domoticz in synology as package! Available now.
npinguin
Post by npinguin »
Hello
Is DSM 6 beta supported / can the package run on DSM 6 beta?
I have a rs815+
Nicky
jumbotroll
Post by jumbotroll »
npinguin wrote:Hello
I have a rs815+
Nicky
I don't think so, I have not updated to 6.0 beta yet.
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
mschut
Domoticz version: V3.5613
Post by mschut »
I have a rs815+
Nicky
I am running the dsm 6 beta (beta 2 now). The synology package is jnstalled and working for me. Not using it however, due to something else.
Verstuurd vanaf mijn SM-G920F met Tapatalk
AxelvanH
Domoticz version: 2020.01
Post by AxelvanH »
Unfortunately it's not working on DSM 6 beta.
You can install it, but it won't run.
Logbook mentions:
/usr/local/domoticz/bin/domoticz: /lib/libstdc++.so.6: no version information available (required by /usr/local/domoticz/lib/libboost_system.so.1.59.0)
Gravityz
Domoticz version: 2022.2
Post by Gravityz »
i installed the latyest 4346 version
everything seems to work but i ssse this error in the error tab
2016-01-29 13:36:22.287 Error: SQL Query("ALTER TABLE MobileDevices ADD COLUMN [Name] VARCHAR(100) DEFAULT ''") : duplicate column name: Name
i stopped domoticz and restarted again. no errors sofar but it is up to you if this is something to look at.
M4nu
Post by M4nu »
Hi everyone,
First thank you for your work !
I have added the repositories urls (http://packages.synocommunity.com/ and http://www.jadahl.com/domoticz_stable/), but even after refreshing my DS414J can't find any update. It sticks to the 2.2112 version (after updating from the Domoticz ui).
Any clue ?
Thank in advance !
jumbotroll
M4nu wrote:Hi everyone,
Any clue ?
Thank in advance !
Add: http://www.jadahl.com/domoticz_beta/ in package center and allow any publisher, and you will have the latest build.
you can also manually download and install http://www.jadahl.com/domoticz_beta/?arch=comcerto2k
Jumbotroll
M4nu
Post by M4nu »
Thank you it's working now !
There is a message which tell me that a version 3530 is available, I suppose I have to ignore it ?
gizmocuz
Post by gizmocuz »
Gravityz wrote:i installed the latyest 4346 version
You can ignore this error (will be fixed in next beta)
M4nu
Post by M4nu »
Ok ! Thank you !
Stevanovich
Post by Stevanovich »
I try to install it, but i get this message :
Need DSM 5.0-448 or more
Can i get it another way ?
Thank
Egregius
Domoticz version: v2024.7
Post by Egregius »
You're still on DSM 4? :o
AxelvanH
Post by AxelvanH »
AxelvanH wrote:Unfortunately it's not working on DSM 6 beta.
Logbook mentions:
Does anybody know how to solve this?
djksage
Post by djksage »
i use now domoticz on my synology ( HP n54l with xpenology ) , working perfectly with aeon labs z-stick gen5, thanks jumbotroll for your work ;)
i would like test mysensor but usb gateway is recognised by domoticz installed on syno?
thanks for your information ;)
jumbotroll
djksage wrote:Hello,
I don't know if mysensor work. Not tested!
Maybe you need some drivers?
Jumbotroll
djksage
Post by djksage »
jumbotroll wrote: I don't know if mysensor work. Not tested!
Yes, i find this (in french)
Le module serialport n’a pas réussi à être installé sur Synology (npm exactement ne peut pas être installé)
the serialport can't be installed on synology (npm exactly can't installed)
i buy arduino for test ;)
EDIT: the best way is buy a nodemcu for make a wifi gateway and this gateway is compatible with domoticz :D
tobiasvdl
Post by tobiasvdl »
jumbotroll wrote:
mschut wrote:Just checking. Is the Evohome HGI-80 module supported within the Synology package? I am not able to see the module on my Synology. It isnt getting a usb port.
No it's not supported in my build.
Hi Jumbotroll,
Do you have any plans to include support for the HGI80 in the synology package? Would be great to connect my evohome to domoticz (running on my synology).
Cheers,
Tobias
jumbotroll
Hi Jumbotroll,
Cheers,
Tobias
Sorry I don't think so.
I have tried to implement this earlier , but Synology need drivers and do not download the firmware for HGI-80 automatically like Linux Ubuntu and Raspberry do. I do not have HGI-80 myself , so this makes it difficult to test.
Jumbotroll
niki_lauda
Post by niki_lauda »
Egregius wrote:You're still on DSM 4? :o
When you have a an "older" DS like me a DS209, you can't upgrade to dsm 5.
Synology supports the dsm 5 year after release off the diskstation.
jumbotroll
I have made a test build Domoticz stable v2.3530 for DS209+ DSM 4.3 (arch=ppc853x) and OpenZvave. (NOT TESTED!!)
Should also work on DSM 4.2.
http://www.jadahl.com/domoticz_stable/?arch=ppc853x
http://www.jadahl.com/domoticz_stable/p ... 3530-7.spk
Jumbotroll
