Philips LivingColors 1st gen
sebasdomoticz
Experts,
As a noob I would like to connect a Philips LivingColors 1st generation to my RPi running domoticz. Currently I only have 2 hardware devices, the Aeonlabs Z-wave stick and the RFXcom RFXtrx433ext.
On this website http://www.knutsel.org/nl/2009/01/01/li ... generatie/ it is said that the lamp is controlled over the 2,4 Ghz wave. That is probably the reason it is not found in the log file.
Is it possible to connect this lamp to my domoticz. If yes, how?
thnx.
thnx.
Derik
- Domoticz version: BETA
Re: Philips LivingColors 1st gen
Is there a Api?
sebasdomoticz
I have no idea. When a device operates over the 2,4 Ghz channel, can I still use it with domoticz using another antenna?
Derik
No way... Not that simple....sebasdomoticz wrote:I have no idea. When a device operates over the 2,4 Ghz channel, can I still use it with domoticz using another antenna?
Look voor the api of this thing...
I do have a Hue set working...
http://www.domoticz.com/forum/viewtopic ... hue#p19317
It seems someone designed a way to interface the LivingColors 1st gen over USB by using an Arduino and a custom shield:
http://www.knutsel.org/2010/04/11/assem ... no-shield/
http://www.knutsel.org/2010/01/08/hello-world/
http://www.knutsel.org/2012/09/04/livin ... -in-stock/
It looks like this might be the best way to go. But I guess you will need to write your own hookup to Domoticz.
daandamhuis
- Domoticz version: 2.4608
I'm sorry to revive this thread, but did someone manage to get this working? I've bought the shield and added my lamps in the Arduino code and I can control the lights through a serial connection.
Does someone have a Python script that can talk to Arduino through USB Serial Connection of the Raspberry Pi?
RPi Model 2: Domoticz Server (Beta)
RPi Model B+: Smart Meter Slave (Stable)
Particle Photon (2x): Prototyping, Controlling LEDS and gathering Sensor data for Domoticz
Arduino Uno R3: with CC2500 Shield for Philips LivingColor Lights 1st Gen.
mentalTheo
- Domoticz version: 3.8798
Daan, did you figure out a way to get it working?
TokTias
Hi !
I have posted my solution of controlling a gen 1 LivingColors lamp using MySensors and Domoticz here : https://forum.mysensors.org/topic/4638/ ... ensor-node
I then also found out that there's another solution here : https://forum.mysensors.org/topic/3080/ ... olors-lamp
Enjoy !
/T
Enjoy !
/T
____________________________________________
domoticz hooked up with :
Philips Hue (v2 Hub + 14 lamps)
MySensors (~15 nodes)
Roborock S5 Max
Broadlink RM2
Chromecast Audio & Video
Roborock S5 Max
Broadlink RM2
Deboer132
Myloweslife, lowes portal, and so on and also the https://my-loweslife.co Only when you click that; will certainly you be taken.
Any of the mass. It features a couple of ergonomic Know More The device's light weight aluminum motor housing.
Dorothy96
Simply flat-out failed to remember an account password could mymenards which is essential to staff members overall as well as.
