RGBW Bulb in Domoticz?
Evelen
Domoticz version: 2.4538
Post by Evelen »
Hi.
I want to buy some RGBW lights to use in domoticz, like this:
https://www.tronika.no/no/lysstyring/83 ... zw098.html
And I have some question:
1. do I need some additional hardware-equipment to use this? (I have a UZB1 Z-Wave interface)
2. Is it posible to use this and change colors and stuff in Domoticz? And how easy is it relative to normal on/off switshes?
I'm not a very advanced user, so I want to avoid scripting
Last edited by ThinkPad on Wednesday 02 December 2015 11:23, edited 1 time in total.
Reason: Titlefix: Bulp --> Bulb
Evelen
Re: RGBW Bulp in Domoticz?
Post by Evelen »
bump
locogek
Post by locogek »
Please look at milight or Philips hue these work out of the box with domoticz
Verstuurd vanaf mijn ONE A2003 met Tapatalk
Evelen
Post by Evelen »
locogek wrote:Please look at milight or Philips hue these work out of the box with domoticz
are these Wifi or Z-Wave?
link plz :)
locogek
Post by locogek »
WiFi with bridge
Evelen
Post by Evelen »
just some cheape stuff from ebay?
http://www.ebay.com/sch/i.html?_from=R4 ... t&_sacat=0
what do you meen by bridge?
locogek
Post by locogek »
Yes it's really cheap. On aliexpress you can get a gu10 rgbww for just 10 euros. A bridge is a device that you connect to your router with WiFi or cable and allows you to control the light. They do that because the light can be cheaper and less energy consumption. Philips is the better and more expensive way then milight
Evelen
Post by Evelen »
Ok, so if I understand you correct.
I Can buy one of these: http://www.milight.com/milight-wifi-rec ... oller-box/ (that is compatible with Domoticz?)
And than buy MILIGHT RGBW bulps and than controll them via domoticz? (also, if i have more then one bulp, can i controll them individually?
locogek
Post by locogek »
Yes you can add the milight bridge in domoticz. Be aware that a milight bridge only can Control 4 different groups. Each group can contain more lights but they will switch at the same time then.
Evelen
Post by Evelen »
Aha so for example i can have:
- 4 separate bulps and controll them individual
or:
- 3 bulp to control individual and a group whit 2 (to controll at the same time)
I guess I just need to buy more controllers if i need more.
Anyway, can i se a screenshot og video from the Domoticz GUI whit Milight?
locogek
Post by locogek »
4 seperate groups on 1 bridge. example for one bridge:
group1: bulb RGBW
group2: Spot1 RGBW, Spot2 RGBW, Spot3 RGBW, etc. (control them together)
group3: LED strip RGBW
group4: Bulb RGBW
For now there are a view drawbacks on controlling them with domoticz. you can have only a few hondred different colors.
You can't use the white and colors together. Only one white color possible.
This is how it looks like in domoticz it's the same as for the hue:
https://www.google.nl/url?sa=i&rct=j&q= ... 5094750174
Evelen
Re: RGBW Bulb in Domoticz?
Post by Evelen »
Hi again :)
Do i Need any scriping to get this to work or will it work right in the GUI?
I already have a PHILIPS 69143-65-PH
http://www.p4c.philips.com/cgi-bin/dcbi ... =6914365PH
If i buy a Phillips bridge, will this be compatible?
Also, should I then buy the new bridge? (is it better than the old one?)
Derik
Post by Derik »
Look @:
viewtopic.php?f=22&t=6095
For a friendly price.....
You can try them
Evelen
Post by Evelen »
Derik wrote:Look @:
You can try them
how mutch do you want inkl shipping to norway?
altso, is the bridge the 3.0?
also, can I use non-RGBW with RGBW?
ramesses
Domoticz version: 3.8755
Post by ramesses »
I have that Z-wave LED RGBW Lamp - ZW098 from Aeotec. I can answer your questions:
1. no. It is like any other z-wave device. You just secure include the lamp and then you can control on/off and set a color from Domoticz. See my post here.
2. yes, you can change color directly in domoticz. See the picture:
RGBW lamp settings
RGBW lamp settings
Domoticz on RaZberry, OZW 1.4-2713
Aeotec MultiSensor 6, Aeotec LED Bulb, Vision ZD2102 Door/Window Sensor, Vision ZP3102 PIR Motion Sensor, D-Link Siren DCH-Z510, Fibaro Smoke Sensor FGSD002, Aeotec Key Fob, Qubino ZMNHDD1 Z-Wave Plus Flush Dimmer
Evelen
Post by Evelen »
Hi and thx for info.
Is the case of GUI the same in I usa a non-ZWave bulp like AppLamp with bridge?
ramesses
Post by ramesses »
I am sorry I have no idea but I think so.
cyberclwn
Domoticz version: 2024.4
Post by cyberclwn »
Evelen wrote:Hi and thx for info.
Yes, it is the same for applamp/ Milight.
3xPi 2B (Domoticz "live", Domoticz "sandbox", PhotoFrame)
RFXCom433(E), KaKu, Oregon Scientific, Keyes 2-relay, Logitech Media Server, MiLight, Smartwares heating controller(2x), IR Send/Receive, Keyes PIR, XH-M131 DuskSensor, DHT22/11
