domoticz in synology as package! Available now.
Boots33
I have a MySensors serial gateway working on my Synology.
tobiasvdl
jumbotroll wrote:Sorry I don't think so.tobiasvdl wrote:Hi Jumbotroll,jumbotroll wrote: No it's not supported in my build.
Do you have any plans to include support for the HGI80 in the synology package? Would be great to connect my evohome to domoticz (running on my synology).
Cheers,
Tobias
I have tried to implement this earlier , but Synology need drivers and do not download the firmware for HGI-80 automatically like Linux Ubuntu and Raspberry do. I do not have HGI-80 myself , so this makes it difficult to test.
Ok, np and thx for your reply! Then I'm afraid I have to switch to Raspberry to get this working. BTW, keep up the good work, so far really enjoy running Domoticz on Synology!
- jumbotroll
DSM 6.0 Beta.
I have compiled some few test version with DSM 6.0-7274 Beta toolchain.
This is not tested!!
domoticz_x86-6.0_2.0.4372-7.spk
domoticz_avoton-6.0_2.0.4372-7.spk
domoticz_armadaxp-6.0_2.0.4372-7.spk
domoticz_armada38x-6.0_2.0.4384-7.spk
domoticz_bromolow-6.0_2.0.4386-7.spk
http://www.jadahl.com
http://www.jadahl.com/domoticz_beta_6/i ... llist=true
https://paypal.me/Jumbotroll
Jumbotroll
Jumbotroll
tobiasvdl
Hi, just responding to your PM via this way since I'm not (yet) able to send you a PM back...jumbotroll wrote:Sorry I don't think so.tobiasvdl wrote:Hi Jumbotroll,jumbotroll wrote: No it's not supported in my build.
Cheers,
Tobias
I'm more than happy to run any tests to get my HGI80 working! I'm running domoticz on a ds214play (DSM 5.2-5644 Update 3).
Just let me know if you need any more info!
- jumbotroll
It's confirmed working with another users also, but you must update to Domoticz V2.4409.tobiasvdl wrote:Hi, just responding to your PM via this way since I'm not (yet) able to send you a PM back...jumbotroll wrote:Sorry I don't think so.tobiasvdl wrote:
Hi Jumbotroll,
Cheers,
Tobias
The drivers and firmware is automatic installed.
Jumbotroll
Jumbotroll
tobiasvdl
Just updated my NAS to the most recent version, but that's V2.4408... are the drivers included in this version as well?jumbotroll wrote:It's confirmed working with another users also, but you must update to Domoticz V2.4409.tobiasvdl wrote:Hi, just responding to your PM via this way since I'm not (yet) able to send you a PM back...jumbotroll wrote: Sorry I don't think so.
- jumbotroll
It's a bugfix in v2.4409 so I think you should update.tobiasvdl wrote: Just updated my NAS to the most recent version, but that's V2.4408... are the drivers included in this version as well?
I have uploaded v2.4409 for evansport.
Jumbotroll
Jumbotroll
tobiasvdl
Thx, I'll give it a try and et you know!jumbotroll wrote:It's a bugfix in v2.4409 so I think you should update.tobiasvdl wrote: Just updated my NAS to the most recent version, but that's V2.4408... are the drivers included in this version as well?
tobiasvdl
Brilliant! It works and is fully functional! Thanks for your support!!tobiasvdl wrote:Thx, I'll give it a try and et you know!jumbotroll wrote:It's a bugfix in v2.4409 so I think you should update.tobiasvdl wrote: Just updated my NAS to the most recent version, but that's V2.4408... are the drivers included in this version as well?
- jumbotroll
Great!tobiasvdl wrote: Brilliant! It works and is fully functional! Thanks for your support!!
Thank's for testing!
Jumbotroll
Jumbotroll
RolandP
I've been trying for two days to get my Aeotech Z-stick recognized on my Synology DS213+ running DSM 5.2-5644 Update 3 and Domoticz v2.4409, but it's not working.
I have a RFXCom connected on ttyUSB0 that's able to communicate with some basic KAKU switches. When I connect the Z-stick to the other free usb port on the Synology I go to Hardware and select OpenZwave USB from the 'type' dropdown. The only option I get in the 'Serial port' dropdown is /dev/ttyUSB0 which is used by my RFXCom.
What am I doing wrong? What am I missing? Hope anyone here can help me
- jumbotroll
Try to remove the Z-stick and reboot your NAS.RolandP wrote:I've been trying for two days to get my Aeotech Z-stick recognized on my Synology DS213+ running DSM 5.2-5644 Update 3 and Domoticz v2.4409, but it's not working.
Then connect your Z-stick and see if that work, if not, I have no clue what the problem is.
Jumbotroll
Jumbotroll
rgouyet
I installed the updated 2.0.4409-7 this morning and since Domoticz freeze and I need to restart it.
I rebooted my DS1515+ and it's the same ...
I use MQTT a lot and I discover that when I want to update the hardware (desactivate or check a box) , Domoticz freeze and i need to restart it...
Any idea ?
How to download the previous version to check if it was better with the previous version ?
Romain
DS1515+ (avoton)
Any idea ?
Romain
DS1515+ (avoton)
djksage
Hello, i received today my arduino nano and NRF and i build a serial gateway, and domoticz recognise mysensors gateway connected by usbjumbotroll wrote: I don't know if mysensor work. Not tested!
Maybe you need some drivers?
10 MySensors Oui MySensors Gateway USB Version: 1.5.3 /dev/ttyUSB1 Désactiver
AxelvanH
- Domoticz version: 2020.01
- Installed this version, but no solution for the libstdc error.jumbotroll wrote:DSM 6.0 Beta.
Domoticz still doesn't want to start
- jumbotroll
Can you telnet into the NAS and check in folder /usr/lib/ if you have libstdc++.so.6AxelvanH wrote:- Installed this version, but no solution for the libstdc error.jumbotroll wrote:DSM 6.0 Beta.
Jumbotroll
Jumbotroll
RolandP
For anyone who might have the same question. I've solved my issue with the following steps:RolandP wrote:I've been trying for two days to get my Aeotech Z-stick recognized on my Synology DS213+ running DSM 5.2-5644 Update 3 and Domoticz v2.4409, but it's not working.
- take out zwave stick from the NAS;
- reboot the NAS;
- open Domoticz in a fresh, unused browser;
- turn on the zwave stick by clicking the button;
- insert into NAS and it showed up as /dev/ttyACM0;
It seemed as if it was a very persistent browser caching issue, although i'm not 100% sure
AxelvanH
Yes, the file is present:jumbotroll wrote:Can you telnet into the NAS and check in folder /usr/lib/ if you have libstdc++.so.6AxelvanH wrote:- Installed this version, but no solution for the libstdc error.jumbotroll wrote:DSM 6.0 Beta.
admin@Diskstation:/usr/lib$ ls libstdc*.* -l
-r-xr-xr-x 1 root root 866848 Jan 17 20:00 libstdc++.so.6
- jumbotroll
Why not try to copy this file to /domoticz/lib folder and chmod 755AxelvanH wrote:
Jumbotroll
Jumbotroll
AxelvanH
Did it! no change on behaviour.jumbotroll wrote:Why not try to copy this file to /domoticz/lib folder and chmod 755AxelvanH wrote:
