How to update RFLink firmware
- Stuntteam
This topic describes an easy method to update the firmware of the RFLink.
Using the RFLink Loader tool:
- Download the latest firmware package from http://sourceforge.net/projects/rflink/ ... urce=files
- Connect the Arduino Mega to a USB port.
- Unpack the zip file to a directory
- Launch the RFLInkLoader.exe program
- Select the file you want to program (which will be the included "rflink.cpp.hex" file)
- Select the serial (USB) port to which the Arduino is connected.
- Hit the "Program" button and wait for the process to finish.
Thats all..
We will try to add firmware updating functionality to Domoticz..
Thats all..
oopee
- Domoticz version: 3.x
Re: How to update RFLink firmware
Remember that you have to install Arduino usb drivers to get Windows to recognize Arduino board and assign COM port. After that you can use the RFLinkLoader. Drivers are part of the Arduino software package https://www.arduino.cc/en/Main/Software.
oopee
And remember to replace /dev/ttyUSB0 with whatever port RFLink is using in your system
- remb0
so it's possible to make an sh script.
and make script executable
then a virtual switch which fire that script.
nice
nice
- Stuntteam
Yes, my rflink loader tool is also using avrdude..
h143
can you explane how you do that?
Dlanor
It works perfectly. Thanks!Stuntteam wrote:This topic describes an easy method to update the firmware of the RFLink.
Thats all..
Domoticz| Zigbee | SONOFF
Derik
- Domoticz version: BETA
Great hardware the RFlink
Perhaps a option to upgrade the RFlink like the RFXcom..
L2v2P
On OS X you can do it as follows:
- Download the Arduino App from https://www.arduino.cc and install it.
- Open a terminal session.
- From the directory where the Arduino App is located run the commands below whereby replacing /dev/cu.usbmodem411 and RFLink_v1-2/RFLink.cpp.hex with your own values.
Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -v -p atmega2560 -c stk500 -P /dev/cu.usbmodem411 -b 115200 -D -U flash:w:RFLink_v1-2/RFLink.cpp.hex:i -C Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf
- remb0
i got now:
avrdude -v -p atmega2560 -c stk500 -P /dev/ACM0 -b 115200 -D -U flash:w:/home/pi/RFLink.cpp.hex:i
Programmer Type : STK500V2
Description : Atmel STK500
Programmer Model: Unknown
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
- Stuntteam
Why the -D ?
NietGiftig
- Domoticz version: V3.6224
Do you have to stop Domoticz that is using Rflink?
RPI-2 + SSD / ESPEasy Sensors & Switches / Sonoff / RFLink / Action Switches / TP-Link switch / Node-Red / Reacticz
Maarten112
Hi Guys,
I'm a new Domoticz and RFLink user since a week now....Thanks for all the great work on both the RFLink hardware and Software. So far it's working great, despite the fact that i'm living in a heavily 433MHz crowded location.
Firmware updating is plain simple for everyone that has ever worked with arduino:)
peerkersezuuker
Same message as remb0.
So updated with my windows machine, would be nice indeed to have an working updater for linux/Pi
rokib
hi,
can someone give me the link to latest beta firmware.
Derik
Perhaps...rokib wrote:hi,
https://sourceforge.net/projects/rflink ... =directory
Or:
http://www.nemcon.nl/blog2/2015/07/bb
Or:
https://www.google.nl/?gws_rd=ssl
- Stuntteam
He probably means Domoticz beta.. For Pi you can enable the betas under settings.
- jumbotroll
How to update RFLink on Synology NAS:
1. Download and install avrdude.spk for your synology from my server: http://www.jadahl.com/synology/
2. Copy the newest RFLink.cpp.hex file to a folder on your NAS, for example /volume1/web
3. Go to Hardware settings in Domoticz and temporary disable (not delete) RFLink.
4. Telnet or ssh your NAS and type:
avrdude -v -p atmega2560 -c stk500 -P /dev/ttyUSB1 -b 115200 -D -U flash:w:/volume1/web/RFLink.cpp.hex:i
Remember to edit correct directory and USB port you using!
5. Go to Hardware settings in Domoticz and enable RFLink.
The end
The end
https://paypal.me/Jumbotroll
Jumbotroll
Jumbotroll
Larsja
- Domoticz version: V2.3530
Hi, did you find out about this remb0? Im getting the same problem.remb0 wrote:i got now:
Programmer Type : STK500V2 Description : Atmel STK500 Programmer Model: Unknown avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_getsync(): timeout communicating with programmer
My RFLink is just 2 meters away, but in near future, im gonna put it in a cabinet, and thus it would be sweet to update it via RPi and skip the usb to windows machine
- remb0
no solution found and tested. I used USB that time. so stil trying (only it's not here but @ my brothers house.
