domoticz in synology as package! Available now.
Hello
Is DSM 6 beta supported / can the package run on DSM 6 beta?
I have a rs815+
Nicky
I have a rs815+
Nicky
- jumbotroll
I don't think so, I have not updated to 6.0 beta yet.npinguin wrote:Hello
I have a rs815+
Nicky
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
mschut
- Domoticz version: V3.5613
I am running the dsm 6 beta (beta 2 now). The synology package is jnstalled and working for me. Not using it however, due to something else.npinguin wrote:Hello
I have a rs815+
Nicky
Verstuurd vanaf mijn SM-G920F met Tapatalk
AxelvanH
- Domoticz version: 2020.01
Unfortunately it's not working on DSM 6 beta.
You can install it, but it won't run.
Logbook mentions:
/usr/local/domoticz/bin/domoticz: /lib/libstdc++.so.6: no version information available (required by /usr/local/domoticz/lib/libboost_system.so.1.59.0)
Logbook mentions:
Gravityz
- Domoticz version: 2025.1
i installed the latyest 4346 version
everything seems to work but i ssse this error in the error tab
2016-01-29 13:36:22.287 Error: SQL Query("ALTER TABLE MobileDevices ADD COLUMN [Name] VARCHAR(100) DEFAULT ''") : duplicate column name: Name
i stopped domoticz and restarted again. no errors sofar but it is up to you if this is something to look at.
M4nu
Hi everyone,
First thank you for your work !
I have added the repositories urls (http://packages.synocommunity.com/ and http://www.jadahl.com/domoticz_stable/), but even after refreshing my DS414J can't find any update. It sticks to the 2.2112 version (after updating from the Domoticz ui).
Any clue ?
Thank in advance !
Any clue ?
Thank in advance !
- jumbotroll
Add: http://www.jadahl.com/domoticz_beta/ in package center and allow any publisher, and you will have the latest build.M4nu wrote:Hi everyone,
Any clue ?
Thank in advance !
you can also manually download and install http://www.jadahl.com/domoticz_beta/?arch=comcerto2k
Jumbotroll
Jumbotroll
M4nu
Thank you it's working now !
There is a message which tell me that a version 3530 is available, I suppose I have to ignore it ?
- gizmocuz
You can ignore this error (will be fixed in next beta)Gravityz wrote:i installed the latyest 4346 version
M4nu
Ok ! Thank you !
Stevanovich
I try to install it, but i get this message :
Need DSM 5.0-448 or more
Can i get it another way ?
Thank
Thank
AxelvanH
Does anybody know how to solve this?AxelvanH wrote:Unfortunately it's not working on DSM 6 beta.
Logbook mentions:
djksage
i use now domoticz on my synology ( HP n54l with xpenology ) , working perfectly with aeon labs z-stick gen5, thanks jumbotroll for your work
i would like test mysensor but usb gateway is recognised by domoticz installed on syno?
thanks for your information
- jumbotroll
I don't know if mysensor work. Not tested!djksage wrote:Hello,
i use now domoticz on my synology ( HP n54l with xpenology ) , working perfectly with aeon labs z-stick gen5, thanks jumbotroll for your work![]()
Maybe you need some drivers?
Jumbotroll
Jumbotroll
djksage
Yes, i find this (in french)jumbotroll wrote: I don't know if mysensor work. Not tested!
Le module serialport n’a pas réussi à être installé sur Synology (npm exactement ne peut pas être installé)
the serialport can't be installed on synology (npm exactly can't installed)
i buy arduino for test
EDIT: the best way is buy a nodemcu for make a wifi gateway and this gateway is compatible with domoticz
tobiasvdl
Hi Jumbotroll,jumbotroll wrote:No it's not supported in my build.mschut wrote:Just checking. Is the Evohome HGI-80 module supported within the Synology package? I am not able to see the module on my Synology. It isnt getting a usb port.
Do you have any plans to include support for the HGI80 in the synology package? Would be great to connect my evohome to domoticz (running on my synology).
Cheers,
Tobias
- jumbotroll
Sorry I don't think so.tobiasvdl wrote:Hi Jumbotroll,jumbotroll wrote:No it's not supported in my build.mschut wrote:Just checking. Is the Evohome HGI-80 module supported within the Synology package? I am not able to see the module on my Synology. It isnt getting a usb port.
Cheers,
Tobias
I have tried to implement this earlier , but Synology need drivers and do not download the firmware for HGI-80 automatically like Linux Ubuntu and Raspberry do. I do not have HGI-80 myself , so this makes it difficult to test.
Jumbotroll
Jumbotroll
niki_lauda
When you have a an "older" DS like me a DS209, you can't upgrade to dsm 5.Egregius wrote:You're still on DSM 4?
Synology supports the dsm 5 year after release off the diskstation.
- jumbotroll
I have made a test build Domoticz stable v2.3530 for DS209+ DSM 4.3 (arch=ppc853x) and OpenZvave. (NOT TESTED!!)
Should also work on DSM 4.2.
http://www.jadahl.com/domoticz_stable/?arch=ppc853x
http://www.jadahl.com/domoticz_stable/p ... 3530-7.spk
Jumbotroll
Jumbotroll
