Blockly examples
mKotek
Re: Blockly examples
Post by mKotek »
Martijn85 wrote:Hello everybody,
Maybe someone can help me out with this small issue. These are my blocks:
This works but when one phone is off and one phone is on the switch Iemand Thuis (Someone Home) is switching every second from on to off. When the second phone is coming online the switch keeps on like ik should. Why, when one phone is off, the switch is switching from on to off?
As far as I can see, in the second part, you should have AND instead of OR between the phones. As it is now, just one phone fulfils the condition and swithc is set to OFF. Next, it detects one phone and sets it to ON again.
Michal 'Kotek', greetings from Poland. Zapraszam na mój blog o automatyce domowej po polsku: http://www.ukotka.com.
Martijn85
Domoticz version: Stable
Post by Martijn85 »
Thanks for the fast reply mKotek, it seems that did the trick! Thank you :)
Evelen
Domoticz version: 2.4538
Re: SCRIPS - EVENT MANAGEMENT SAMPLE
Post by Evelen »
Jochen wrote:Turn on a Light when open a door
This example will turn on a light when
1. A door is opening
2. It is between 22:00 and 07:00
A notification will be send everytime the is opening (00:00 - 24:00)
PS: The device Garagentor is the door (Garagentor = Garagedoor), the light is light is Licht Garage (Light Garage)
how to set a if-do inside a if-do?
Yoshiii
Post by Yoshiii »
rtulp wrote:
elmortero wrote:I don't know about curtains but with blinds you use Off for open and On for closed
Thanks! That makes sense!
Does the script work now? I cannot get my blinds to work... :(
brianprak
Post by brianprak »
Whats wrong with the following blockly i get an error 'then' expected near 'comparevariable'
StanHD
Post by StanHD »
Hi, I think the problem is in the Else if section where the "On & "Or" are incorrectly arranged. Try right clicking all of the "And" "Or" blocks and setting them as "External Inputs" It might be easier to see the logic then.
Python:- Broadlink RM2, Sonos
djgodlike
Re: RE: Re: Blockly examples
Post by djgodlike »
brianprak wrote:Whats wrong with the following blockly i get an error 'then' expected near 'comparevariable'
Compare with this picture very precisely!
Aeon Labs Gen5 USB
Greenwave Powernode 6 NS310
2x Greenwave Powernode 1 NS310
Philips Hue
Logitech media Server
Plugwise Smile P1
marktn
Post by marktn »
I have made my first blocky event.
Is it possible to test this, without waiting till the sunn is under? (simultion of a day)
The script is sending nog from 23:00 till 00:00 email, a lot of emails!! I just want one email that i am not at home. How to do this?
Thanks for reading,
Mark
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
sweup
Post by sweup »
I have build a Blockly with a manual switch to toggle alarm on/off.
Unfortunately my alarm not working, when I set my alarm "on", the alarm goes off - I want to set blockly to "when alarm is on and sensor 1 register motion, I will be notified and siren should beep". What I have done wrong?
Im using Aeon labs sensor+Razberry
JayKudo
Post by JayKudo »
So I am trying to create a group dimmer and want to use blocky for it.
How can I detect a change in a (virtual) dimmer switch. So if the virtual switch changes value, than I want to set two real dimmers to that value.
Do I need to create a user var and save the current value and than compare the value with the virtual dimmer, or is there an easier method (or should I use blocky at all for this)?
assenzuid
Post by assenzuid »
I have created below blockly, but unfortunately it's not working.
assenzuid
Post by assenzuid »
assenzuid wrote:I have created below blockly, but unfortunately it's not working.
Solved by using.
micbou
Post by micbou »
so what am I doing wrong here? this feels so straight forward but it doesn't work
hjvingen
Post by hjvingen »
micbou wrote:so what am I doing wrong here? this feels so straight forward but it doesn't work
Please try again with setting the group to "on" instead of "active",
this works for me.
Schermafbeelding 2016-06-05 om 20.51.35.png (13.36 KiB) Viewed 5405 times
micbou
Post by micbou »
Unfortunatly not working neither. Time doesn't seem to work in any scenario and Domoticz does show the correct time.
hjvingen
Post by hjvingen »
micbou wrote:Unfortunatly not working neither. Time doesn't seem to work in any scenario and Domoticz does show the correct time.
Do you get something in the log, like this?
Schermafbeelding 2016-06-05 om 21.04.28.png (12.12 KiB) Viewed 5402 times
Do other events (not time related) work?
micbou
Post by micbou »
No, the log shows no activity from the event.
Only events that seem to work are those activating a device after a device has been activated (for example 'turn on left light when the right light is on)
hjvingen
Post by hjvingen »
That's strange, because the event system is working but somehow the time related triggers don't work.
in the editor there is also a selector which can be set to time or device, did you already try these?
Schermafbeelding 2016-06-05 om 21.35.29.png (34.73 KiB) Viewed 5376 times
micbou
Post by micbou »
Yup, tried that too...
Schermafbeelding 2016-06-05 om 21.48.43.png (56.45 KiB) Viewed 5374 times
micbou
Post by micbou »
and its weird because below does work
Schermafbeelding 2016-06-05 om 22.03.06.png (28.71 KiB) Viewed 5371 times
