Extracting Setpoint from a Radiatorvalve
DutchHans
Hi All,
I am trying to create a script to check if a temperature in a room is higher than the setpoint set by Domoticz. In that case I have to check the radiatorvalve. (Batteries could be dead) I have searched the forum for several hours but I cant find how to extract the setpoint for a radiator valve in Lua. The Setpoint is set to 15 but Otherdevices_svalues give me 0.0, same with otherdevices_temperature.
Anyone knows how to extract the setpoint from a radiator?
Regards, Hans
Regards, Hans
- Westcott
Re: Extracting Setpoint from a Radiatorvalve
Hi Hans,
Have you added a device that displays your setpoint correctly?
setpoint = tonumber(otherdevices_svalues['Your setpoint device name'])
DutchHans
Yes, ive tried several, but no luck.
setpoint = tonumber(otherdevices_svalues['Radiator Bedroom']) and setpoint = tonumber(otherdevices_temperature['Radiator Bedroom'])
Any ideas?
Any ideas?
- Westcott
What does the device 'Radiator Bedroom' show in the Domoticz GUI?
What value does setpoint = tonumber(otherdevices_svalues['Radiator Bedroom']) print?
DutchHans
The GUI in Domoticz
2016-05-10 13:15:18.775 LUA: 0
2016-05-10 13:15:18.954 LUA: 0
2016-05-10 13:15:19.136 LUA: 0
- Westcott
Interesting!
Is it possible that you have more than 1 device called 'Radiator Bedroom'?
DutchHans
Hi Westcott,
Yes, when I add a radiatorvalve there are 2 items added with the same name. one holds the set temperature and one is a on/off switch
There are also two IDX's
BTW, thank you for replying so quickly..
- jvdz
- Domoticz version: 4.107
Just rename one of the two so they are both unique and you can use them in LUA.
Jos
Jos
DutchHans
I did rename one.. answer is still 0
2016-05-10 13:37:44.992 LUA: Radiator Bedroom Temperature is 0
Luigi87
With type of Danfoss product do you have?
I have the LG-13's and these do not send a acual temp.
DutchHans
Hi Luigi87,
Thanks for replying.
Smartwares Wireless Radiator valves
http://www.homewizard.co.uk/smartwares- ... valve.html
The valve itself doesnt send... but the setpoint is sent by Domoticz which is visible in the GUI. and I would like to use that Temperature to compare it with the actual measured temperature. If the actual temperature rises above the setpoint temperature than there must be an error (for example: battery faillure). I have had it once that I came back home after a few days and the bedroom was like a sauna, which costs a huge amount of wasted energy.
Regards..Hans
Regards..Hans
- Egregius
- Domoticz version: v2024.7
The value is in the data part of the json reply, shouldn't be that hard.
At least, not in php
DutchHans
Hi Egregius,
Maybe thats a start, only thing is... I am not a real programmer, I try to read code from others and combine things to fill my needs. Do you have an example?
Regards, Hans
Regards, Hans
Luigi87
Oke, now its clear to me. I thought I had read that you used a danfoss.DutchHans wrote:Hi Luigi87,
Regards..Hans
I Don't know how thats works yet. but i will also follow this topic.
I hope to have some time by the end of this year to implement this also.
DutchHans
Someone else any ideas? I guess it must be possible to extract the setpoint but I have really no idea...
Regards, Hans
Regards, Hans
- jvdz
What does it return without converting it tonumber? so just:
Jos
print(otherdevices_svalues['Radiator Bedroom'])
DutchHans
Hi Jos,
The line:
shows this in the log:
2016-05-11 09:04:29.249 LUA: 0.0
But the setpoint in the Domoticz Gui still returns 15.0°C
Regards, Hans
The line:
Regards, Hans
- jvdz
Could you show a screen capture of the devices list and simply put in a filter like "Radiator"?
This will show the existing devices with that name in it and their current values.
r/Jos
r/Jos
DutchHans
Hi Jos,
The complete list of radiators (4 pieces)
- radiators.jpg (263.4 KiB) Viewed 3736 times
DutchHans
Its getting weirder...I tested it in Blockly
returns in the log:
So, why not in Lua????
regards, Hans
regards, Hans
