Extracting Setpoint from a Radiatorvalve
DutchHans
Post by DutchHans »
Hi All,
I am trying to create a script to check if a temperature in a room is higher than the setpoint set by Domoticz. In that case I have to check the radiatorvalve. (Batteries could be dead) I have searched the forum for several hours but I cant find how to extract the setpoint for a radiator valve in Lua. The Setpoint is set to 15 but Otherdevices_svalues give me 0.0, same with otherdevices_temperature.
Anyone knows how to extract the setpoint from a radiator?
Regards, Hans
Westcott
Re: Extracting Setpoint from a Radiatorvalve
Post by Westcott »
Hi Hans,
Have you added a device that displays your setpoint correctly?
setpoint = tonumber(otherdevices_svalues['Your setpoint device name'])
DutchHans
Post by DutchHans »
Yes, ive tried several, but no luck.
setpoint = tonumber(otherdevices_svalues['Radiator Bedroom']) and setpoint = tonumber(otherdevices_temperature['Radiator Bedroom'])
Any ideas?
Westcott
Post by Westcott »
What does the device 'Radiator Bedroom' show in the Domoticz GUI?
What value does setpoint = tonumber(otherdevices_svalues['Radiator Bedroom']) print?
DutchHans
Post by DutchHans »
The GUI in Domoticz
2016-05-10 13:15:18.775 LUA: 0
2016-05-10 13:15:18.954 LUA: 0
2016-05-10 13:15:19.136 LUA: 0
Westcott
Post by Westcott »
Interesting!
Is it possible that you have more than 1 device called 'Radiator Bedroom'?
DutchHans
Post by DutchHans »
Hi Westcott,
Yes, when I add a radiatorvalve there are 2 items added with the same name. one holds the set temperature and one is a on/off switch
There are also two IDX's
BTW, thank you for replying so quickly..
jvdz
Domoticz version: 4.107
Post by jvdz »
Just rename one of the two so they are both unique and you can use them in LUA.
Jos
DutchHans
Post by DutchHans »
I did rename one.. answer is still 0
2016-05-10 13:37:44.992 LUA: Radiator Bedroom Temperature is 0
Luigi87
Post by Luigi87 »
With type of Danfoss product do you have?
I have the LG-13's and these do not send a acual temp.
DutchHans
Post by DutchHans »
Hi Luigi87,
Thanks for replying.
Smartwares Wireless Radiator valves
http://www.homewizard.co.uk/smartwares- ... valve.html
The valve itself doesnt send... but the setpoint is sent by Domoticz which is visible in the GUI. and I would like to use that Temperature to compare it with the actual measured temperature. If the actual temperature rises above the setpoint temperature than there must be an error (for example: battery faillure). I have had it once that I came back home after a few days and the bedroom was like a sauna, which costs a huge amount of wasted energy.
Regards..Hans
Egregius
Domoticz version: v2024.7
Post by Egregius »
The value is in the data part of the json reply, shouldn't be that hard.
At least, not in php :lol:
DutchHans
Post by DutchHans »
Hi Egregius,
Maybe thats a start, only thing is... I am not a real programmer, I try to read code from others and combine things to fill my needs. Do you have an example?
Regards, Hans
Luigi87
Post by Luigi87 »
DutchHans wrote:Hi Luigi87,
Regards..Hans
Oke, now its clear to me. I thought I had read that you used a danfoss.
I Don't know how thats works yet. but i will also follow this topic.
I hope to have some time by the end of this year to implement this also.
DutchHans
Post by DutchHans »
Someone else any ideas? I guess it must be possible to extract the setpoint but I have really no idea...
Regards, Hans
jvdz
Post by jvdz »
What does it return without converting it tonumber? so just:
print(otherdevices_svalues['Radiator Bedroom'])
Jos
DutchHans
Post by DutchHans »
Hi Jos,
The line:
shows this in the log:
2016-05-11 09:04:29.249 LUA: 0.0
But the setpoint in the Domoticz Gui still returns 15.0°C
Regards, Hans
jvdz
Post by jvdz »
Could you show a screen capture of the devices list and simply put in a filter like "Radiator"?
This will show the existing devices with that name in it and their current values.
r/Jos
DutchHans
Post by DutchHans »
Hi Jos,
The complete list of radiators (4 pieces)
DutchHans
Post by DutchHans »
Its getting weirder...I tested it in Blockly
returns in the log:
So, why not in Lua????
regards, Hans
