Domoticz App for Windows Phone
jackslayter
- Domoticz version: stable
RPi2 + RFLink, Domoticz
Chacon - micromodule 200w, remote 3b, 2x module 1000w, remote 16b, smoke detector, door contact, 2x 3500w plug
Oregon - 3x Thgr122Nx / OWL - CM180 / TRC02_2 RGB / Cheap - PiR, door contact, Temp Hum / 4x REVOLT NC5461
DavidM84
Re: Domoticz App for Windows Phone
I work on it.
What do you think about ask me any impovement?
I work on it.
dijkdj
Hello David,
My wife uses the WP app:
Possible improvements:
-Fit more switches on one page: Space is taken now by info lastaccess/type switch. I think you can put it in a smaller font
-Make roomplan accessible
If I think of more I will add it. Good work!
DavidM84
Cool the change was already done but I have to test on different size to be sure, I have a 1520 the size always seem good tonight I test on my wife's 920 to see and perhaps tomorow we will send a new version, So for the room plan I have to make any think like configure it on my server....
jackslayter
Hi, it is possible to add https with private certificate (login) ?
Thank you
Thank you
DavidM84
How can I configure my raspberry to have https, did you have a tuto to save time ? If I configure mine I will have to implement itjackslayter wrote:Hi, it is possible to add https with private certificate (login) ?
Thank you
jackslayter
globalassist
Works great! Could use a better translator for Dutch. Can I help?
DavidM84
Of course perhaps by private messageglobalassist wrote:Works great! Could use a better translator for Dutch. Can I help?
superwifly
Hello, im trying to configure the app in my windows phone but any kind of configuration i put in the conection settings of the app i get the error "connection error". I tried mading the connection in the local lan and i tried with nating across internet (opening the correct ports). I tried with autentication of web site and without ( i tried mading basic auth to)
Can you help me plis? i dont know what is the problem.
King regards.
King regards.
Kouseri
Hi David,DavidM84 wrote:Hello,
I work on it.
I would like to start learning Windows (Phone) development and I would like to do an app which modifies user variables of Domoticz. More information about the idea can be found from here. I was just thinking how the app would interact with the Domoticz. So could you reveal how your app is interacting with the Domoticz? Are you using json queries or something else?
- MaffeMuis
- Domoticz version: 3.9483
Not working in Windows 10 phone.
Can not scroll in the settings, so i can not set it up.
Ik ben en blijf een brabander!
|Node-Red|Mqtt|ESPboards|tasmota|NAS|
Hi David,
Thanks a lot for your work. Could You improve NFC into domoticz mobile app? thanks in advance!!
gcoupe
- Domoticz version: v4.10717
Not working in WP8.1 either.
Can't scroll down the Connexion page to set it up.
The UI is in French - I assume middle icon at the bottom of the screen is to get into Installation settings. But the icon is greyed-out, so I can't select it.
- thecosmicgate
- Domoticz version: newest
Not working in win10
It's nice to be important, but it's more important to be nice
Scooter ;)
Scooter ;)
Isane
- Domoticz version: Stable
Send DavidM84 a message?thecosmicgate wrote:Not working in win10
DavidM84
Interesting... I use it on my 1520 with Windows mobile 10 but perhaps it'is due to the scroll problem in settings(I didn't see it with my screen),thecosmicgate wrote:Not working in win10
So I'm testing any correction I had done for me perhaps I will send any update in the next week
DavidM84
Hi, perhaps you have to test the connection via internet explorer before so if you are in local lan you don"t have to specify user passwordsuperwifly wrote:Hello, im trying to configure the app in my windows phone but any kind of configuration i put in the conection settings of the app i get the error "connection error". I tried mading the connection in the local lan and i tried with nating across internet (opening the correct ports). I tried with autentication of web site and without ( i tried mading basic auth to)
King regards.
DavidM84
Yes of course, I used rest request if you want to update a user variable you can sendKouseri wrote:Hi David,DavidM84 wrote:Hello,
I work on it.
GET /json.htm?type=command¶m=getuservariables
that return a json data where you identify your user variable and after you ca send this request
GET /json.htm?type=command¶m=updateuservariable&idx=(your uservariable idx)&vname=(your uservariable name)&vtype=2&vvalue=(the value), vtype = 2 is string type
- thecosmicgate
Running Win10 (not the phone version) on a tablet . but not possible to install
Scooter ;)
Scooter ;)
