Somfy Telis Remotes
433Mhz opensource Receiver & Transmitter.
hnogueira
Somfy Telis Remotes
Post by hnogueira »
Hi:
I have several Somfy blind working OK from Domoticz, but I also control those blinds via the original Somfy Telis Remotes.
Is there a way to have a remotes added to Domoticz so that when a blind is closed or opened via Telis the state is updated on Domoticz?
regards,
Helde Nogueira
Stuntteam
Re: Somfy Telis Remotes
Post by Stuntteam »
RFlink can receive and transmit RTS signals but you might need a 433.42 mhz receiver to get good results over longer distances.
hnogueira
Post by hnogueira »
How to I setup and configure the Telis Remotes?
deennoo
Post by deennoo »
Just press small red button at back 10 sec this will set your blinds on "add new remote mode"
http://domo-attitude.fr
bibo456
Post by bibo456 »
Hello All,
Did you manage to pair your somfy blind with RFlink ?
I did not succeed.
I can see the remote. But cannot control the blinds.
Thank you for your feedback
mistysnip
Domoticz version: 2024.7
Post by mistysnip »
bibo456 wrote:Hello All,
I did not succeed.
Bump
Oliv5
Post by Oliv5 »
Same status than bibo456: I can receive the remote signal but trying to send some fails.
The association procedure didn't work with my setup, whose trouble is I cannot get the RF transmitter close to the blind RF receiver (too high).
gthenk
Post by gthenk »
I’ve installed Domoticz (latest/stable)
Added my RF link and is working (tested with some KAKU)
Used :http://www.nemcon.nl/blog2/ with version 39 installed.
Now i’m trying to add my somfy telis 4 remotes to the system.
Added as
check screenshot
Then i’m switching my original remote in learning other remotes
Hit the “testen" button in domotizc
But after that the blinds did not receive the signal (so not able to learn the signal)
I’ve been searching the internet for some days now, but unable to find some information on how to proceed.
Should this work? or am I doing something wrong?
Or do I need to be as close as possible to learn the remote? (now 10 meters)
Hope you can help me a little bit.
Screen Shot 2016-03-19 at 10.00.14.png (44.68 KiB) Viewed 12818 times
supermat
Post by supermat »
For Somfy transmition you must have a 433,42 (not 433.92) transmitter !!
deennoo
Post by deennoo »
It works with a 433.92 mhz too.
Rflink didn't copy existing remote, it can listen to it that all.
You have to set a new remote using RFlink Loader First, when this done, then add it to domoticz using the same ID.
onwieze
Post by onwieze »
I tested the Telis 1 remote on the RFLink Gateway with R40 firmware and within one meter I get the debug output as expected:
-> Press Down
20;06;RTS;ID=e6a531;SWITCH=01;CMD=DOWN;
-> Press UP
20;08;RTS;ID=e6a531;SWITCH=01;CMD=UP;
In Domoticz when learning I also need to have the remote within 1 meter, otherwise it won't receive any signals. But after learning I cannot use the device in Domoticz because it's probably to far away (its 2 meters max with 1 wall in between).
Is there any way to improve the signal for this?
(I also tried to do the learn approach by pressing the red button on the back of the Somfy remote until the sunscreen reacts and then send a signal from Domoticz, but the sunscreen doesn't respond).
Stuntteam
Post by Stuntteam »
You need to pair the screen with rflink loader.. do not use domoticz for that..
waba
Domoticz version: 3.4834
Post by waba »
Can you also explain how to do this? I cannot find any entry in RFLink Loader to do that
djgodlike
Post by djgodlike »
I paired the somfy screens from the RFLink loader (did it by adding 1 to the original code: "10;RTS;2c2a40;1;PAIR;" when code was 1c2a40).
Did get feedback from the screens and "OK" in logging screen.
The logged code from the remote: "20;02;RTS;ID=1c2a40;SWITCH=01;CMD=UP;"
Now when i try to add a manual switch in Domoticz (Blinds, RFY and the same code with 1 added) but the switch won't work..
Can someone give me some advice?
Aeon Labs Gen5 USB
Greenwave Powernode 6 NS310
2x Greenwave Powernode 1 NS310
Philips Hue
Logitech media Server
Plugwise Smile P1
supermat
Post by supermat »
I made a tutorial (in french), I control many blind with this solution. I hope it can help you.
https://matdomotique.wordpress.com/2016 ... -et-somfy/
joshua
Post by joshua »
thank you for the great work and good tutorial.
Pixal
Domoticz version: 4.10199
Post by Pixal »
supermat wrote:Hi,
Thank you!! My Somfy RTS Telis 1 sunscreen started working after this tutorial. I had to translate it to Dutch and use some common sense but I was almost ready to give up until I saw this manual.
SHadley1138
Post by SHadley1138 »
I had it working following this guide once, then moved the Rflink, and never managed to get it working again. I had to go down the dry contact route in the end
Kerneldomoticz
Domoticz version: 3.5248
Post by Kerneldomoticz »
You also have this page that i will test soon to control my somfy sun screen. sorry it is also in french . but googletranslate should do a good job.
http://blog.domadoo.fr/2014/06/06/appai ... fxtrx433e/
piokuc
Post by piokuc »
HI
I read this manual:
and start test on my somfy. But for me it not working.
Ok i connect my RFLink by USB to my PC. Run RFLink LOader and i have latest FW 42 and serial port logging ON.
When i do command
10;RTSSHOW;
all my entry was blank
RTS Record: 0 Address: FFFFFF RC: FFFF
RTS Record: 1 Address: FFFFFF RC: FFFF
RTS Record: 2 Address: FFFFFF RC: FFFF
RTS Record: 3 Address: FFFFFF RC: FFFF
RTS Record: 4 Address: FFFFFF RC: FFFF
RTS Record: 5 Address: FFFFFF RC: FFFF
RTS Record: 6 Address: FFFFFF RC: FFFF
RTS Record: 7 Address: FFFFFF RC: FFFF
RTS Record: 8 Address: FFFFFF RC: FFFF
RTS Record: 9 Address: FFFFFF RC: FFFF
RTS Record: 10 Address: FFFFFF RC: FFFF
RTS Record: 11 Address: FFFFFF RC: FFFF
RTS Record: 12 Address: FFFFFF RC: FFFF
RTS Record: 13 Address: FFFFFF RC: FFFF
RTS Record: 14 Address: FFFFFF RC: FFFF
RTS Record: 15 Address: FFFFFF RC: FFFF
Then i start pair my remote rts SMOOVE ORIGIN from somfy
https://e-rolety.eu/userdata/gfx/30dbab ... ea634c.jpg
i send command
10;RTS;0F0F0F;0412;3;PAIR;
and then i press for about 3 secund button on remote to PROG.
On loader show example
20;07;OK;
then i again send command
10;RTSSHOW;
and now show me:
RTS Record: 3 Address: 0F0F0F RC: 0413
And RC is not 0412 as i send command but is 0413. I don again it with other address 2F2F2F and RC 0222 and after that in RFLink is save RC 0223. Always is RC one more than i send by command.
And my somfy didnt working when i send commacnd:
10;RTS;0F0F0F;0412;0;DOWN;
10;RTS;0F0F0F;0412;0;UP;
10;RTS;0F0F0F;0412;0;STOP;
Also i try send
10;RTS;0F0F0F;0412;3;DOWN;
10;RTS;0F0F0F;0412;3;UP;
10;RTS;0F0F0F;0412;3;STOP;
as i have save in RFLink on entry 3 but also not working.
Please help me. I am begginer.
What is command to erase all entry in RFlink ?
