ELV Max! Heating control system
Westcott
Re: ELV Max! Heating control system
Post by Westcott »
I can't remember how I did it, but this might help -
http://www.domoticz.com/forum/viewtopic ... 638#p22638
jorishp
Post by jorishp »
do you have the same files for basexx? :oops:
pi@raspberrypi ~ $ lua max.lua
lua: max.lua:2: module 'basexx' not found:
	no field package.preload['basexx']
	no file '/usr/local/share/lua/5.2/basexx.lua'
	no file '/usr/local/share/lua/5.2/basexx/init.lua'
	no file '/usr/local/lib/lua/5.2/basexx.lua'
	no file '/usr/local/lib/lua/5.2/basexx/init.lua'
	no file './basexx.lua'
	no file '/usr/share/lua/5.2/basexx.lua'
	no file '/usr/share/lua/5.2/basexx/init.lua'
	no file '/usr/local/lib/lua/5.2/basexx.so'
	no file '/usr/lib/arm-linux-gnueabihf/lua/5.2/basexx.so'
	no file '/usr/lib/lua/5.2/basexx.so'
	no file '/usr/local/lib/lua/5.2/loadall.so'
	no file './basexx.so'
stack traceback:
	[C]: in function 'require'
	max.lua:2: in main chunk
	[C]: in ?
pi@raspberrypi ~ $
Westcott
Post by Westcott »
Yes - I have
mvzut
Post by mvzut »
I got exactly the same output as jorishp.
Turned out that the files we need are not in /usr/local/share/lua/5.2 but in /usr/local/share/lua/5.1/ So this is what I did:
pi@raspberrypi ~ $ sudo cp /usr/local/share/lua/5.1/*.lua /usr/local/share/lua/5.2
And this is the result:
pi@raspberrypi ~ $ lua test.lua
L=CxMOQwkSGAAYAAAADBIYAAkSGAQYAAAAnQwSF58JEhgEGAAAAJkLExCVCRIYABgAAAA=
Len=12  Adr=130E43      batt=0  bst=0   mode=1
Valve pos=0     Setpoint=12     Temp=0
pi@raspberrypi ~ $
Not sure why the files were not installed in 5.2 and if simply copying them from 5.1 to 5.2 is a smart thing to do, but at least it seems to work now!
What I don't understand yet: I have two wall thermostats and two radiator valves, and I thought the L-message should give some kind of device list, but I don't see that in the output?! I read some interesting info at https://github.com/Bouni/max-cube-protocol, but I still don't really get the function of the L: message.
Is your output completely different? I guess we need to decode the C: messages too to get the real device data?
blackdog65
Post by blackdog65 »
Hiya,
I get a similar output as mvzut
L=CxOGXgkSGAAnAAAADBNwhAkSGAEnAAAAyQsThi8JEhgAJwAAAAwJbJ4JEhgAJwAAAMwME3A1CRIYAScAAADMCw646AkSGAAnAAAA
Len=12	Adr=13865E	batt=0	bst=0	mode=1
Valve pos=0	Setpoint=19.5	Temp=0
I have 3 room stats and three radiator valves
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
Westcott
Post by Westcott »
Thanks to both of you for persevering!.
Your L= data is perfect.
Here is a new version with much improved decoding.
It'll also print the M= data, so I can get your device names.
New code below -
package.loadlib("core.so", "*")
local socket = require "socket"
local basexx = require "basexx"
--MaxIP='172.16.176.26'
MaxIP='KEQ0817132' -- Your Cube's IP name
MaxPort=62910
function maxCmd_H(data)
--	print('H='..data)
function maxCmd_M(data)
	print('M='..data)
function maxCmd_C(data)
--	print('C='..data)
function maxCmd_L(data)
print('L='..data)
	pos = 1
	dec = basexx.from_base64(data)
	L_hex = basexx.to_hex(dec)
	L_len = string.len(L_hex)
	while (pos < L_len) do -- Extract the data for one device at a time
		s = L_hex:sub(pos,(pos+1))
		data_len = tonumber(s,16) + 1
		hex = L_hex:sub(pos,pos+(data_len*2))
		valve_adr  = hex:sub(3,8)
		valve_info = tonumber(hex:sub(13,14),16)
		batt = bit32.extract(valve_info,7,1)
		bst  = bit32.extract(valve_info,3,1)
		mode = bit32.extract(valve_info,0,2)
		if (batt==0) then sbat="OK" else sbat="Low" end
		if (mode==0) then smode="Auto" elseif (mode==1) then smode="Manual"
		elseif (mode==2) then smode="Holiday" elseif (mode==3) then smode="Boost" end
	print("Len="..data_len, "Adr="..valve_adr, "batt="..sbat, "mode="..smode, "bst="..bst)
		if (data_len == 13) then	-- WallMountedThermostat (dev_type 3)
			s = hex:sub(17,18)
			setpoint = tonumber(s,16) / 2
			s = hex:sub(25,26)
			temp = tonumber(s,16) / 10
	print("Thermostat setpoint="..setpoint, "Temp="..temp)
		elseif (data_len == 12) then -- HeatingThermostat (dev_type 1 or 2)
			s = hex:sub(15,16)
			valve_pos = tonumber(s,16)
			s = hex:sub(17,18)
			s = hex:sub(21,22)
	print("Valve pos="..valve_pos, "Setpoint="..setpoint, "Temp="..temp)
		pos = pos + (data_len*2)
local tcp = socket.connect(MaxIP, MaxPort)
if not tcp then
	print("Socket connect failed for "..MaxIP..':'..MaxPort)
	return
tcp:settimeout(2)
while true do
    s, status, partial = tcp:receive()
    if (status) then
		print("TCP receive - "..status)
		break
    local line = (s or partial)
	local cmd  = line:sub(1,1)
	local data = line:sub(3)
	if (cmd == 'H') then
		maxCmd_H(data)
	elseif (cmd == 'M') then
		maxCmd_M(data)
	elseif (cmd == 'C') then
		maxCmd_C(data)
	elseif (cmd == 'L') then
		maxCmd_L(data)
		break
tcp:close()
blackdog65
Looks promising!
M=00,01,VgIDAQlCZWRyb29tLTEThl4CCVNpdHRpbmdSbQ646AMHS2l0Y2hlbhOGLwYDE3CETUVRMDg1NjQzNQpXYWxsU3RhdC0xAQEThl5NRVExNDY3NjQzCVJhZGlhdG9yMQEDCWyeS0VRMDQ5OTEwNwpXYWxsU3RhdC0xAgEOuOhMRVEwMDUyNjc5ClJhZGlhdG9yLTECAxNwNU1FUTA4NTY1MTYKV2FsbFN0YXQtMQMBE4YvTUVRMTQ2NzY5NQpSYWRpYXRvci0xAwE=
L=CxOGXgkSGAAnAAAADBNwhAkSGAEnAAAA0AsThi8JEhgAJwAAAAwJbJ4JEhgAJwAAAMoME3A1CRIYAScAAADKCw646AkSGAAnAAAA
Len=12	Adr=13865E	batt=OK	mode=Auto	bst=1
Len=13	Adr=137084	batt=OK	mode=Auto	bst=1
Thermostat setpoint=19.5	Temp=20.8
Len=12	Adr=13862F	batt=OK	mode=Auto	bst=1
Len=13	Adr=096C9E	batt=OK	mode=Auto	bst=1
Thermostat setpoint=19.5	Temp=20.2
Len=13	Adr=137035	batt=OK	mode=Auto	bst=1
Len=12	Adr=0EB8E8	batt=OK	mode=Auto	bst=1
So... 6 devices show up, 3 stats and 3 valves. Looks like we'll have to re-install one at a time (when your script is all running ok :D ) and rename one by one... which has to be done with Maxbuddy anyway, so no biggy.
Good work so far Matey! :D
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
Westcott
Post by Westcott »
Thanks for the data, BD.
Decoding the new M= data will take a little while, so remember to breathe occasionally, please!
blackdog65
Westcott wrote:Thanks for the data, BD.
Most welcome, but I'll be away for a fortnight, so no help for a while. ;)
You have to realize that the intelligent control of the heating system is THE most important and exciting part of Domoticz for Mrs. BD :lol: :roll:
I was on the verge of switching to Honeywell EvoHome as I'd had no real success with z-wave, so getting full-on control of ELV Max! is a right result!
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
Skippiemanz
Domoticz version: 4.10233
Post by Skippiemanz »
Looks good! Keep up the good work!
Verstuurd vanaf mijn SM-G925F met Tapatalk
mvzut
Post by mvzut »
M=00,01,VgICAQtLYW1lciBOaWVscxMOQwIMU3R1ZGVlcmthbWVyExCVBAMSF59NRVEwODUzNDQ2F1RoZXJtb3N0YWF0IGthbWVyIE5pZWxzAQETDkNNRVExNDQ0NzAzGVJhZGlhdG9ya3J
hYW4ga2FtZXIgTmllbHMBAxIYAE1FUTA4NTMzMzYYVGhlcm1vc3RhYXQgc3R1ZGVlcmthbWVyAgETEJVNRVExNDQzODY4GlJhZGlhdG9ya3JhYW4gc3R1ZGVlcmthbWVyAgE=
L=CxMOQwkSGAAYAAAADBIYAAkSGAQYAAAAmAwSF58JEhgEGAAAAJkLExCVCRIYABgAAAA=
Len=12  Adr=130E43      batt=OK mode=Auto       bst=1
Len=13  Adr=121800      batt=OK mode=Auto       bst=1
Thermostat setpoint=12  Temp=15.2
Len=13  Adr=12179F      batt=OK mode=Auto       bst=1
Thermostat setpoint=12  Temp=15.3
Len=12  Adr=131095      batt=OK mode=Auto
Nice, these are indeed my two thermostats and two control valves!
Westcott
Post by Westcott »
Thanks for the data!
Westcott
Post by Westcott »
Some new code.
This fully decodes device names and status data.
It is only a small step to actually updating Domoticz devices.
local Socket = require "socket"
local Basexx = require "basexx"
local MaxIP = 'your IP name'
local MaxPort = 62910
local Rooms   = {}
local Devices = {}
	i = 0
	j = 0
    while true do    -- find 'next' comma
      i = string.find(data, ",", i+1)
      if not i then break end
	  j = i
	s   = data:sub(j+1)
	dec = Basexx.from_base64(s)
	num_rooms = string.byte(dec,3)
	pos=4
	for i=1, num_rooms do
		room_num = string.byte(dec, pos)
		name_len = string.byte(dec, pos+1)
		pos  = pos+2
		name = dec:sub(pos, pos+name_len)
		pos  = pos+name_len
		adr  = Basexx.to_hex(dec:sub(pos, pos+2))
		Rooms[adr] = name
		pos = pos+3
	print("Rooms\n-----")
	for adr, name in pairs(Rooms) do
		print(name, adr)
	num_devs = string.byte(dec, pos)
	for i=1, num_devs do
		dtype = string.byte(dec, pos+1)
		adr   = Basexx.to_hex(dec:sub(pos+2, pos+4))
		snum  = dec:sub(pos+5, pos+14)
		name_len = string.byte(dec, pos+15)
		pos  = pos+16
		pos  = pos+name_len
		Devices[adr] = name
	print("\nDevices\n-------")
		for adr, name in pairs(Devices) do
		print(name, adr)
print("\nDevice status\n-------------")
	pos = 1
	dec = Basexx.from_base64(data)
	L_hex = Basexx.to_hex(dec)
		adr  = hex:sub(3,8)
		name = Devices[adr]
		if not name then name=adr end
			valve_pos = -1
			s = hex:sub(17,18)
			s = hex:sub(25,26)
			dtype = "Thermostat"
			s = hex:sub(15,16)
			s = hex:sub(17,18)
			s = hex:sub(21,22)
			dtype = "Valve    "
print(dtype, name, "Setpoint="..setpoint, "Temp="..temp, "Valve pos="..valve_pos, "Battery="..sbat, "Mode="..smode)
local tcp = Socket.connect(MaxIP, MaxPort)
if not tcp then
	return
tcp:settimeout(2)
while true do
    if (status) then
		break
		maxCmd_H(data)
		maxCmd_M(data)
		maxCmd_C(data)
		maxCmd_L(data)
		break
tcp:close()
mvzut
Post by mvzut »
I get:
Rooms
Studeerkamer   131095
Kamer Niels    130E43
Devices
Thermostaat studeerkamer       121800
Thermostaat kamer Niels        12179F
Radiatorkraan studeerkamer     131095
Radiatorkraan kamer Niels      130E43
Device status
Valve           Radiatorkraan kamer Niels      Setpoint=12     Temp=0  Valve pos=0     Battery=OK      Mode=Auto
Thermostat      Thermostaat studeerkamer       Setpoint=12     Temp=15.3       Valve pos=-1    Battery=OK      Mode=Auto
Thermostat      Thermostaat kamer Niels        Setpoint=12     Temp=15.7       Valve pos=-1    Battery=OK      Mode=Auto
Valve           Radiatorkraan studeerkamer     Setpoint=12     Temp=0  Valve pos=0     Battery=OK      Mode=Auto
pi@raspberrypi ~ $
Nice progress! The valve positions at the thermostat are "-1", what does that mean? What do valve positions mean at all for thermostats (since they don't even have a valve)?
Thanks for your hard work! When I have time, I will start integrating this in my multi-room script that controls my boiler based on the status of the Max! valves. I currently use Max! Buddy for that, but this is not ideal. Once in a while, Max! Buddy doesn't find my Cube after a restart of my Pi, which has lead to undesired situations. Moreover, it seems overkill to have so many programs and scripts running in the background, basically just to switch on my boiler when one of the valves is >0 and the boiler is not on. Your work has made it possible for me to significantly simplify my setup!
Next great step would be if we could also change the setpoint of the thermostats. Do you have an idea how to achieve that?
Westcott
Post by Westcott »
Hi Mvzut,
Thanks for the kind words!
Valve position -1 means it does not have a valve, it is just for debug printing porpoises.
When I get my replacement Cube I can work on sending data TO valves.
Also need to discover why nobody else's valves send their actual temperatures. Mine does.
Possibly valve firmware versions?
mvzut
Post by mvzut »
Westcott wrote:Hi Mvzut,
I think I read somewhere that the valves DO send their actual temperatures, but only after they have received a new setpoint, and for a limited amount of time. Probably they go into a low power mode to save battery. I'll check if this is true when I have some time.
Skippiemanz
i thought that the valves only send there temp when the valves are in motion.
But maybe i'm wrong. I sure hope so ;)
mvzut
Post by mvzut »
Skippiemanz wrote:i thought that the valves only send there temp when the valves are in motion.
Just checked, and I can confirm that the valves indeed only briefly report the actual temperature when they just received a new setpoint.
Meza
Post by Meza »
I saw a script somewhere else once where the author
"asked" a valve for it's position by setting a different set point temporarily and then immediately setting it back to the original value. Sorry I don't remember where though!
Sent from my PLK-L01 using Tapatalk
Westcott
Post by Westcott »
Thanks Meza, that's a neat trick.
I'll try it when my Cube reappears.
