This is an extracted part from viewtopic.php?f=31&t=12111 (can be closed if possible), to provide a more precise improvement suggestion regarding z-wave device management.
Improvement when adding a new z-wave device
When adding a node, instead of beeing redirected to the node list, a dialog appears where the user can set the name and room for the node.
All devices associated to that node that is created in the process, will get the same name and room by default.
The Room name will also be set in the z-wave control panel (Today only name is transferred)
All devices must be assigned to a room. If no room is selected, they are added to a room called "Unassigned".
Group a node's devices in a more clear way on the Device tab, this will make it easier to administrate z-wave hardware with a lot of virtual devices, such as Fibaro Motion Sensor. Something like this:
I like the idea.
Sometimes I get lost in the device list. If would be easier if the devices are grouped, for instance, grouping all devices in one node (a node with relays, meters...)
Recently added a Aeotech G5 energy monitor. It added no less than 12 devices which where randomly splayed out all over the devices screen.
Same with Z-wave switches... If you are adding several at a time, its very difficult to figure out which switch is which on the Devices screen. Even a simple z-Wave switch will often add 3-4 devices.
sjoerdmulder wrote:+1 and i can code Would love too fix some of these issues, but i'm quite new to Domoticz
Well, if you can code and have some time to spare on this, that's a BIG start. Happy to assist in any other way I can (as I'm sure many others here are as well).
