Nodon Soft Remote crc 360x
misjel
Post by misjel »
I bought two Nodon Soft remotes but I can't get them to work..
When I include the remote i get an unknown device. It seems that this device isn't part of the open zwave config.
I modified the xml and used the octan remote config:
<Product type="0002" id="0002" name="SoftRemote" config="nodon/crc3100OctanRemote.xml"/>
I still can't use the remote.
Does somebody get this remotes to work an can explane how?
Best regards,
Michel
NodOn
Re: Nodon Soft Remote crc 360x
Post by NodOn »
You are right, Soft Remote is not supported by OpenZwave.
Some users have found a solution in here :
viewtopic.php?f=17&t=8043
gizmocuz
Post by gizmocuz »
I just got send a Soft Remote ! What a nice little device, and it has a magnet ! Thanks NodOn !!
Here is how i made it working (Open up the manual !):
1. First i reset the Soft Remote
2. Include (secure) the Software Remote in 'Gateway Mode'
3. Add your zwave Controller (Node 1) to Group 1 of the Soft Remote node (From the Node Management dropdown Groups/Network)
4. Select the Soft Remote node from the nodes table, and change parameter 3 (Scene Type) to 'Scene Activation'
Press the button labeled 'Apply Configuration' at the bottom of the settings
press a button on the remote to wake it up, and wait about 10 seconds.
Now.... it can be received by Domoticz (you can open up the domoticz web gui a second time, and open the log screen)
On the remote, you can press normal, long press, double press etc.. Quite a few combinations you can make !
I suggest to press a button, then switch to the devices view, and you will see the last received button on top (if you order by date/time), and label it correctly
So..... now we have the buttons in Domoticz... and now you can create Scenes/Groups, and learn these buttons as activation code
Richie1972
Post by Richie1972 »
Had nothing but trouble with this and finally saw your post above.
Tried it and managed to add the node, but step 3 can't be done, as the Group 1 section for that node is blank:
2016-04-13 15_53_22-Domoticz.png (176.19 KiB) Viewed 4890 times
Richie
Aeo S5 USB
3 FGSD002 Smoke
1 FGSM Motion
4 FGBS Binary
1 Horstmann ASR-ZW
2 Aeo Relay
1 FGS222 2xRelay
2 Aeo Multi Gen4
2 Everspring relay
1 Aeo Repeater
1 Popp Switch
1 TKB socket
4 Popp Dimmer
gizmocuz
Post by gizmocuz »
That does not look good. Good you exclude/include again ?
How does the node table look ? Does it recognize that it is from the Manufacturer NodeOn ?
Richie1972
Included and excluded numerous times.
It doesn't recognise it as anything, just Unknown.
Not sure if i need to follow someone else's instructions and use the config from another device, however i am very new to Domoticz and could do with a detailed step by step guide on what files to edit/create
Thanks,
Richie
Richie
Aeo S5 USB
3 FGSD002 Smoke
1 FGSM Motion
4 FGBS Binary
1 Horstmann ASR-ZW
2 Aeo Relay
1 FGS222 2xRelay
2 Aeo Multi Gen4
2 Everspring relay
1 Aeo Repeater
1 Popp Switch
1 TKB socket
4 Popp Dimmer
gizmocuz
Post by gizmocuz »
I made a small wiki, please feel free to edit
http://www.domoticz.com/wiki/NodOn_Soft_Remote
Richie1972
Thanks for that.
Did you have to do something prior to adding the node (some people have had to edit config files i believe)?
As you can see from my screenshot it is not recognising the device:
2016-04-13 16_27_11-Domoticz.png (60.35 KiB) Viewed 4881 times
Thanks,
Richie
Richie
Aeo S5 USB
3 FGSD002 Smoke
1 FGSM Motion
4 FGBS Binary
1 Horstmann ASR-ZW
2 Aeo Relay
1 FGS222 2xRelay
2 Aeo Multi Gen4
2 Everspring relay
1 Aeo Repeater
1 Popp Switch
1 TKB socket
4 Popp Dimmer
gizmocuz
Post by gizmocuz »
No, i updated domoticz to the latest version #5060+
gizmocuz
Post by gizmocuz »
Make sure you see node in the table like in the image under point #2
Richie1972
Mine shows:
Version: 3.4834
Build Hash: 8398125
Compile Date: 2016-03-02 07:43:51
But Check for Updates doesn't find a newer version
Richie
Aeo S5 USB
3 FGSD002 Smoke
1 FGSM Motion
4 FGBS Binary
1 Horstmann ASR-ZW
2 Aeo Relay
1 FGS222 2xRelay
2 Aeo Multi Gen4
2 Everspring relay
1 Aeo Repeater
1 Popp Switch
1 TKB socket
4 Popp Dimmer
gizmocuz
Post by gizmocuz »
In your Domoticz Settings, do you have selected the 'beta' release channel ? Else you can just download the latest installer from
www.domoticz.com
Richie1972
Updating now to beta version
Richie
Aeo S5 USB
3 FGSD002 Smoke
1 FGSM Motion
4 FGBS Binary
1 Horstmann ASR-ZW
2 Aeo Relay
1 FGS222 2xRelay
2 Aeo Multi Gen4
2 Everspring relay
1 Aeo Repeater
1 Popp Switch
1 TKB socket
4 Popp Dimmer
gizmocuz
Post by gizmocuz »
Ok, you will have to exclude/include again (did you do a reset as well ?), and include it in 'gateway mode', this is explained on the back of the manual
Richie1972
Thanks for your help that's fixed it :)
Richie
Aeo S5 USB
3 FGSD002 Smoke
1 FGSM Motion
4 FGBS Binary
1 Horstmann ASR-ZW
2 Aeo Relay
1 FGS222 2xRelay
2 Aeo Multi Gen4
2 Everspring relay
1 Aeo Repeater
1 Popp Switch
1 TKB socket
4 Popp Dimmer
gizmocuz
Post by gizmocuz »
Great to hear... What was the problem ? That you needed the latest version, or my expert tutorial :mrgreen:
Feel free to update the wiki if something could be described better
Richie1972
Both.
Richie
Aeo S5 USB
3 FGSD002 Smoke
1 FGSM Motion
4 FGBS Binary
1 Horstmann ASR-ZW
2 Aeo Relay
1 FGS222 2xRelay
2 Aeo Multi Gen4
2 Everspring relay
1 Aeo Repeater
1 Popp Switch
1 TKB socket
4 Popp Dimmer
laggmunk
Post by laggmunk »
Sorry to wake this thread to life, but I followed these instructions and they work...but I do't want to use scenes, I just want a click or doublecklick on a button to toggle a light, and I cannot figure out how to do that, I can not make domoticz react to any button set to "mono" mode.
I set button 1+3 to mono mode and included the controller and a switch in the z-wave group 2, but I can see no entry in the log when pushing a button.
what is the intended way for this to work?
gizmocuz
Post by gizmocuz »
What is wrong with using scenes ?
You can also directly configure the nodeon in the group of a lamp if that is what you want in the group editor or via the zwave control panel.
I do not have experience with this, i work with the scenes, and find that i have total control with all the buttons (including long pushes) when using scenes
laggmunk
Post by laggmunk »
well a scene cannot toggle a device, so I need two scenes per device I wish to control. that amounts to a lot. and with 3 functions per button, 4 buttons per remote, the amount of light switches in the gui has far exceeded the point where the domoticz gui can be used to turn lights on and off.
trying to figure out if I have to search for a scene or a switch in the gui to turn a light off makes it take even longer.
I bought physical remotes because the number of swithes in the switches tab was too large to make it practical, maybe I just just accept that using my iphone to control lights is not practical, just for upstairs I now have 51 switchtes to scroll through out of which 48 are scene controlling swithces that are always listed as being on
