domoticz in synology as package! Available now.
Skippiemanz
Domoticz version: 4.10233
Post by Skippiemanz »
Check the domoticz log. Mine said that port 8084 was already taken. A reboot solved this
Pietoesnoe
Post by Pietoesnoe »
I'm having troubles with the latest update (2.0.3412-7) . Everything works fine, but after +/- 30min Domoticz stops. Wenn I manually restart it, everything stops +/- 30min later.
I already did a clean instal, reboot, nothing worked.
The last version worked fine (about 2 months ago), so it's been a while since I made an update.
I have a Synology DS214 fully updated.
Anyone else having these issues?
jumbotroll
Post by jumbotroll »
Pietoesnoe wrote:I'm having troubles with the latest update (2.0.3412-7) . Everything works fine, but after +/- 30min Domoticz stops. Wenn I manually restart it, everything stops +/- 30min later.
I don't know what causes your problem and it's working stable here on my DS712+.
I have today updated domoticz to V2.0.3430-7 and OpenZWave to Version 1.3.518.
Hope that solve your problem.
http://jadahl.dscloud.me/sspks/index.php?fulllist=true
http://www.jadahl.com
Jumbotroll
https://paypal.me/Jumbotroll
Jumbotroll
Pietoesnoe
jumbotroll wrote: I don't know what causes your problem and it's working stable here on my DS712+.
Jumbotroll
Thank you for all the work you are doing! I figured out what caused the crashes. The Kodi server in my devices made Domoticz crash. So it had nothing to do with the Synology package!
Thx for the update!
bayensf
Post by bayensf »
Hi I am new on this forum, just starting Domoticz.
This thread is long, 22 pages already, so just my question.
I have DS211j and have downloaded the package from synocommunity. Version showing 2.0.2112-5
I have ordered AEONLABS 2-stick USB, and have a Hikvison IP Camera operational (Visible in the Domoticz Windows versions)
Before I start Domoticz on my NAS do I need to do anything else? I see other's loading some additional programs, is this needed?
Also I see some "chat" about updates and drivers for USB devices, will the version from synocommunity have them and will the package update to future releases?
Any help is welcome and apreciated.
Many thanks in advance,
jumbotroll
bayensf wrote:Hi I am new on this forum, just starting Domoticz.
2.0.2112-5 from synocommunity does not support OpenZwave and has no USB drivers.
You can download my package with USB drivers and OpenZWave.
Latest Domoticz build V2.3502.
Jumbotroll
Jumbotroll
yugoos
Domoticz version: 2.3072
Post by yugoos »
@Jumbotroll
I have DS214 (no plus) and can't install your packages, i tried all armada variants but it should be armada-xp.
all i get is a error-message: "this package is not supported on this platform"
my current DSM version: 5.2-5592 Update 4
synocommunity version installed ok..
am i doing something wrong?
jumbotroll
yugoos wrote:@Jumbotroll
DS214 use arch-armadaxp
Have you tried to manually download domoticz_armadaxp-5.2_2.0.3502-7.spk http://jadahl.dscloud.me/sspks/packages ... 3502-7.spk
No one else has reported problem with armadaxp packages.
Jumbotroll
Jumbotroll
yugoos
Post by yugoos »
jumbotroll wrote: DS214 use arch-armadaxp
Jumbotroll
thanx for the quick reply.
unfortunately this one does not work either.
perhaps synopkg.log gives a hint but i can't find it (tar error is reported for regular updates aswel)
2015/10/31 12:51:43	(system) trigger	 :
			Begin:	/bin/mkdir -p /volume1/@tmp/5634AB4FE04A2E98/
			End:	/bin/mkdir -p /volume1/@tmp/5634AB4FE04A2E98/	ret=[0]
			Begin:	/bin/tar xf /volume1/@tmp/upload_tmp.299010 -C /volume1/@tmp/5634AB4FE04A2E98/ INFO --no-same-owner
			End:	/bin/tar xf /volume1/@tmp/upload_tmp.299010 -C /volume1/@tmp/5634AB4FE04A2E98/ INFO --no-same-owner	ret=[0]
			Begin:	/bin/tar xf /volume1/@tmp/upload_tmp.299010 -C /volume1/@tmp/5634AB4FE04A2E98/ conf --no-same-owner
/bin/tar: conf: Not found in archive
/bin/tar: Exiting with failure status due to previous errors
			End:	/bin/tar xf /volume1/@tmp/upload_tmp.299010 -C /volume1/@tmp/5634AB4FE04A2E98/ conf --no-same-owner	ret=[2]
2015/10/31 12:51:43	(system) trigger	domoticz 2.0.3502-7:
			Begin:	/bin/tar xf /volume1/@tmp/upload_tmp.299010 -C /volume1/@tmp/5634AB4FE04A2E98/ scripts/start-stop-status --no-same-owner --no-same-permissions
			End:	/bin/tar xf /volume1/@tmp/upload_tmp.299010 -C /volume1/@tmp/5634AB4FE04A2E98/ scripts/start-stop-status --no-same-owner --no-same-permissions	ret=[0]
			Begin:	/bin/tar xf /volume1/@tmp/upload_tmp.299010 -C /volume1/@tmp/5634AB4FE04A2E98/ scripts/preinst --no-same-owner --no-same-permissions
			End:	/bin/tar xf /volume1/@tmp/upload_tmp.299010 -C /volume1/@tmp/5634AB4FE04A2E98/ scripts/preinst --no-same-owner --no-same-permissions	ret=[0]
			Begin:	/bin/tar xf /volume1/@tmp/upload_tmp.299010 -C /volume1/@tmp/5634AB4FE04A2E98/ scripts/postinst --no-same-owner --no-same-permissions
			End:	/bin/tar xf /volume1/@tmp/upload_tmp.299010 -C /volume1/@tmp/5634AB4FE04A2E98/ scripts/postinst --no-same-owner --no-same-permissions	ret=[0]
			Begin:	/bin/tar xf /volume1/@tmp/upload_tmp.299010 -C /volume1/@tmp/5634AB4FE04A2E98/ scripts/preuninst --no-same-owner --no-same-permissions
			End:	/bin/tar xf /volume1/@tmp/upload_tmp.299010 -C /volume1/@tmp/5634AB4FE04A2E98/ scripts/preuninst --no-same-owner --no-same-permissions	ret=[0]
			Begin:	/bin/tar xf /volume1/@tmp/upload_tmp.299010 -C /volume1/@tmp/5634AB4FE04A2E98/ scripts/postuninst --no-same-owner --no-same-permissions
			End:	/bin/tar xf /volume1/@tmp/upload_tmp.299010 -C /volume1/@tmp/5634AB4FE04A2E98/ scripts/postuninst --no-same-owner --no-same-permissionsret=[0]
			Begin:	/bin/tar xf /volume1/@tmp/upload_tmp.299010 -C /volume1/@tmp/5634AB4FE04A2E98/ scripts/preupgrade --no-same-owner --no-same-permissions
			End:	/bin/tar xf /volume1/@tmp/upload_tmp.299010 -C /volume1/@tmp/5634AB4FE04A2E98/ scripts/preupgrade --no-same-owner --no-same-permissionsret=[0]
			Begin:	/bin/tar xf /volume1/@tmp/upload_tmp.299010 -C /volume1/@tmp/5634AB4FE04A2E98/ scripts/postupgrade --no-same-owner --no-same-permissions
			End:	/bin/tar xf /volume1/@tmp/upload_tmp.299010 -C /volume1/@tmp/5634AB4FE04A2E98/ scripts/postupgrade --no-same-owner --no-same-permissionsret=[0]
2015/10/31 12:51:44	(system) trigger	domoticz 2.0.3502-7:
			Begin:	/bin/rm -rf /volume1/@tmp/5634AB4FE04A2E98
			End:	/bin/rm -rf /volume1/@tmp/5634AB4FE04A2E98	ret=[0]
BTW...do you perhaps have a ser2net for synology? so i can remotely manage MySensors and OpenTherm-gateway connected to my NAS
jumbotroll
@yugoos
The log does not tell me what the problem is.
Did you uninstall the old domoticz or did you update?
I think you should uninstall the old.
I'm not familiar with ser2net, do you need some special drivers for this device?
Jumbotroll
Jumbotroll
yugoos
Post by yugoos »
I did uninstall the old version, i even doublechecked the removal from /var/packages after uninstall.
Could another package be causing trouble?
Ser2net is a popular and simple tool to share a serial port on a tcp port over the network/internet, if the serialport is available on the host no aditional driver is needed...i used your usbserial drivers for wich work great...
See: http://ser2net.sourceforge.net
Domoticz can also use these shared serial ports.
I only cannot compile anything on my nas and i dont have crosscompilers or the time to figure out what's needed to create a package
raymond
Domoticz version: V4.10232
Post by raymond »
I'm on the beta track through Synology jadahl repo. With every update, my scripts folder is gone. Since I had only 1 major script running, I started to make a copy of it in the /domoticz/ directory.
Again with the Latest update, V2.3542, my scripts folder is gone again, and the copy of the script is also gone.
What am I missing here? I'm recreating the folder and script each time an update has run. Though I'm, on a beta version, this shouldn't happen.
Any advice?
Ray
Skippiemanz
In witch folder did you put the scripts. I also use the jadahl packages but never had this problem
raymond
Post by raymond »
I have created the scripts folder myself, as it was missing. copied the samplescripts examples over and started to use the scripts.
Every update it is gone, so I must using the wrong folder, ie create it myself each time.
Also, I copied the script files I use to the /domoticz/ folder as a backup. Also gone after the updates.
I'm going mad! should I use /domoticz/var/scripts/ instead?
bayensf
Post by bayensf »
Jumbotroll
Thanks Jumbotroll,
I have downloaded and it worked. I also had to do an update, worked also.
Added the P1 Smart Meter USB worked perfect after I set the port to USB0 (connected at the front on the NAS) and 115200 as baud rate (9600 did not work on this KAIFA MA105C)
Now what remains is the AEOTEC Z-Stick Gen5 that is blinking all 3 colors all the time and not seeing my Fibaro Universal Binary Sensor (FGBS-001 v2.1 - v2.3)
The device is connected to ACM0 port on the NAS (I do not see any other ports). I used an USB port on the back in the NAS. Looking in Synolgy infocenter (DSM5.2) I see, for external systems 2 USB devices being "USBDevice - Sigma Designs, Inc." and "FT232 USB-Serial (UART) IC - Future Technology Devices International, Ltd". The last one my P1 Smart Meter USB and the first one should be the Z-Stick. So it's connected and seen by the NAS and by Domoticz, when I look in the LOG file it's there.
So what do I miss, why is my Binary Sensor not visible? I did follow the procedure, pushing the button 3 times. Even tried it with holding the Z-Stick next to it being in inclusion mode.
Not so important, just a question, the LOG file is filling itselff every 10 seconds with statements about the P1, any option to change it?
Any advise/help is more than welcome. :D Update: Solved by resetting,restarting,...again....now it's ok :mrgreen:
Many thanks in advance, with kind regards,
BayensF
Last edited by bayensf on Wednesday 04 November 2015 22:39, edited 1 time in total.
Skippiemanz
raymond wrote:I have created the scripts folder myself, as it was missing. copied the samplescripts examples over and started to use the scripts.
yes thats the one i use! Try that one instead.
Ady92100
Domoticz version: >V3.6796
Post by Ady92100 »
Hello everybody
I've just installed domoticz on my Synology DS212 after having used Raspberry 2 during many months.
Besides domoticz (published by Jumbotroll) I use a bash script to detect presence at home based on ping.
So each time, I update domoticz with the DSM "package manager', it never starts again.
Even if I kill all running 'bash program' and all events locking port 8084 (netstat command), the domoticz program don't start again.
The only way I've found to make domoticz restart is to issue the command "ipkg remove bash" which is painfull.
Do you have any idea why I have to issue this command and how I can solve my problem ?
Thanks for your help
Synology DS212 + RFXTrx433 + AEon Stick S2
Oregon - Thgr122Nx / Chacon - module 1000w - détecteur de fumée 34131 / OWL -CM180 / Greenwave Multiprise
Ady92100
Post by Ady92100 »
Hello Jumbotroll,
this package.... It's a great work and thank you for it.
I use this enhancement "custom pages" http://easydomoticz.com/forum/viewtopic.php?f=17&t=331
All the app is installed in /domoticz/www/monitor
Every update the directory "domoticz/www/monitor" is erased. So everytime i have to copy them manualy from a copy.
And of course I forget to save this directory before the update.
Can you help me (eg not erase this directory monitor)
Thanks.
jumbotroll
Ady92100 wrote:Hello Jumbotroll,
Thanks.
Here you go ;)
Test build with backup/restore of /domoticz/www/monitor folder.
http://www.jadahl.com/beta.html
Jumbotroll
Jumbotroll
raymond
Post by raymond »
Yes this is surviving the updates. A lot of references in this forum and wiki are on the ./domoticz/scripts/ folder. This is not right, and it's deleted with every (beta) update.
Thanks for pointing this out, all good now.
Ray
Users browsing this forum: Gianluca and 1 guest
