ELV Max! Heating control system
- Westcott
Re: ELV Max! Heating control system
I can't remember how I did it, but this might help -
http://www.domoticz.com/forum/viewtopic ... 638#p22638
jorishp
do you have the same files for basexx?
pi@raspberrypi ~ $ lua max.lua
lua: max.lua:2: module 'basexx' not found:
no field package.preload['basexx']
no file '/usr/local/share/lua/5.2/basexx.lua'
no file '/usr/local/share/lua/5.2/basexx/init.lua'
no file '/usr/local/lib/lua/5.2/basexx.lua'
no file '/usr/local/lib/lua/5.2/basexx/init.lua'
no file './basexx.lua'
no file '/usr/share/lua/5.2/basexx.lua'
no file '/usr/share/lua/5.2/basexx/init.lua'
no file '/usr/local/lib/lua/5.2/basexx.so'
no file '/usr/lib/arm-linux-gnueabihf/lua/5.2/basexx.so'
no file '/usr/lib/lua/5.2/basexx.so'
no file '/usr/local/lib/lua/5.2/loadall.so'
no file './basexx.so'
stack traceback:
[C]: in function 'require'
max.lua:2: in main chunk
[C]: in ?
pi@raspberrypi ~ $ - Westcott
Yes - I have
mvzut
I got exactly the same output as jorishp.
Turned out that the files we need are not in /usr/local/share/lua/5.2 but in /usr/local/share/lua/5.1/ So this is what I did:
And this is the result:
Not sure why the files were not installed in 5.2 and if simply copying them from 5.1 to 5.2 is a smart thing to do, but at least it seems to work now!
What I don't understand yet: I have two wall thermostats and two radiator valves, and I thought the L-message should give some kind of device list, but I don't see that in the output?! I read some interesting info at https://github.com/Bouni/max-cube-protocol, but I still don't really get the function of the L: message.
Is your output completely different? I guess we need to decode the C: messages too to get the real device data?
pi@raspberrypi ~ $ sudo cp /usr/local/share/lua/5.1/*.lua /usr/local/share/lua/5.2Code: Select all
pi@raspberrypi ~ $ lua test.lua
L=CxMOQwkSGAAYAAAADBIYAAkSGAQYAAAAnQwSF58JEhgEGAAAAJkLExCVCRIYABgAAAA=
Len=12 Adr=130E43 batt=0 bst=0 mode=1
Valve pos=0 Setpoint=12 Temp=0
pi@raspberrypi ~ $ What I don't understand yet: I have two wall thermostats and two radiator valves, and I thought the L-message should give some kind of device list, but I don't see that in the output?! I read some interesting info at https://github.com/Bouni/max-cube-protocol, but I still don't really get the function of the L: message.
- blackdog65
Hiya,
I get a similar output as mvzut
I have 3 room stats and three radiator valves
L=CxOGXgkSGAAnAAAADBNwhAkSGAEnAAAAyQsThi8JEhgAJwAAAAwJbJ4JEhgAJwAAAMwME3A1CRIYAScAAADMCw646AkSGAAnAAAA
Len=12 Adr=13865E batt=0 bst=0 mode=1
Valve pos=0 Setpoint=19.5 Temp=0
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
- Westcott
Thanks to both of you for persevering!.
Your L= data is perfect.
Here is a new version with much improved decoding.
It'll also print the M= data, so I can get your device names.
New code below -
New code below -
package.loadlib("core.so", "*")
local socket = require "socket"
local basexx = require "basexx"
--MaxIP='172.16.176.26'
MaxIP='KEQ0817132' -- Your Cube's IP name
MaxPort=62910
function maxCmd_H(data)
-- print('H='..data)
function maxCmd_M(data)
print('M='..data)
function maxCmd_C(data)
-- print('C='..data)
function maxCmd_L(data)
print('L='..data)
pos = 1
dec = basexx.from_base64(data)
L_hex = basexx.to_hex(dec)
L_len = string.len(L_hex)
while (pos < L_len) do -- Extract the data for one device at a time
s = L_hex:sub(pos,(pos+1))
data_len = tonumber(s,16) + 1
hex = L_hex:sub(pos,pos+(data_len*2))
valve_adr = hex:sub(3,8)
valve_info = tonumber(hex:sub(13,14),16)
batt = bit32.extract(valve_info,7,1)
bst = bit32.extract(valve_info,3,1)
mode = bit32.extract(valve_info,0,2)
if (batt==0) then sbat="OK" else sbat="Low" end
if (mode==0) then smode="Auto" elseif (mode==1) then smode="Manual"
elseif (mode==2) then smode="Holiday" elseif (mode==3) then smode="Boost" end
print("Len="..data_len, "Adr="..valve_adr, "batt="..sbat, "mode="..smode, "bst="..bst)
if (data_len == 13) then -- WallMountedThermostat (dev_type 3)
s = hex:sub(17,18)
setpoint = tonumber(s,16) / 2
s = hex:sub(25,26)
temp = tonumber(s,16) / 10
print("Thermostat setpoint="..setpoint, "Temp="..temp)
elseif (data_len == 12) then -- HeatingThermostat (dev_type 1 or 2)
s = hex:sub(15,16)
valve_pos = tonumber(s,16)
s = hex:sub(17,18)
s = hex:sub(21,22)
print("Valve pos="..valve_pos, "Setpoint="..setpoint, "Temp="..temp)
pos = pos + (data_len*2)
local tcp = socket.connect(MaxIP, MaxPort)
if not tcp then
print("Socket connect failed for "..MaxIP..':'..MaxPort)
return
tcp:settimeout(2)
while true do
s, status, partial = tcp:receive()
if (status) then
print("TCP receive - "..status)
break
local line = (s or partial)
local cmd = line:sub(1,1)
local data = line:sub(3)
if (cmd == 'H') then
maxCmd_H(data)
elseif (cmd == 'M') then
maxCmd_M(data)
elseif (cmd == 'C') then
maxCmd_C(data)
elseif (cmd == 'L') then
maxCmd_L(data)
break
tcp:close()
- blackdog65
Looks promising!
So... 6 devices show up, 3 stats and 3 valves. Looks like we'll have to re-install one at a time (when your script is all running ok
) and rename one by one... which has to be done with Maxbuddy anyway, so no biggy.
Good work so far Matey!
M=00,01,VgIDAQlCZWRyb29tLTEThl4CCVNpdHRpbmdSbQ646AMHS2l0Y2hlbhOGLwYDE3CETUVRMDg1NjQzNQpXYWxsU3RhdC0xAQEThl5NRVExNDY3NjQzCVJhZGlhdG9yMQEDCWyeS0VRMDQ5OTEwNwpXYWxsU3RhdC0xAgEOuOhMRVEwMDUyNjc5ClJhZGlhdG9yLTECAxNwNU1FUTA4NTY1MTYKV2FsbFN0YXQtMQMBE4YvTUVRMTQ2NzY5NQpSYWRpYXRvci0xAwE=
L=CxOGXgkSGAAnAAAADBNwhAkSGAEnAAAA0AsThi8JEhgAJwAAAAwJbJ4JEhgAJwAAAMoME3A1CRIYAScAAADKCw646AkSGAAnAAAA
Len=12 Adr=13865E batt=OK mode=Auto bst=1
Len=13 Adr=137084 batt=OK mode=Auto bst=1
Thermostat setpoint=19.5 Temp=20.8
Len=12 Adr=13862F batt=OK mode=Auto bst=1
Len=13 Adr=096C9E batt=OK mode=Auto bst=1
Thermostat setpoint=19.5 Temp=20.2
Len=13 Adr=137035 batt=OK mode=Auto bst=1
Len=12 Adr=0EB8E8 batt=OK mode=Auto bst=1
Valve pos=0 Setpoint=19.5 Temp=0Good work so far Matey!
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
- Westcott
Thanks for the data, BD.
Decoding the new M= data will take a little while, so remember to breathe occasionally, please!
- blackdog65
Most welcome, but I'll be away for a fortnight, so no help for a while.Westcott wrote:Thanks for the data, BD.
You have to realize that the intelligent control of the heating system is THE most important and exciting part of Domoticz for Mrs. BD
I was on the verge of switching to Honeywell EvoHome as I'd had no real success with z-wave, so getting full-on control of ELV Max! is a right result!
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
Skippiemanz
- Domoticz version: 4.10233
Looks good! Keep up the good work!
Verstuurd vanaf mijn SM-G925F met Tapatalk
mvzut
M=00,01,VgICAQtLYW1lciBOaWVscxMOQwIMU3R1ZGVlcmthbWVyExCVBAMSF59NRVEwODUzNDQ2F1RoZXJtb3N0YWF0IGthbWVyIE5pZWxzAQETDkNNRVExNDQ0NzAzGVJhZGlhdG9ya3J
hYW4ga2FtZXIgTmllbHMBAxIYAE1FUTA4NTMzMzYYVGhlcm1vc3RhYXQgc3R1ZGVlcmthbWVyAgETEJVNRVExNDQzODY4GlJhZGlhdG9ya3JhYW4gc3R1ZGVlcmthbWVyAgE=
L=CxMOQwkSGAAYAAAADBIYAAkSGAQYAAAAmAwSF58JEhgEGAAAAJkLExCVCRIYABgAAAA=
Len=12 Adr=130E43 batt=OK mode=Auto bst=1
Len=13 Adr=121800 batt=OK mode=Auto bst=1
Thermostat setpoint=12 Temp=15.2
Len=13 Adr=12179F batt=OK mode=Auto bst=1
Thermostat setpoint=12 Temp=15.3
Len=12 Adr=131095 batt=OK mode=Auto Raspberry Pi 4 - RFXtrx433 - CC2531 Zigbee - Opentherm Gateway - P1 smart meter - Netatmo - Philips Hue - ELV Max! - ESP8266 DIY water meter - 6 x Sonos - 4 x IP cameras - Wall mounted tablet + Dashticz - Google Home integration - MANY switches/sensors
- Westcott
Thanks for the data!
- Westcott
Some new code.
This fully decodes device names and status data.
It is only a small step to actually updating Domoticz devices.
local Socket = require "socket"
local Basexx = require "basexx"
local MaxIP = 'your IP name'
local MaxPort = 62910
local Rooms = {}
local Devices = {}
i = 0
j = 0
while true do -- find 'next' comma
i = string.find(data, ",", i+1)
if not i then break end
j = i
s = data:sub(j+1)
dec = Basexx.from_base64(s)
num_rooms = string.byte(dec,3)
pos=4
for i=1, num_rooms do
room_num = string.byte(dec, pos)
name_len = string.byte(dec, pos+1)
pos = pos+2
name = dec:sub(pos, pos+name_len)
pos = pos+name_len
adr = Basexx.to_hex(dec:sub(pos, pos+2))
Rooms[adr] = name
pos = pos+3
print("Rooms\n-----")
for adr, name in pairs(Rooms) do
print(name, adr)
num_devs = string.byte(dec, pos)
for i=1, num_devs do
dtype = string.byte(dec, pos+1)
adr = Basexx.to_hex(dec:sub(pos+2, pos+4))
snum = dec:sub(pos+5, pos+14)
name_len = string.byte(dec, pos+15)
pos = pos+16
pos = pos+name_len
Devices[adr] = name
print("\nDevices\n-------")
for adr, name in pairs(Devices) do
print(name, adr)
print("\nDevice status\n-------------")
pos = 1
dec = Basexx.from_base64(data)
L_hex = Basexx.to_hex(dec)
adr = hex:sub(3,8)
name = Devices[adr]
if not name then name=adr end
valve_pos = -1
s = hex:sub(17,18)
s = hex:sub(25,26)
dtype = "Thermostat"
s = hex:sub(15,16)
s = hex:sub(17,18)
s = hex:sub(21,22)
dtype = "Valve "
print(dtype, name, "Setpoint="..setpoint, "Temp="..temp, "Valve pos="..valve_pos, "Battery="..sbat, "Mode="..smode)
local tcp = Socket.connect(MaxIP, MaxPort)
if not tcp then
return
tcp:settimeout(2)
while true do
if (status) then
break
maxCmd_H(data)
maxCmd_M(data)
maxCmd_C(data)
maxCmd_L(data)
break
tcp:close()
mvzut
I get:
Nice progress! The valve positions at the thermostat are "-1", what does that mean? What do valve positions mean at all for thermostats (since they don't even have a valve)?
Thanks for your hard work! When I have time, I will start integrating this in my multi-room script that controls my boiler based on the status of the Max! valves. I currently use Max! Buddy for that, but this is not ideal. Once in a while, Max! Buddy doesn't find my Cube after a restart of my Pi, which has lead to undesired situations. Moreover, it seems overkill to have so many programs and scripts running in the background, basically just to switch on my boiler when one of the valves is >0 and the boiler is not on. Your work has made it possible for me to significantly simplify my setup!
Next great step would be if we could also change the setpoint of the thermostats. Do you have an idea how to achieve that?
Rooms
Studeerkamer 131095
Kamer Niels 130E43
Devices
Thermostaat studeerkamer 121800
Thermostaat kamer Niels 12179F
Radiatorkraan studeerkamer 131095
Radiatorkraan kamer Niels 130E43
Device status
Valve Radiatorkraan kamer Niels Setpoint=12 Temp=0 Valve pos=0 Battery=OK Mode=Auto
Thermostat Thermostaat studeerkamer Setpoint=12 Temp=15.3 Valve pos=-1 Battery=OK Mode=Auto
Thermostat Thermostaat kamer Niels Setpoint=12 Temp=15.7 Valve pos=-1 Battery=OK Mode=Auto
Valve Radiatorkraan studeerkamer Setpoint=12 Temp=0 Valve pos=0 Battery=OK Mode=Auto
pi@raspberrypi ~ $Thanks for your hard work! When I have time, I will start integrating this in my multi-room script that controls my boiler based on the status of the Max! valves. I currently use Max! Buddy for that, but this is not ideal. Once in a while, Max! Buddy doesn't find my Cube after a restart of my Pi, which has lead to undesired situations. Moreover, it seems overkill to have so many programs and scripts running in the background, basically just to switch on my boiler when one of the valves is >0 and the boiler is not on. Your work has made it possible for me to significantly simplify my setup!
- Westcott
Hi Mvzut,
Thanks for the kind words!
Valve position -1 means it does not have a valve, it is just for debug printing porpoises.
When I get my replacement Cube I can work on sending data TO valves.
Also need to discover why nobody else's valves send their actual temperatures. Mine does.
Possibly valve firmware versions?
mvzut
I think I read somewhere that the valves DO send their actual temperatures, but only after they have received a new setpoint, and for a limited amount of time. Probably they go into a low power mode to save battery. I'll check if this is true when I have some time.Westcott wrote:Hi Mvzut,
Skippiemanz
i thought that the valves only send there temp when the valves are in motion.
But maybe i'm wrong. I sure hope so
mvzut
Just checked, and I can confirm that the valves indeed only briefly report the actual temperature when they just received a new setpoint.Skippiemanz wrote:i thought that the valves only send there temp when the valves are in motion.
Meza
I saw a script somewhere else once where the author
"asked" a valve for it's position by setting a different set point temporarily and then immediately setting it back to the original value. Sorry I don't remember where though!
Sent from my PLK-L01 using Tapatalk
- Westcott
Thanks Meza, that's a neat trick.
I'll try it when my Cube reappears.
