Yes it's right I haven't done it for the moment I have to finish any improvment on the actual version like scroll in paramaters and any other technical things and after i will done in W10 perhaps I will implement management of multiple box in same time ....thecosmicgate wrote:Running Win10 (not the phone version) on a tablet . but not possible to install
Domoticz App for Windows Phone
Re: Domoticz App for Windows Phone
- Domoticz version: V2.3530
Here I am using WP 8.1 and can not set-up a connection.
With the samsung app no problem.
Is there a tutorial for this??
I have connection now...do not ask me what did different but it is connected.
Know I can not see my switches etc.
The midlle of the three buttons below (settings) I can not touch it is gray.
Simmulair with one off the remarks above in this topic.
Has anyone allready found out what to do to get it working?
I am from Holland may we have other apps...
I use the domoticz app from de microsoft store.
Thanks a lot for helping me.
Regards,
Jack
Regards,
Jack
if you select a device after the button become enabled
Jack wrote:I have connection now...do not ask me what did different but it is connected.
Regards,
Jack
With the beta version I see there is a little change which impact the reading of data so I had made the change, so I done any other thing I have to test a bit before sending it to you
David,
thanks for the replay and PM.
I can not see any device.
In the log function in Domticz i see that Iam connected.
Looking forward for your update.
Thanks a lot on forehand.
Regards,
Jack
Regards,
Jack
Because a misunderstanding with my father (My favorite tester and my integrator) I think you will receive the new version soon, I hope it will work well
Hi David,
Thanks a lot.
Will we get it via the windows store as an update?
Grets and regards,
Jack
Thanks a lot.
Grets and regards,
Jack
yes, and now I think it's ok
Jack wrote:Hi David,
Thanks a lot.
Grets and regards,
Jack
great looking forward for it.
Yes something is changed.
But still not updating with my switches.
I see the test switches that are in the test system that comes with the app on first installation.
I change the conection details and see it connected on my domoticz log.
After switching off and on connection information is back to default.
I had one time connection after that is not possible to connect anymore.
Hopefully my info and feedback helps you...
Regards and thanks on forehand.
Jack
Jack
did you use the new button to save configuration?
Jack wrote:Yes something is changed.
But still not updating with my switches.![]()
Jack
I did not found....
But after your remark I found it.
Thanks a lot now it is updating and can I start testing.
Maybe it is more easy to set the save button in the field so it is more vissable
and use the symbol for save.
But I found and happy now.
many thanks,
Jack
many thanks,
Jack
App on window's phone is working now.
there is only one problem.. a few words are in french.
Is it possible to translate all in Dutch?
Or is there a possibillity to select englisch as language?
Let us know if we can contribute to have this translated to english.
The app is half English, half French and half Dutch.
It looks like the developer started in native French (not a good idea
Can we help in any way? Are you thinking of open-sourcing the app?
That's difficult, 3 x halfPeterHarrie wrote:The app is half English, half French and half Dutch.
The Project Is only in french at the origine and i use domoticz translation for a major part... I have not a lot of time to verify all translation and each time any one ask me how can i help you I want to say: tell me which word s aren't translated and i can change it quickly....
I think it's a good idea to make it in french because I have no problems with my translation.
I have sent you a PM with some ideas and words that are off.
We in Holland tend to do everything in English and only later do translations... guess the French think a little different
