[513] Google Nest Protect (Smoke + CO sensor) support
Skorpion
Post by Skorpion »
It would be really nice if the Google Nest Protect can be supported in Domoticz. (Not to be mistaken with the Google Nest Thermostat. The request for the Google Nest Thermostat can be found here: http://www.domoticz.com/forum/viewtopic.php?f=5&t=6077)
- Read status of Protect in Domoticz so interaction with LUA/Blocky events are possible. E.g. Open curtains/roller shutters and turn lights on when alarm goes off.
Maybe it even is possible to use the PIR's of the protect to be used with other actuators etc.
The link to the tracker can be found here:
http://www.domoticz.com/forum/tracker.php?p=2&t=513
Skorpion
Re: [513] Google Nest Protect (Smoke + CO sensor) support
Post by Skorpion »
Did some searching and I found the code for the Nest thermostat & Protect plugin for the Vera controller. Does anyone know if this is easy adjustable to work with Domoticz?
Git code:
https://github.com/watou/vera-nest/tree/master/src
Readme/explanation:
http://watou.github.io/vera-nest/
tomeaton
Post by tomeaton »
Has anyone had any luck with this?
tcviper
Post by tcviper »
Same question, has support been implemented yet for Nest Protect? :)
Would love to see that next to the Thermostat.
tcviper
Post by tcviper »
Pretty pls :)
Sappien
Post by Sappien »
+1
C4Vette
Post by C4Vette »
Have three of these so would be great.
Wannabe: VeraLite user until it recently died. Looking for replacement.
franzelare
Post by franzelare »
I'm planning to replace my current smoke sensors because they are over 10 years old, so this would be a great feature!
gizmocuz
Post by gizmocuz »
Maybe someone with a nest protect can send me a PM with the login details, i then can have a look at implementing this
tcviper
Post by tcviper »
Gizmocuz pm ;)
Alle
Post by Alle »
I just updated to the new build with Nest protect support(Thank you!), but it get the following error in the log:
Error: Nest: Error login!
Checked my credentials and they are correct...
ESXi/Ubuntu - Z-wave.me USB Stick - Domoticz Beta - EvoHome - Nest Protect - Logitech Media Server - Netatmo Weather Station - Everspring - Aeonlabs
Derik
Post by Derik »
wwwwhhhooowwww great option... :) :D
Wath version is support?
Protect or protect V2?
tcviper
Post by tcviper »
Should work with both versions :)
You need to use your email as login and password from home.nest.com
Derik
Post by Derik »
some one have screendumps...?
Alle
Post by Alle »
Doesn't work (at least not for me). I only use Nest Protect, not the thermostat.. Could that be the cause?
*update
With invalid credentials:
2015-11-08 20:44:30.807 Error: Nest: Invalid data received, or invalid username/password!
With valid credentials:
2015-11-08 20:45:04.816 Error: Nest: Error login!
Bob123bob
Post by Bob123bob »
I got the same results
Add device works and the status is correct then there is no update and sometime Nest: Error login! in the log
PatrickEekhout
Post by PatrickEekhout »
Which readouts are possible with Domoticz from the Nest Protect? Can't seem to find it anywhere.
For example, is it possible to readout the current CO-level in ppm with Domoticz?
Clemen
Post by Clemen »
PatrickEekhout wrote:Which readouts are possible with Domoticz from the Nest Protect? Can't seem to find it anywhere.
This is whats supported by the API
https://developer.nest.com/documentatio ... rms-object
But Domoticz only shows a switch, which is alway off. even when there is smoke.
gizmocuz
Post by gizmocuz »
Well, it's an opensource project, and i made a good start with it
feel free to supply a git patch
bxlouis
Domoticz version: 2020.1
Post by bxlouis »
Is it normal that the Nest Protect switch type is set to "Lighting 2, AC, Smoke Detector"?
Also, does it make a difference between a CO alert and a Smoke alert?
Thanks and happy new year!
