Domoticz App for Windows Phone
DavidM84
Re: Domoticz App for Windows Phone
Post by DavidM84 »
thecosmicgate wrote:Running Win10 (not the phone version) on a tablet . but not possible to install
Yes it's right I haven't done it for the moment I have to finish any improvment on the actual version like scroll in paramaters and any other technical things and after i will done in W10 perhaps I will implement management of multiple box in same time ....
Jack
Domoticz version: V2.3530
Post by Jack »
Here I am using WP 8.1 and can not set-up a connection.
With the samsung app no problem.
Is there a tutorial for this??
Jack
Post by Jack »
I have connection now...do not ask me what did different but it is connected.
Know I can not see my switches etc.
The midlle of the three buttons below (settings) I can not touch it is gray.
Simmulair with one off the remarks above in this topic.
Has anyone allready found out what to do to get it working?
I am from Holland may we have other apps...
I use the domoticz app from de microsoft store.
Thanks a lot for helping me.
Regards,
Jack
DavidM84
Post by DavidM84 »
if you select a device after the button become enabled
Jack wrote:I have connection now...do not ask me what did different but it is connected.
Regards,
Jack
DavidM84
Post by DavidM84 »
With the beta version I see there is a little change which impact the reading of data so I had made the change, so I done any other thing I have to test a bit before sending it to you
Jack
Post by Jack »
David,
thanks for the replay and PM.
I can not see any device.
In the log function in Domticz i see that Iam connected.
Looking forward for your update.
Thanks a lot on forehand.
Regards,
Jack
DavidM84
Post by DavidM84 »
Because a misunderstanding with my father (My favorite tester and my integrator) I think you will receive the new version soon, I hope it will work well
Jack
Post by Jack »
Hi David,
Thanks a lot.
Will we get it via the windows store as an update?
Grets and regards,
Jack
DavidM84
Post by DavidM84 »
yes, and now I think it's ok
Jack wrote:Hi David,
Thanks a lot.
Grets and regards,
Jack
Jack
Post by Jack »
great looking forward for it.
Jack
Post by Jack »
Yes something is changed.
But still not updating with my switches. :cry:
I see the test switches that are in the test system that comes with the app on first installation.
I change the conection details and see it connected on my domoticz log.
After switching off and on connection information is back to default.
I had one time connection after that is not possible to connect anymore.
Hopefully my info and feedback helps you...
Regards and thanks on forehand.
Jack
DavidM84
Post by DavidM84 »
did you use the new button to save configuration?
Jack wrote:Yes something is changed.
Jack
Jack
Post by Jack »
I did not found....
But after your remark I found it.
Thanks a lot now it is updating and can I start testing.
Maybe it is more easy to set the save button in the field so it is more vissable
and use the symbol for save.
But I found and happy now.
many thanks,
Jack
Jack
Post by Jack »
App on window's phone is working now.
there is only one problem.. a few words are in french.
Is it possible to translate all in Dutch?
Or is there a possibillity to select englisch as language?
petzno
Post by petzno »
Let us know if we can contribute to have this translated to english.
PeterHarrie
Post by PeterHarrie »
The app is half English, half French and half Dutch.
It looks like the developer started in native French (not a good idea :-))
Can we help in any way? Are you thinking of open-sourcing the app?
pepijn
Post by pepijn »
PeterHarrie wrote:The app is half English, half French and half Dutch.
That's difficult, 3 x half :D
PeterHarrie
Sharp!
DavidM84
Post by DavidM84 »
The Project Is only in french at the origine and i use domoticz translation for a major part... I have not a lot of time to verify all translation and each time any one ask me how can i help you I want to say: tell me which word s aren't translated and i can change it quickly....
I think it's a good idea to make it in french because I have no problems with my translation.
PeterHarrie
I have sent you a PM with some ideas and words that are off.
We in Holland tend to do everything in English and only later do translations... guess the French think a little different :-)
