domoticz in synology as package! Available now.
jumbotroll
Post by jumbotroll »
Here you can manually download stable releases V2.3530
http://www.jadahl.com
http://jadahl.dscloud.me/sspks_stable/i ... llist=true
Jumbotroll
https://paypal.me/Jumbotroll
Jumbotroll
Eternity
Post by Eternity »
After allowing BETA updates, and an update and a reboot... the PIR is working!
Thanks !!!
Synology DS218+
Homey controller
Z-Wave stuff (Fibaro / Aeotec / NEO Coolcam)
Zigbee stuff (Aqara)
HUE lights
Logitech Harmony Ultimate + Hub
IP camera's
mcmikev
Post by mcmikev »
I have a very weird issue with the domoticz package for the Syno.
I have a syno DS411+II and can install the package without issues. Package starts and you can select hardware and change settings etc.
BUT........ When i restore a database using the settings page then I cannot use the package anymore.
All the hardware options are gone, only blanc empty line, the settings are messed up , language Arabic etc instead of english.
When the database is restored the first time it all looks fine the sensors and switches are visible and hardware is visible.
But the minute you click on something to change it all is gone and messed up.
Any ideas how this can be? The backup of the database comes from a RPI2 with domoticz version V2.3799 Build Hash: 70987e6
So restoring a working DB messes everything up :-(
Here are some screen to make things more clear and hopefully a solution is out there :D
hardware screen just after restoring the database
settingsscreen just after installation of the package. All looks fine
Just installed the package and hardware is visible and selectable
mcmikev
Post by mcmikev »
could not add more pictures so part II :D
just clicking on apply in the settings changes everything. Settings are messed up and all the hardware is gone.
settings screen just after restore database. All looks fine
dsahboard just after restore database
mcmikev
Post by mcmikev »
Sorry the last part is this III
Last picture..
Sorry for the huge post but I wanted to make myself as clear as possible :D
However I see the order of the pictures is not how I added them, so it is not in that specific order, but the text under the pictures explains the screens and the moment of time.
hardware just after the restore and clicking apply in the settings without changing ANYTHING
Eternity
Post by Eternity »
I don't have a solution, but can add to this issue that I too have a strange restore problem; I tried to import a backup from my Windows test DOmoticz enviroment to my Synology setup... and discovered that the backup from the Windows system was 0 bytes.
Synology DS218+
Homey controller
HUE lights
IP camera's
pepeEL
Post by pepeEL »
Hello Jumbotroll
If you build spk Domoticz maybe you also try build OWFS as SPK for Synology to run working 1wire by USB on Domoticz by Synology ? 1wire need OWFS to read data.
jumbotroll
pepeEL wrote:Hello Jumbotroll
I've taken a look at this and it is not an easy job to implement this for all the different architectures for the moment and I do not have much free time to work with this atm.
We'll see later if I get the opportunity to work with it .
Jumbotroll
Jumbotroll
pepeEL
Post by pepeEL »
Ok thanks
Wysłane z mojego SM-G920F przy użyciu Tapatalka
Gravityz
Domoticz version: 2025.1
Post by Gravityz »
Hi Jumbotroll
i love your packages, real easy and works instantly(also after rebooting)
one question however: im am thinking about buying a 716+
can you tell me if you have packages available for this nas also, if not which of the current ones will work since it has a different intel cPU
thanks again
jumbotroll wrote:Here you can manually download stable releases V2.3530
Jumbotroll
jumbotroll
Gravityz wrote:Hi Jumbotroll
thanks again
Jumbotroll
I have compiled domoticz_braswell-5.2_2.0.3827-7.spk for DS216+ and DS716+
DS216+ and DS716+ is now added to my sspks server.
This is not tested, but you can be the first :)
http://jadahl.dscloud.me/sspks/?arch=braswell
Jumbotroll
Jumbotroll
Gravityz
Post by Gravityz »
Thanks Jumbotroll.
i do not have the 716+ yet but when i do this is the first thing to test.
CoolRaoul
Post by CoolRaoul »
That's the first time I install Domoticz on my NAS
I've found an issue in the package "start-stop-status" script.
the "su -" at line 44 should be changed to a simple "su".
Forcing a login shell may have bad side effects on users (that was my case) who have customized "/root/profile" and/or "/etc/profile".
With this simple edit, the package now starts normally on my configuration.
jumbotroll
CoolRaoul wrote: Hello,
Ok, Thanks I will fix this in next build.
Jumbotroll
Jumbotroll
jumbotroll
Update
Added arch-armada38x for DS216 and DS416j
http://jadahl.dscloud.me/sspks/?arch=armada38x
Jumbotroll
Jumbotroll
boxstart
Post by boxstart »
I tried to install Domoticz on my DS414, but without success.
I am running the DSM 6 beta OS, so that might be the cause of my problems. I have two issues:
1. I am not able to use the http://jadahl.dscloud.me/sspks/ package source. When I add it to the settings and try to update the available packages, my NAS pops up with the error that there was a network problem and that I must check my network settings. The network connection however is OK;
2. When I download the package for the DS414 manually and do a manual installation, the installation goes fine, but I am not able to start Domoticz after the installation. There is no error message at all.
Does anybody have experience with this package in combination with DSM 6 beta?
Thanks in advance!
hal9001
Post by hal9001 »
I finally solved my EnOcean problem with Domoticz (which was linked to a USB device conflict with an old install of PulseStation).
Everything is now working fine (RFXCom, EnOcean, Zwave) but I still have a remaining problem: when I try to reboot or shutdown my Synology (DS214), it stays stucked forever with the blue led blinking. Nothing happens if I push the power button a few seconds to force the shutdown. The only way to stop it is to unplug the power cable (not nice). After replugging the power cable and power it on again, it starts up with no problem...
I face this issue since I started using the Domoticz package.
Does anyone also face this issue and found a workaround to it?
jumbotroll
hal9001 wrote:I finally solved my EnOcean problem with Domoticz (which was linked to a USB device conflict with an old install of PulseStation).
I've never heard others have this problem , but have you tried to stop domoticz in package manager before a restart ?
Jumbotroll
Jumbotroll
hal9001
Post by hal9001 »
Jumbotroll
I will give it a try, thanks.
G3rard
Domoticz version: No
Post by G3rard »
@jumbotroll, thanks for the updates that keep on coming for Synology :D
One question, since a recent version there is a LUA editor in Domoticz available. This editor has some example scripts available when you select LUA and press new.
These examples are stored in scripts/templates (https://github.com/domoticz/domoticz/tr ... /templates).
Can you add these files to the package? Thanks.
Not using Domoticz anymore
