Somfy Telis Remotes
hnogueira
Somfy Telis Remotes
Hi:
I have several Somfy blind working OK from Domoticz, but I also control those blinds via the original Somfy Telis Remotes.
Is there a way to have a remotes added to Domoticz so that when a blind is closed or opened via Telis the state is updated on Domoticz?
regards,
Helde Nogueira
regards,
Helde Nogueira
- Stuntteam
Re: Somfy Telis Remotes
RFlink can receive and transmit RTS signals but you might need a 433.42 mhz receiver to get good results over longer distances.
hnogueira
How to I setup and configure the Telis Remotes?
deennoo
Just press small red button at back 10 sec this will set your blinds on "add new remote mode"
http://domo-attitude.fr
bibo456
Hello All,
Did you manage to pair your somfy blind with RFlink ?
I did not succeed.
I can see the remote. But cannot control the blinds.
Thank you for your feedback
I did not succeed.
mistysnip
- Domoticz version: 2024.7
Bumpbibo456 wrote:Hello All,
I did not succeed.
Oliv5
Same status than bibo456: I can receive the remote signal but trying to send some fails.
The association procedure didn't work with my setup, whose trouble is I cannot get the RF transmitter close to the blind RF receiver (too high).
gthenk
I’ve installed Domoticz (latest/stable)
Added my RF link and is working (tested with some KAKU)
Used :http://www.nemcon.nl/blog2/ with version 39 installed.
Now i’m trying to add my somfy telis 4 remotes to the system.
Added as
check screenshot
Then i’m switching my original remote in learning other remotes
Hit the “testen" button in domotizc
But after that the blinds did not receive the signal (so not able to learn the signal)
I’ve been searching the internet for some days now, but unable to find some information on how to proceed.
Should this work? or am I doing something wrong?
Or do I need to be as close as possible to learn the remote? (now 10 meters)
Hope you can help me a little bit.
Added as
check screenshot
- Screen Shot 2016-03-19 at 10.00.14.png (44.68 KiB) Viewed 12513 times
supermat
For Somfy transmition you must have a 433,42 (not 433.92) transmitter !!
deennoo
It works with a 433.92 mhz too.
Rflink didn't copy existing remote, it can listen to it that all.
You have to set a new remote using RFlink Loader First, when this done, then add it to domoticz using the same ID.
I tested the Telis 1 remote on the RFLink Gateway with R40 firmware and within one meter I get the debug output as expected:
-> Press Down
20;06;RTS;ID=e6a531;SWITCH=01;CMD=DOWN;
-> Press UP
20;08;RTS;ID=e6a531;SWITCH=01;CMD=UP;
In Domoticz when learning I also need to have the remote within 1 meter, otherwise it won't receive any signals. But after learning I cannot use the device in Domoticz because it's probably to far away (its 2 meters max with 1 wall in between).
Is there any way to improve the signal for this?
(I also tried to do the learn approach by pressing the red button on the back of the Somfy remote until the sunscreen reacts and then send a signal from Domoticz, but the sunscreen doesn't respond).
-> Press Down
-> Press UP
- Stuntteam
You need to pair the screen with rflink loader.. do not use domoticz for that..
waba
- Domoticz version: 3.4834
Can you also explain how to do this? I cannot find any entry in RFLink Loader to do that
djgodlike
I paired the somfy screens from the RFLink loader (did it by adding 1 to the original code: "10;RTS;2c2a40;1;PAIR;" when code was 1c2a40).
Did get feedback from the screens and "OK" in logging screen.
The logged code from the remote: "20;02;RTS;ID=1c2a40;SWITCH=01;CMD=UP;"
Now when i try to add a manual switch in Domoticz (Blinds, RFY and the same code with 1 added) but the switch won't work..
Can someone give me some advice?
Aeon Labs Gen5 USB
Greenwave Powernode 6 NS310
2x Greenwave Powernode 1 NS310
Philips Hue
Logitech media Server
Plugwise Smile P1
Philips Hue
Plugwise Smile P1
supermat
I made a tutorial (in french), I control many blind with this solution. I hope it can help you.
https://matdomotique.wordpress.com/2016 ... -et-somfy/
joshua
thank you for the great work and good tutorial.
Pixal
- Domoticz version: 4.10199
Thank you!! My Somfy RTS Telis 1 sunscreen started working after this tutorial. I had to translate it to Dutch and use some common sense but I was almost ready to give up until I saw this manual.supermat wrote:Hi,
SHadley1138
I had it working following this guide once, then moved the Rflink, and never managed to get it working again. I had to go down the dry contact route in the end
Kerneldomoticz
- Domoticz version: 3.5248
You also have this page that i will test soon to control my somfy sun screen. sorry it is also in french . but googletranslate should do a good job.
http://blog.domadoo.fr/2014/06/06/appai ... fxtrx433e/
piokuc
HI
I read this manual:
and start test on my somfy. But for me it not working.
Ok i connect my RFLink by USB to my PC. Run RFLink LOader and i have latest FW 42 and serial port logging ON.
When i do command
all my entry was blank
Then i start pair my remote rts SMOOVE ORIGIN from somfy
https://e-rolety.eu/userdata/gfx/30dbab ... ea634c.jpg
i send command
and then i press for about 3 secund button on remote to PROG.
On loader show example
then i again send command and now show me:
And RC is not 0412 as i send command but is 0413. I don again it with other address 2F2F2F and RC 0222 and after that in RFLink is save RC 0223. Always is RC one more than i send by command.
And my somfy didnt working when i send commacnd:
Also i try send
as i have save in RFLink on entry 3 but also not working.
Please help me. I am begginer.
What is command to erase all entry in RFlink ?
I read this manual:
When i do command
10;RTSSHOW;Code: Select all
RTS Record: 0 Address: FFFFFF RC: FFFF
RTS Record: 1 Address: FFFFFF RC: FFFF
RTS Record: 2 Address: FFFFFF RC: FFFF
RTS Record: 3 Address: FFFFFF RC: FFFF
RTS Record: 4 Address: FFFFFF RC: FFFF
RTS Record: 5 Address: FFFFFF RC: FFFF
RTS Record: 6 Address: FFFFFF RC: FFFF
RTS Record: 7 Address: FFFFFF RC: FFFF
RTS Record: 8 Address: FFFFFF RC: FFFF
RTS Record: 9 Address: FFFFFF RC: FFFF
RTS Record: 10 Address: FFFFFF RC: FFFF
RTS Record: 11 Address: FFFFFF RC: FFFF
RTS Record: 12 Address: FFFFFF RC: FFFF
RTS Record: 13 Address: FFFFFF RC: FFFF
RTS Record: 14 Address: FFFFFF RC: FFFF
RTS Record: 15 Address: FFFFFF RC: FFFFhttps://e-rolety.eu/userdata/gfx/30dbab ... ea634c.jpg
i send command
10;RTS;0F0F0F;0412;3;PAIR;On loader show example
20;07;OK;Code: Select all
RTS Record: 3 Address: 0F0F0F RC: 0413
RTS Record: 15 Address: FFFFFF RC: FFFFAnd my somfy didnt working when i send commacnd:
10;RTS;0F0F0F;0412;0;DOWN;
10;RTS;0F0F0F;0412;0;UP;
10;RTS;0F0F0F;0412;0;STOP;Code: Select all
10;RTS;0F0F0F;0412;3;DOWN;
10;RTS;0F0F0F;0412;3;UP;
10;RTS;0F0F0F;0412;3;STOP;Please help me. I am begginer.
