Finally re-enable the RFlink device - the log and the Hardware device shows the version when it restarts.
