Changing from RFXtrx433 to RFXtrx433e
markk
I'm running Domoticz on Windows with a rfxtrx433 and have just bought a rfxtrx433e to replace it. I've tried adding this the same way as I originally added the rfxtrx433 but, although it is receiving commands, it won't send any. It seems my existing switches are still linked to the rfxtrx433. Is there a process i need to follow to make the change over?
- mbliek
Re: Changing from RFXtrx433 to RFXtrx433e
Did you enable the right protocols on the new RFXCOM? The devices are not linked to the RFXCOM like zwave does.
You need to select the right protocols in order to switch them. Receiving is always enabled.
Op zoek naar een Domoticz Start Set?
markk
Thanks for your reply.Yes, all the same protocols are enabled but I get the message below. Also, looking at the log, although it receives chimes, harmony hub signals etc, the names are missing from all the "com" switches. It seems all the "com" switches are still lnked to the old RFXcom. I think I need to change something to let the new RFXcom know they exist but I can't figure out how
- IMG_1459.PNG (119.71 KiB) Viewed 3034 times
- mbliek
Did you try restarting your pc? Or at the hardware section, select the rfxcom and press update. Do not remove the device or every device will be removed that uses the rfxcom.
markk
That didn't work either
Enabled the new rfxcom, disabled the old one, restarted the PC, still nothing!
- bizziebis
- Domoticz version: 3.8805
Every switch is connected to a hardware ID in the database. Most easy would be to edit the database and change the ID of the old rfxtrx to the new one. So every switch will work like before.
So lets say your old rfxtrx has ID 3 and your new rfxtrx has ID 6. You edit the new rfxtrx to ID 3, and the old one to 6. Afterwards you can remove the old rfxtrx in domoticz
Edit: Wait, can't you just edit the old device at the hardware tab and change the comport/USB port? You don't need to add a new hardware device, at least not in Linux.
markk
Ha ha, brilliant. that did the trick. I didn't need to add the new hardware at allbizziebis wrote:Every switch is connected to a hardware ID in the database. Most easy would be to edit the database and change the ID of the old rfxtrx to the new one. So every switch will work like before.
