Philips LivingColors 1st gen
sebasdomoticz
Post by sebasdomoticz »
Experts,
As a noob I would like to connect a Philips LivingColors 1st generation to my RPi running domoticz. Currently I only have 2 hardware devices, the Aeonlabs Z-wave stick and the RFXcom RFXtrx433ext.
On this website http://www.knutsel.org/nl/2009/01/01/li ... generatie/ it is said that the lamp is controlled over the 2,4 Ghz wave. That is probably the reason it is not found in the log file.
Is it possible to connect this lamp to my domoticz. If yes, how?
thnx.
Derik
Re: Philips LivingColors 1st gen
Post by Derik »
Is there a Api?
sebasdomoticz
I have no idea. When a device operates over the 2,4 Ghz channel, can I still use it with domoticz using another antenna?
Derik
Post by Derik »
sebasdomoticz wrote:I have no idea. When a device operates over the 2,4 Ghz channel, can I still use it with domoticz using another antenna?
No way... Not that simple....
Look voor the api of this thing...
I do have a Hue set working...
http://www.domoticz.com/forum/viewtopic ... hue#p19317
Thice
Post by Thice »
It seems someone designed a way to interface the LivingColors 1st gen over USB by using an Arduino and a custom shield:
http://www.knutsel.org/2010/04/11/assem ... no-shield/
http://www.knutsel.org/2010/01/08/hello-world/
http://www.knutsel.org/2012/09/04/livin ... -in-stock/
It looks like this might be the best way to go. But I guess you will need to write your own hookup to Domoticz.
daandamhuis
Domoticz version: 2.4608
Post by daandamhuis »
I'm sorry to revive this thread, but did someone manage to get this working? I've bought the shield and added my lamps in the Arduino code and I can control the lights through a serial connection.
Does someone have a Python script that can talk to Arduino through USB Serial Connection of the Raspberry Pi?
RPi Model 2: Domoticz Server (Beta)
RPi Model B+: Smart Meter Slave (Stable)
Particle Photon (2x): Prototyping, Controlling LEDS and gathering Sensor data for Domoticz
Arduino Uno R3: with CC2500 Shield for Philips LivingColor Lights 1st Gen.
mentalTheo
Domoticz version: 3.8798
Post by mentalTheo »
Daan, did you figure out a way to get it working?
TokTias
Post by TokTias »
Hi !
I have posted my solution of controlling a gen 1 LivingColors lamp using MySensors and Domoticz here : https://forum.mysensors.org/topic/4638/ ... ensor-node
I then also found out that there's another solution here : https://forum.mysensors.org/topic/3080/ ... olors-lamp
Enjoy !
/T
____________________________________________
domoticz hooked up with :
Philips Hue (v2 Hub + 14 lamps)
MySensors (~15 nodes)
Roborock S5 Max
Broadlink RM2
Chromecast Audio & Video
Deboer132
Post by Deboer132 »
Myloweslife, lowes portal, and so on and also the https://my-loweslife.co Only when you click that; will certainly you be taken.
Allint367
Target OS: OS X
Post by Allint367 »
Any of the mass. It features a couple of ergonomic Know More The device's light weight aluminum motor housing.
Dorothy96
Post by Dorothy96 »
Simply flat-out failed to remember an account password could mymenards which is essential to staff members overall as well as.
