domoticz in synology as package! Available now.
jumbo70
Post by jumbo70 »
@jumbotroll
DSM5.2 5644
jumbotroll wrote:
jumbo70 wrote:Hi,
The 'killall synousbmodemd' command did not help. Actually 'No process was killed'.
Any idea if the Vision or Zwave.me usb stick will give similar problem, or is this problem specific for the Aeotec gen5 stick?
kind regards,
Jumbo70
What DSM version du you have on your NAS? 4.2,4.3 or 5.2?
jumbotroll
Post by jumbotroll »
jumbo70 wrote:@jumbotroll
DSM5.2 5644
jumbotroll wrote:
jumbo70 wrote:Hi,
kind regards,
Jumbo70
Ok.
Can you test this version?
domoticz_88f6281-5.2_3.0.4846-7.spk with cdc-acm drivers.
Manually download and install from package center.
http://www.jadahl.com/domoticz_beta/pac ... 4846-7.spk
https://paypal.me/Jumbotroll
Jumbotroll
G3rard
Domoticz version: No
Post by G3rard »
jumbotroll wrote:Domoticz V3.4834 Stable.
http://www.jadahl.com/domoticz_stable/
I will keep V2.3530 a while.
Thanks jumbotroll!
Just installed 3.4834 and it's seems to be working fine.
Not using Domoticz anymore
deennoo
Post by deennoo »
I start to move from a PI to a Syno.
Before putting all on my real syno, i made a "test" on an xpenology.
A question : what about hard drive stop ? On normal use when don't using the Nas, hard drive stop spinning.
As domoticz always write logs on DB, hard drive can't stop, is there any problème with this ?
http://domo-attitude.fr
j0bro
Post by j0bro »
I just upgraded my Synology DS215j (armada375) to DSM 6.0-7307 (RC), backed up my Domoticz db, uninstalled Domoticz, added the http://www.jadahl.com/domoticzbeta/ package source and installed the Domoticz beta package (version 3.0.4836-7). However, it won't run and complains about libstdc++.so.6 (see below). Anything else I should do? Thanks!
/usr/local/domoticz/bin/domoticz: /lib/libstdc++.so.6: no version information available (required by /usr/local/domoticz/lib/libboost_thread.so.1.59.0)
/usr/local/domoticz/bin/domoticz: /lib/libstdc++.so.6: no version information available (required by /usr/local/domoticz/lib/libboost_date_time.so.1.59.0)
/usr/local/domoticz/bin/domoticz: /lib/libstdc++.so.6: no version information available (required by /usr/local/domoticz/lib/libboost_system.so.1.59.0)
Gravityz
Domoticz version: 2025.1
Post by Gravityz »
wanted to install the stable version but instead picked 4836.
what exiting bugs did you squash in that version compared to the 4834 version
gizmocuz
Post by gizmocuz »
Gravityz
Post by Gravityz »
after installing 4836 i noticed the following(more people seem to have this problem)
Qubino ZMNHAD1 module
Temp:WORKING
kWh meter:NOT WORKING, NOT COUNTING
powermeter:WORKING
i have 2 kWh meters for qubino and both are not working.
fibaro FGD212
powermeter:WORKING
kWh meter:WORKING
Fibaro FGWPE plug
powermeter:WORKING
kWh meter:WORKING
jumbo70
Post by jumbo70 »
@jumbotroll,
Thanks for the support. Unfortunately I can't get it to work.
The aeotec stick is blinking, but does not show up in the external devices list nor do I see it as serial port within domoticz when selecting openzwave usb.
I added output of dmesg |grep usb. Maybe that might help.
PS, some other memory usb sticks pop-up immediately as external devices.
Thanks,
jumbo70
DSM5.2 5644
Ok.
dmesg after installation and restart 3.png (130.72 KiB) Viewed 3462 times
Pierryck
Post by Pierryck »
Thanks for this package, I réally enjoy to run Domoticz on my synology.
Vaaben
Post by Vaaben »
+1 to J0bro's problem - have the exactly same Syno - and the exactly same problem
j0bro wrote:I just upgraded my Synology DS215j (armada375) to DSM 6.0-7307 (RC), backed up my Domoticz db, uninstalled Domoticz, added the http://www.jadahl.com/domoticzbeta/ package source and installed the Domoticz beta package (version 3.0.4836-7). However, it won't run and complains about libstdc++.so.6 (see below). Anything else I should do? Thanks!
jumbotroll
I have never compiled domoticz for armada375.
This is the list for DSM6.0 http://www.jadahl.com/domoticz_beta_6/i ... llist=true
Jumbotroll
j0bro
Re: RE: Re: domoticz in synology as package! Available now.
Post by j0bro »
Well I have been running Domoticz for this architecture for well over a year, via the Synocommunity package but what I understand is that it isn't maintained anymore. My assumption was that my NAS was supported in this newer package version, but it seems I am out of luck.
I see you compile for armada370 already, any chance of including armada375 as well? The newer Synologies use this chipset a lot, you would make a lot of us happy [SMILING FACE WITH SMILING EYES]
Verstuurd vanaf mijn Nexus 6P met Tapatalk
jumbotroll
Ok, I have added toolchain and compiled for armada375 DSM 6.0 you can test.
http://www.jadahl.com/domoticz_beta_6/?arch=armada375
Jumbotroll
j0bro
Re: RE: Re: RE: Re: domoticz in synology as package! Available now.
Post by j0bro »
Hey that's terrific! Will test and report back as soon as I get home tonight. Thanks in advance my friend!
EDIT: Everything working just fine again, thanks for your blazing fast support!
dtech
Post by dtech »
Ok the synology I cannot update to the latest stable version, shall I do same magic, or wait till Jumbotroll will realize new version ?
Many thank
Egregius
Domoticz version: v2024.7
Post by Egregius »
Yes, working on a DS1513+ with DSM 6 beta with a S2 stick and rfxcom.
Moved from RPi2 to Syno because I had a new site to host there and there's builtin support for let's encrypt certificates now.
First moved my floorplan from RPi to Syno but that gived from time to time a timeout while connecting to Domoticz.
Now that everything is on the Syno it feels even faster than before :)
Egregius
Post by Egregius »
dtech wrote:Hi,
Many thank
Because Syno can be dangerous to update files I disabled the update check inside Domoticz and will wait for a package update from Jumbotroll.
Guess that's the safest way to keep it stable.
dtech
Post by dtech »
Egregius wrote: Because Syno can be dangerous to update files I disabled the update check inside Domoticz and will wait for a package update from Jumbotroll.
This was my idea that with Synology this will not be so easy, thx for info will wait for final realize.
jumbotroll
dtech wrote:Hi,
Many thank
What latest release/stable version do you not find?
And what issue do you have?
What NAS do you have?
What DSM version do you have?
Jumbotroll
