cannot see z-wave devices
course66
Domoticz version: V2.3202
Post by course66 »
I installed an Aeon USB Stick Gen 5 on the raspberry pi 2, after having linked it to the Stick the Fibaro motion sensor. Domoticz firstly saw both the Aeon and Fibaro devices within the Aeon Stick setup page, but couldn't see the parameters (light, temperature and so) related to Fibaro device on devices page. After a domoticz upgrade the setup button on domoticz is red
Screen Shot 2016-03-05 at 08.35.21.png (260.53 KiB) Viewed 4476 times
and the device setup page is empty
I did stop and started again domoticz without solving this issue.
can anyone tell what should I do?
thanks and ciao,
gabriele
jvdz
Domoticz version: 4.107
Re: cannot see z-wave devices
Post by jvdz »
Does the domoticz.log show any errors?
Jos
course66
Post by course66 »
nope :(
unless these http://www.domoticz.com/forum/viewtopic.php?f=6&t=11002 but I do not think they are related.
jvdz
Post by jvdz »
Well your domoticz.log should at least show the startup messages and for z-wave the devices it found in the config.
Jos
course66
Post by course66 »
very strange, I rebooted the rpi (after system update) and now setup button in blue.
Screen Shot 2016-03-10 at 20.14.53.png (203.45 KiB) Viewed 4458 times
When I click on the setup button two pop-ups appear:
Screen Shot 2016-03-10 at 20.15.02.png (69.63 KiB) Viewed 4458 times
Screen Shot 2016-03-10 at 20.15.07.png (84.18 KiB) Viewed 4458 times
course66
Post by course66 »
then I see the devices in the Aeon setup page:
Screen Shot 2016-03-10 at 20.15.12.png (286.85 KiB) Viewed 4457 times
but couldn't see the Fibaro on the devices domoticz page. I see only two switches related to Aeon Stick
Screen Shot 2016-03-10 at 20.18.23.png (168.54 KiB) Viewed 4457 times
StephaneG
Post by StephaneG »
Devices 43 and 44 are your fibaro's sensors (their ID's are 000002xxx, and 2 is the fibaro's node number).
Regards,
Stéphane
course66
Post by course66 »
why fibaro sensor appear as two switches when it is a there-in-one sensor (motion, temperature and light)?
what should I do (apart click on green arrow)?
I also see some strange devices related to rpi2, could be from Fibaro sensor?
Screen Shot 2016-03-10 at 23.32.51.png (166.57 KiB) Viewed 4417 times
thanks
gabriele
Slinkos
Domoticz version: 3.4834
Post by Slinkos »
Maybe the wrong port was selected
bbqkees
Domoticz version: 4.1x
Post by bbqkees »
course66 wrote:why fibaro sensor appear as two switches when it is a there-in-one sensor (motion, temperature and light)?
First follow the following guide so the ZWave stick will always have the same USB port number after reboot.
http://www.domoticz.com/wiki/PersistentUSBDevices
Second remove the 'SBFSpot' hardware in your hardware list. This gives the 'wrong' devices in your list.
course66
Post by course66 »
thanks bbqkees,
I'm getting your suggestions. I'll try. Unfortunately now I'm out of home and mydomoticz is not working (for me).
course66
Post by course66 »
Hi bbqkees,
I removed Aeon, made Aeon persistent on usb, deleted SBFspot, re-booted, connected Aeon hardware to new USB port.
Screen Shot 2016-03-14 at 20.48.15.png (127.82 KiB) Viewed 4331 times
Screen Shot 2016-03-14 at 20.48.29.png (208.3 KiB) Viewed 4331 times
but...
course66
Post by course66 »
I still see only two switches
Screen Shot 2016-03-14 at 20.48.39.png (319.76 KiB) Viewed 4327 times
even if from the log it seems that domoticz+aeon can read other devices...
any idea?
thanks and ciao
bbqkees
Post by bbqkees »
Did you try to exclude and re-include the device?
Kroontje
Post by Kroontje »
Disable polling for the motion sensor, wake up the sensor by 3x clicking the include button and filter under Devices for Aeon or '00002' and see what shows up. The logging tells you that the Temperature and Luminance nodes are added. :)
quique
Post by quique »
Any news on this? Did you find a solution to the problem?
I have the same situation, installed a z-wave sensor (Secure) with 2 probes for tubes temperature measurements, so a total of 3 measurements in the same sensor and even if at the device registration shows in the log the fact that the sensor has different temperature registers I can see only one device in the setup/device menu and indeed receive only measurements for that device.
I can see the channels in the control panel but not as devices in domoticz.
Screen Shot 2018-01-12 at 09.17.21.png (76.05 KiB) Viewed 2918 times
My setup is domoticz with Synology NAS and the USB z-wave key.
Thanks for your help.
Users browsing this forum: Ahrefs [Bot] and 1 guest
