How to update RFLink firmware
433Mhz opensource Receiver & Transmitter.
Stuntteam
Re: How to update RFLink firmware
Post by Stuntteam »
- When Domoticz starts / connects to the RFLink, it will show the version number
- You can also use "RFLink Loader" to see the version number. It will tell you when it connects to the RFLink.
- Alternatively you can use any termninal program and send the command 10;VERSION; it will then tell you the installed version.
woody4165
Post by woody4165 »
Dlanor
Post by Dlanor »
It seams firmware R42 is ready and build R43 has been started. I don't see the download link for R42. Hasn't it been released yet?
Domoticz| Zigbee | SONOFF
Stuntteam
Post by Stuntteam »
not yet.. but soon..
bizziebis
Domoticz version: 3.8805
Post by bizziebis »
Do you have the source anywhere hosted on svn or Git? I only seem te be able to find an old version cloned by someone.
piokuc
Post by piokuc »
Good option will be add to Domoticz and RFLink option update firmware by using GUI Domoticz. As is in RFXCom. This will be very good option. Because some user has set box RFLink in very accessible place and must disconnect it from Raspberry and connect to PC.
Also good will be add option debug mode to domoticz to read code from RFLink example from new devices to send to developer to add support
Stuntteam
Post by Stuntteam »
Firmware updates within Domoticz might be added later. Adding new protocols has more priority at the moment.
Debug mode will not be added to Domoticz. Domoticz should be treated as normal operational platform.
If you want to experiment and debug, you either connect RFlink temporary to a PC or for less than 10 euros you could build yourself a second RFlink!
piokuc
Post by piokuc »
Ok thanks. But please think about add to domoticz update FW in future.
Wysłane z mojego Galaxy S6 za pomocą Tapatalk
bizziebis
Post by bizziebis »
With a shell script it's possible to flash it from the raspberry itself. It's not as easy as flashing from Domoticz, but it keeps you from removing your RFLink and plugging it into your pc.
piokuc
Post by piokuc »
But i postulate to also RFLink can be flash as RFXCom by using GUI Domoticz...by webbrowser
Stuntteam
Post by Stuntteam »
If you can organize that the duration of a day will go from 24 to 48 hours then we can get more done in a day :P
Otherwise just be patient..
piokuc
Post by piokuc »
georgesattali
Post by georgesattali »
@ bizziebis,
shell script !! nice !
Do you have an example or some hints ?
NietGiftig
Domoticz version: V3.6224
Post by NietGiftig »
piokuc wrote:But i postulate to also RFLink can be flash as RFXCom by using GUI Domoticz...by webbrowser
Why don't you buy an RFXcom.
You be happy, and we have no more multiple posts from you on different forums.
So everybody happy!
RPI-2 + SSD / ESPEasy Sensors & Switches / Sonoff / RFLink / Action Switches / TP-Link switch / Node-Red / Reacticz
Stuntteam
Post by Stuntteam »
I am pretty sure he would still cross post, just about a different device :P
bizziebis
Re: RE: Re: How to update RFLink firmware
Post by bizziebis »
georgesattali wrote:@ bizziebis,
I made a small script which disables Monit, stops Domoticz and then executes the following command:
sudo avrdude -v -p atmega2560 -c stk500 -P /dev/ttyACM0 -b 115200 -D -U flash:w:/home/pi/RFLink.cpp.hex:i
If you don't have Avrdude installed you must first install it
sudo apt-get install Avrdude
georgesattali
Thanks for the command ! I'll try it soon. :)
htca
Post by htca »
Is there a location where you could download the zip besides the google link? it seems impossible to download it from the CLI (I am on a distance, so easy plugging in a USB stick with the files is not an option).
marcels
Post by marcels »
Guys, I'm having trouble updating the rflink firmware version to R44.
I used the instructions in the startpost. But although I think everything should be OK, the program button is greyed out..
The logging window shows the following information:
20;00;Nodo RadioFrequencyLink V1.1;
10;version;
20;01;VER=1.1;REV=28;BUILD=000;
10;status;
20;02;CMD UNKNOWN;
Any idea's?
Westcott
Post by Westcott »
I successfully use the method in the 3rd and 4th posts by downloading the new zip file to my Windows PC. then unpacking it and sending just the RFLink.cpp.hex file to the RPi.
You don't need to stop Domotics - simply update your RFlink device in Setup->Hardware with 'Enabled' unchecked.
Note its Port, then use it in the avrdude command.
Finally re-enable the RFlink device - the log and the Hardware device shows the version when it restarts.
