Suggestion: Z-Wave device management improvements
dhanjel
Domoticz version: 3.5146
Post by dhanjel »
This is an extracted part from viewtopic.php?f=31&t=12111 (can be closed if possible), to provide a more precise improvement suggestion regarding z-wave device management.
Improvement when adding a new z-wave device
  • When adding a node, instead of beeing redirected to the node list, a dialog appears where the user can set the name and room for the node.
  • All devices associated to that node that is created in the process, will get the same name and room by default.
  • The Room name will also be set in the z-wave control panel (Today only name is transferred)
  • All devices must be assigned to a room. If no room is selected, they are added to a room called "Unassigned".
  • Group a node's devices in a more clear way on the Device tab, this will make it easier to administrate z-wave hardware with a lot of virtual devices, such as Fibaro Motion Sensor. Something like this:
juankar
Domoticz version: 4.
Re: Suggestion: Z-Wave device management improvements
Post by juankar »
I like the idea.
Sometimes I get lost in the device list. If would be easier if the devices are grouped, for instance, grouping all devices in one node (a node with relays, meters...)
stevewm
Post by stevewm »
Agreed on the grouping in the device list.
Recently added a Aeotech G5 energy monitor. It added no less than 12 devices which where randomly splayed out all over the devices screen.
Same with Z-wave switches... If you are adding several at a time, its very difficult to figure out which switch is which on the Devices screen. Even a simple z-Wave switch will often add 3-4 devices.
Kerneldomoticz
Domoticz version: 3.5248
Post by Kerneldomoticz »
Great idea !!
device list is a mess after 10 and more devices ... adding the column where it is listed the name of the node we set under hardware will be nice too.
raym
Post by raym »
Love this idea. Hopefully not too difficult for someone here to implement...
robpow
Domoticz version: Beta :)
Post by robpow »
+1
JuanUil
Domoticz version: 4.11083
Post by JuanUil »
count me in ;)
Ricard1
Post by Ricard1 »
+1
warp
Post by warp »
+1
Raspberry 2B:RaZberry Z-Wave+:Edimax EW-7811UN:Huawei E220 3G
4xQubino ZMNHCA2
Everspring SE812 & ST812
Mcohome MH-S411 & MH-S412
2xAEON LABS ZW-100
2xFibaro FGSD-002:Fibaro FGFS-101:Fibaro FGS-221 & KLF-050
maurool
Post by maurool »
+1
Very useful! Sometimes going from adding hardware to discover the correct associated devices is a pain...
bbqkees
Domoticz version: 4.1x
Post by bbqkees »
+1
Kerneldomoticz
+ 1000
great ideas ! it will be great if this can be pushed in a a future Beta realease
Flo
piokuc
Post by piokuc »
Good idea +1 :)
emme
Domoticz version: latest
Post by emme »
+1
"We always done this way"
raym
Post by raym »
There's obviously a lot of support for this. Anyone smart enough to make it happen? I wish I could code but I am happy to help with any testing....
sjoerdmulder
Post by sjoerdmulder »
+1 and i can code :) Would love too fix some of these issues, but i'm quite new to Domoticz
ben53252642
Post by ben53252642 »
+ 1 this is a great idea and would save a lot of time.
Evelen
Domoticz version: 2.4538
Post by Evelen »
+1
:o
raym
Re: RE: Re: Suggestion: Z-Wave device management improvements
Post by raym »
sjoerdmulder wrote:+1 and i can code :) Would love too fix some of these issues, but i'm quite new to Domoticz
Well, if you can code and have some time to spare on this, that's a BIG start. Happy to assist in any other way I can (as I'm sure many others here are as well).
mischa
Domoticz version: 3.8872
Post by mischa »
+1
Pi 2 - Pi 1 - Razzbery 2.0 - Fibaro FGD-211 - Fibaro FGD-212 - Fibaro FGRGBWM-441 (RGBW Module) - Fibaro FGBS321 (Universal Switch) - FGWPF-102 - TBK Home TZ67-G - Synology DS1515+ - Esp Easy (with wemos D1 mini)
