I never entered any password, but it seems one came with last update... I hope we will not have to re-initiate it after each update.
I think XPenology using arch-bromolow.rednas wrote:I only know it is version 2.0.3724-7 (which I can see in DSM). Is it possible to see in DSM which arch this is?
Arch-bromolow is updated to v2.0.3771-7rednas wrote:Thanks! I will let you know
I 'm not familiar with EnOcean, but have you read:hal9001 wrote:Hi,
I just installed the latest Domoticz package on my DS214 with no problem.
I plugged an Enocean USB Key in the front USB plug, checked that it is recognized by the NAS with the "dmesg | grep tty" command which sees it under /dev/ttyUSB0
I added it in the hardware panel as EnOcean USB (ESP3) with Serial Port = /dev/ttyUSB0 (already filled in correctly by Domoticz)
I then pressed the learn button of my Nodor Door Sensor, I see the receiver led flash on the USB Key but no device is created in the Device panel and nothing shows in Domoticz log file... I also tried to activate the door switch after pressing the "Learn light/switch" in the Switches panel, I see the USB key led flash but still nothing in Domoticz.
Any idea ?
Thanks !
Karl
This may be relatively much work. I must then cross compile Homekit for all the different Synology NAS (archs) and implement it when I compile domoticz , but I will see how much work it is , before I dismiss itcwvs wrote:Hey Jumbotroll, first of all great work!
I have been using it for quite some time now and it works great!
One thing i am realy eager to experiment with is the possibility for Homekit integration. It is already done with Domoticz (https://www.domoticz.com/wiki/Homekit_Siri) is this something that can be incorporated to the package or is there an other solution for this?
Thanks in advance!
Great! Thanks for looking into it!jumbotroll wrote:This may be relatively much work. I must then cross compile Homekit for all the different Synology NAS (archs) and implement it when I compile domoticz , but I will see how much work it is , before I dismiss itcwvs wrote:Hey Jumbotroll, first of all great work!
Thanks in advance!![]()
Jumbotroll
