[513] Google Nest Protect (Smoke + CO sensor) support
It would be really nice if the Google Nest Protect can be supported in Domoticz. (Not to be mistaken with the Google Nest Thermostat. The request for the Google Nest Thermostat can be found here: http://www.domoticz.com/forum/viewtopic.php?f=5&t=6077)
- Read status of Protect in Domoticz so interaction with LUA/Blocky events are possible. E.g. Open curtains/roller shutters and turn lights on when alarm goes off.
Maybe it even is possible to use the PIR's of the protect to be used with other actuators etc.
The link to the tracker can be found here:
http://www.domoticz.com/forum/tracker.php?p=2&t=513
Re: [513] Google Nest Protect (Smoke + CO sensor) support
Did some searching and I found the code for the Nest thermostat & Protect plugin for the Vera controller. Does anyone know if this is easy adjustable to work with Domoticz?
Git code:
https://github.com/watou/vera-nest/tree/master/src
Readme/explanation:
http://watou.github.io/vera-nest/
Git code:
Readme/explanation:
Has anyone had any luck with this?
- tcviper
Same question, has support been implemented yet for Nest Protect?
Would love to see that next to the Thermostat.
- C4Vette
Have three of these so would be great.
Wannabe: VeraLite user until it recently died. Looking for replacement.
I'm planning to replace my current smoke sensors because they are over 10 years old, so this would be a great feature!
- gizmocuz
Maybe someone with a nest protect can send me a PM with the login details, i then can have a look at implementing this
- Alle
I just updated to the new build with Nest protect support(Thank you!), but it get the following error in the log:
Error: Nest: Error login!
Checked my credentials and they are correct...
ESXi/Ubuntu - Z-wave.me USB Stick - Domoticz Beta - EvoHome - Nest Protect - Logitech Media Server - Netatmo Weather Station - Everspring - Aeonlabs
- Domoticz version: BETA
wwwwhhhooowwww great option...
Wath version is support?
Protect or protect V2?
- tcviper
Should work with both versions
You need to use your email as login and password from home.nest.com
some one have screendumps...?
- Alle
Doesn't work (at least not for me). I only use Nest Protect, not the thermostat.. Could that be the cause?You need to use your email as login and password from home.nest.com
*update
With invalid credentials:
2015-11-08 20:44:30.807 Error: Nest: Invalid data received, or invalid username/password!
With valid credentials:
2015-11-08 20:45:04.816 Error: Nest: Error login!
I got the same results
Add device works and the status is correct then there is no update and sometime Nest: Error login! in the log
Which readouts are possible with Domoticz from the Nest Protect? Can't seem to find it anywhere.
For example, is it possible to readout the current CO-level in ppm with Domoticz?
PatrickEekhout wrote:Which readouts are possible with Domoticz from the Nest Protect? Can't seem to find it anywhere.
This is whats supported by the API
https://developer.nest.com/documentatio ... rms-object
But Domoticz only shows a switch, which is alway off. even when there is smoke.
- gizmocuz
Well, it's an opensource project, and i made a good start with it
feel free to supply a git patch
- Domoticz version: 2020.1
Is it normal that the Nest Protect switch type is set to "Lighting 2, AC, Smoke Detector"?
Also, does it make a difference between a CO alert and a Smoke alert?
Thanks and happy new year!
